查看: 2322|回复: 1
[Windows VPS] Hostodo的邮件什么意思?As you may or may have not known
发表于 2015-8-18 11:35:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
August 17th, 2015
As you may or may have not known, we have recently had an influx of spammers register and spam from our network here at Hostodo, getting many of our IP ranges listed on the Spamhaus blacklist.
We have been working with our datacenter on getting these listings removed, and in the meantime, to control the situation, a limitation has been put in place blocking connections over port 25.
This limitation has been removed, and Spamhaus listings resolved. We have a strict anti-spam policy in place with a 0 tolerance policy. Any spam mailing will result in service termination. There is a limit of 15 SMTP connections in place per VM. If you need this limit raised for a legitimate reason, please contact us at support@hostodo.com
This is all in an effort to create the best environment for Hostodo VPS clients. Please feel free to get in touch if there are any questions or concerns.
是说把25端口关了吗?
发表于 2015-8-18 11:52:58 | 只看该作者
服务器IP进入黑名单问题已经解决了,所以那个邮件端口的限制解除,但是颁布了新的条款,发现乱发垃圾邮件会有惩罚
GMT+8, 2026-4-19 08:37 , Processed in 0.065150 second(s), 10 queries , Gzip On, MemCache On.
