查看: 11441|回复: 32
K总MJJ的cheapvz小鸡鸡地址与简单测试
发表于 2015-9-13 12:46:17 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
MJJ的K总已经把便宜货单独搞成一个全新的子品牌,主站kvmla已经下架了便宜货,估计也是为了更好管理吧!今天手贱,剁手了一个512M套餐的,数据中心选择的是洛杉矶!可以说后台还是一如既往的简洁,各项指标都非常的清晰,一览无余!现在趁热打铁,要不之后又几乎时间不够了!现在就做一个简单的测试吧,前提不跑分,太费时间了!
地址:https://www.cheapvz.com/aff.php?aff=20&gid=1
测试IP:
弗利蒙 198.176.48.2
洛杉矶 104.251.224.1
凤凰城 107.178.66.1
配置:
CPU:2 core
RAM:512M
HDD:30G
IPV4: 1
Bandwidth:800G
1、CPU参数
[root@yourdomain ~]# cat /proc/cpuinfo
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 44
model name : Intel(R) Xeon(R) CPU L5639 @ 2.13GHz
stepping : 2
microcode : 21
cpu MHz : 1600.000
cache size : 12288 KB
physical id : 0
siblings : 12
core id : 0
cpu cores : 6
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 11
wp : yes
依然还是CPU L5639   ,频率MJJ的做了限制在1600MHZ
2、VPS网络性能测试
[root@yourdomain ~]# wget http://dl.wdlinux.cn:5180/lanmp_laster.tar.gz
--2015-09-13 00:09:32-- http://dl.wdlinux.cn:5180/lanmp_laster.tar.gz
Resolving dl.wdlinux.cn... 119.146.223.143
Connecting to dl.wdlinux.cn|119.146.223.143|:5180... connected.
HTTP request sent, awaiting response... 200 OK
Length: 81312101 (78M) [application/octet-stream]
Saving to: `lanmp_laster.tar.gz'
100%[======================================>] 81,312,101 210K/s in 8m 48s
2015-09-13 00:18:22 (150 KB/s) - `lanmp_laster.tar.gz' saved [81312101/81312101]
[root@yourdomain ~]# wget http://cachefly.cachefly.net/100mb.test
--2015-09-13 00:22:44-- http://cachefly.cachefly.net/100mb.test
Resolving cachefly.cachefly.net... 205.234.175.175
Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
Length: 104857600 (100M) [application/octet-stream]
Saving to: `100mb.test'
100%[======================================>] 104,857,600 23.9M/s in 4.6s
2015-09-13 00:22:48 (21.7 MB/s) - `100mb.test' saved [104857600/104857600]
cheapvz vps
ping值还是不错的,在不抽风的情况下,国内速度还是不错的!联通线路要稍微差那么一点点!
3、vps硬盘I/O测试
[root@yourdomain ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 2.22804 s, 120 MB/s
4096+0 records in
4096+0 records out
268435456 bytes (268 MB) copied, 1.96894 s, 136 MB/s
4、AMH4.2的安装
******* SSH Management *******
Host: amh host
PHP: amh php
Nginx: amh nginx
MySQL: amh mysql
FTP: amh ftp
Backup: amh backup
Revert: amh revert
SetParam: amh SetParam
Module : amh module
Crontab : amh crontab
Upgrade : amh upgrade
Info: amh info
******* SSH Dirs *******
WebSite: /home/wwwroot
Nginx: /usr/local/nginx
PHP: /usr/local/php
MySQL: /usr/local/mysql
MySQL-Data: /usr/local/mysql/data
Start time: Sun Sep 13 12:31:29 CST 2015
Completion time: Sun Sep 13 12:43:33 CST 2015 (Use: 12 minute)
More help please visit:http://amysql.com
暂时就到这吧,发现安装AMH在小七使用过这么多VPS主机中,速度算是很快的了!特别是使用腾讯云的时候安装AMH那才是一个煎熬啊!这估计与硬盘的性能有很大的关系!
小七博客:https://www.xqblog.com
发表于 2015-9-13 12:54:29 | 只看该作者
@晓白   @kvm  k肿我有一个博客。。。。。。
 楼主| 发表于 2015-9-13 12:55:55 | 只看该作者
 楼主| 发表于 2015-9-13 13:00:07 | 只看该作者
没有涨价吧,查看了一下以前的  是降价了一点点
发表于 2015-9-13 13:53:57 | 只看该作者
发表于 2015-9-13 14:18:45 | 只看该作者
这么快就入手了啊。。
发表于 2015-9-13 14:33:08 | 只看该作者
这么快就入手
发表于 2015-9-13 14:33:36 | 只看该作者
k肿我有一个博客。。。。。。
GMT+8, 2026-4-30 09:42 , Processed in 0.064224 second(s), 10 queries , Gzip On, MemCache On.
