查看: 3240|回复: 13
HWL的ip怎么变了- -
发表于 2015-9-22 19:51:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
难不成被集中到一台大鸡鸡上来额。。
发表于 2015-9-22 19:53:38 | 只看该作者
被你知道了
发表于 2015-9-22 19:54:38 | 只看该作者
HWL自己买了IP。。。你查下新IP的WHOIS就知道了。
发表于 2015-9-22 19:55:44 | 只看该作者
现在才知道阿
 楼主| 发表于 2015-9-22 19:56:59 | 只看该作者
没留意到有通知。
  1. This is a notification that your Hong Kong VPS will be migrated to a new VPS node. After seeing many performance-related problems with the current VPS nodes, we have acquired a more powerful Dual E5-2620v2 node within the SoftLayer Hong Kong datacenter and we will be moving you over. We believe this is beneficial for your VPS as it will improve its performance across multiple areas. The migration window is the following, however your VPS will only go down for a brief period of no longer than one (1) hour.
  2. From: 7.00AM Sunday, 20 September 2015 (UTC)
  3. To: 7.00AM Monday, 21 September 2015 (UTC)
  4. There will be an IP change associated to this move. Once all VPS are migrated we will email you your new IP address. You may also find your new IP address by logging into the VPS control panel. All IP's starting with 119 and 209 will be renumbered.
  5. If you currently have a NAT VPS, this is good news for you! You will no longer have a shared IP and you will be assigned a dedicated IP address, for free!
  6. Please let us know if you have any questions.
  7. Best Regards,
  8. HostWithLinux Ltd.
发表于 2015-9-22 20:00:48 | 只看该作者
换IP是小事,关键是鸡鸡能量要充足。
发表于 2015-9-22 20:05:18 | 只看该作者
多了swap 1g,不错
发表于 2015-9-22 20:15:02 来自手机 | 只看该作者
老板赚大钱了,自己申请as号了,买ip了。
发表于 2015-9-22 21:08:37 | 只看该作者
只买有自己ip的主机商的vps,跑路概率能小一点
发表于 2015-9-22 21:13:27 | 只看该作者
哪里看见自己IP
GMT+8, 2026-4-30 04:47 , Processed in 0.066671 second(s), 10 queries , Gzip On, MemCache On.
