查看: 2748|回复: 0
K总MJJ的cheapvz 弗里蒙特节点 256M的简单测试
发表于 2015-9-14 10:46:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
地址:https://www.cheapvz.com/aff.php?aff=20&gid=1
测试IP:
弗利蒙 198.176.48.2
洛杉矶 104.251.224.1
凤凰城 107.178.66.1
下面是弗里蒙特节点  256M的简单测试  来自夜妹子博客,现在转载过来
基础测试
CPU model :  Intel(R) Xeon(R) CPU E5-1650 v2 @ 3.50GHz
Number of cores : 1
CPU frequency :  3501.000 MHz
Total amount of ram : 256 MB
Total amount of swap : 0 MB
System uptime :   13:56,
Download speed from CacheFly: 9.15MB/s
Download speed from Coloat, Atlanta GA: 1.48MB/s
Download speed from Softlayer, Dallas, TX: 1.31MB/s
Download speed from Linode, Tokyo, JP: 1000KB/s
Download speed from i3d.net, Rotterdam, NL: 1008KB/s
Download speed from Leaseweb, Haarlem, NL: 791KB/s
Download speed from Softlayer, Singapore: 1.38MB/s
Download speed from Softlayer, Seattle, WA: 2.76MB/s
Download speed from Softlayer, San Jose, CA: 8.51MB/s
Download speed from Softlayer, Washington, DC: 988KB/s
I/O speed :  123 MB/s
硬件指数
root@vpsmm:/home/wwwroot/default# uptime
22:07:49 up 14:11,  1 user,  load average: 0.02, 0.05, 0.00
root@vpsmm:/home/wwwroot/default# free -m
             total       used       free     shared    buffers     cached
Mem:           256         82        173          0          0         12
-/+ buffers/cache:         69        186
Swap:            0          0          0
root@vpsmm:/home/wwwroot/default# df -hal
Filesystem      Size  Used Avail Use% Mounted on
/dev/simfs       15G  4.2G   11G  28% /
proc               0     0     0    - /proc
sysfs              0     0     0    - /sys
none            128M  4.0K  128M   1% /dev
none               0     0     0    - /dev/pts
none               0     0     0    - /proc/sys/fs/binfmt_misc
none             26M  976K   25M   4% /run
none            5.0M     0  5.0M   0% /run/lock
none             52M     0   52M   0% /run/shm
none            100M     0  100M   0% /run/user
root@vpsmm:/home/wwwroot/default# df -i
Filesystem      Inodes  IUsed   IFree IUse% Mounted on
/dev/simfs     7864320 129189 7735131    2% /
none             32768     97   32671    1% /dev
none             32768     75   32693    1% /run
none             32768      1   32767    1% /run/lock
none             32768      2   32766    1% /run/shm
none             32768      1   32767    1% /run/user
root@vpsmm:/home/wwwroot/default# lscpu
Architecture:          i686
CPU op-mode(s):        32-bit, 64-bit
Byte Order:            Little Endian
CPU(s):                12
Vendor ID:             Genu
CPU family:            6
Model:                 62
Stepping:              4
CPU MHz:               3501.000
BogoMIPS:              7000.18
Virtualization:        VT-x
网络测试
#vps上下载cachefly文件
root@vpsmm:/home/wwwroot/default# wget cachefly.cachefly.net/100mb.test
--2015-09-13 22:09:57--  http://cachefly.cachefly.net/100mb.test
Resolving cachefly.cachefly.net (cachefly.cachefly.net)... 205.234.175.175
Connecting to cachefly.cachefly.net (cachefly.cachefly.net)|205.234.175.175|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 104857600 (100M) [application/octet-stream]
Saving to: `100mb.test'
100%[=============================================>] 104,857,600 7.23M/s   in 12s
2015-09-13 22:10:09 (8.22 MB/s) - `100mb.test' saved [104857600/104857600]
#来自crissic洛杉矶vps下载测试结果
root@vpsmm:~# wget 104.143.36.157/100mb.test
--2015-09-13 22:12:03--  http://104.143.36.157/100mb.test
Connecting to 104.143.36.157:80... connected.
Saving to: '100mb.test'
100%[=============================================>] 104,857,600 8.22MB/s   in 12s
2015-09-13 22:12:14 (8.60 MB/s) - '100mb.test' saved [104857600/104857600]
硬盘IO测试
root@vpsmm:/home/wwwroot/default# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 2.16265 s, 124 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 2.18634 s, 123 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 1.92819 s, 139 MB/s
综合跑分
Benchmark Run: Sun Sep 13 2015 22:15:20 - 22:43:33
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       21566330.2 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3739.2 MWIPS (10.0 s, 7 samples)
Execl Throughput                               5092.3 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        513292.8 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          146224.6 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1448548.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                              990159.5 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 229562.8 lps   (10.0 s, 7 samples)
Process Creation                              12517.9 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   6196.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    766.6 lpm   (60.0 s, 2 samples)
System Call Overhead                         955827.8 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   21566330.2   1848.0
Double-Precision Whetstone                       55.0       3739.2    679.9
Execl Throughput                                 43.0       5092.3   1184.3
File Copy 1024 bufsize 2000 maxblocks          3960.0     513292.8   1296.2
File Copy 256 bufsize 500 maxblocks            1655.0     146224.6    883.5
File Copy 4096 bufsize 8000 maxblocks          5800.0    1448548.4   2497.5
Pipe Throughput                               12440.0     990159.5    795.9
Pipe-based Context Switching                   4000.0     229562.8    573.9
Process Creation                                126.0      12517.9    993.5
Shell Scripts (1 concurrent)                     42.4       6196.9   1461.5
Shell Scripts (8 concurrent)                      6.0        766.6   1277.7
System Call Overhead                          15000.0     955827.8    637.2
System Benchmarks Index Score                                        1071.8
测试IP
104.143.36.157 / php探针 / 100mb.test / wordpress演示
GMT+8, 2026-4-29 22:46 , Processed in 0.282987 second(s), 12 queries , Gzip On, MemCache On.
