查看: 8054|回复: 37
[不限流量] **深夜发福利***HWL同款低价SL香港鸡,仅剩6台。
发表于 2015-7-1 00:05:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
今天发现的一家IDC新上线了SL香港,512M内存月付3.99刀!
看到8个可用于是忍不住诱惑付款买了一台。
买SL香港自然看中网络,开通后自己搭建了SS测试发现效果还是很不错的,跟我手里的HWL9刀季付效果一样好好的,ping也很好看,无图无真相
U2B看1080P可以上5000,还是不错的。
BYTE UNIX Benchmarks (Version 5.1.3)
   System: startss: GNU/Linux
   OS: GNU/Linux -- 2.6.32-042stab108.5 -- #1 SMP Wed Jun 17 20:20:17 MSK 2015
   Machine: x86_64 (unknown)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz (4600.0 bogomips)
          Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
   CPU 1: Intel(R) Xeon(R) CPU E5-2650 v3 @ 2.30GHz (4600.0 bogomips)
   10:56:57 up 11 min,  1 user,  load average: 0.19, 0.15, 0.06; runlevel 2
Benchmark Run: Tue Jun 30 2015 10:56:57 - 11:27:29
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       13001409.1 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3254.9 MWIPS (9.9 s, 7 samples)
Execl Throughput                               2103.7 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        349757.3 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           93611.5 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1147645.9 KBps  (30.0 s, 2 samples)
Pipe Throughput                              633688.0 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 132851.3 lps   (10.0 s, 7 samples)
Process Creation                               5782.0 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   3075.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    418.8 lpm   (60.1 s, 2 samples)
System Call Overhead                        1004957.3 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   13001409.1   1114.1
Double-Precision Whetstone                       55.0       3254.9    591.8
Execl Throughput                                 43.0       2103.7    489.2
File Copy 1024 bufsize 2000 maxblocks          3960.0     349757.3    883.2
File Copy 256 bufsize 500 maxblocks            1655.0      93611.5    565.6
File Copy 4096 bufsize 8000 maxblocks          5800.0    1147645.9   1978.7
Pipe Throughput                               12440.0     633688.0    509.4
Pipe-based Context Switching                   4000.0     132851.3    332.1
Process Creation                                126.0       5782.0    458.9
Shell Scripts (1 concurrent)                     42.4       3075.9    725.5
Shell Scripts (8 concurrent)                      6.0        418.8    698.0
System Call Overhead                          15000.0    1004957.3    670.0
System Benchmarks Index Score                                         671.5
Benchmark Run: Tue Jun 30 2015 11:27:29 - 12:02:10
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       13939833.6 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     6503.4 MWIPS (9.9 s, 7 samples)
Execl Throughput                               2136.0 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        372504.7 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           98392.2 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1191092.9 KBps  (30.0 s, 2 samples)
Pipe Throughput                              696467.1 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 134653.6 lps   (10.0 s, 7 samples)
Process Creation                               6914.5 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   3431.5 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    446.8 lpm   (60.2 s, 2 samples)
System Call Overhead                        1052298.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   13939833.6   1194.5
Double-Precision Whetstone                       55.0       6503.4   1182.4
Execl Throughput                                 43.0       2136.0    496.7
File Copy 1024 bufsize 2000 maxblocks          3960.0     372504.7    940.7
File Copy 256 bufsize 500 maxblocks            1655.0      98392.2    594.5
File Copy 4096 bufsize 8000 maxblocks          5800.0    1191092.9   2053.6
Pipe Throughput                               12440.0     696467.1    559.9
Pipe-based Context Switching                   4000.0     134653.6    336.6
Process Creation                                126.0       6914.5    548.8
Shell Scripts (1 concurrent)                     42.4       3431.5    809.3
Shell Scripts (8 concurrent)                      6.0        446.8    744.7
System Call Overhead                          15000.0    1052298.7    701.5
System Benchmarks Index Score                                         756.7
https://hostingandvps.com/billing/cart.php?gid=33
 楼主| 发表于 2015-7-1 00:14:01 | 只看该作者
发表于 2015-7-1 00:14:35 | 只看该作者
裤子都脱了,给我看这个?
发表于 2015-7-1 00:15:30 | 只看该作者
流量这么少 怎么跟HWL比
发表于 2015-7-1 00:16:42 来自手机 | 只看该作者
Location SINGAPORE ( Asia )?
发表于 2015-7-1 00:39:50 | 只看该作者
香港的 4刀没了
发表于 2015-7-1 00:55:09 | 只看该作者
醉了,到底是香港小鸡还是新加坡小鸡?
GMT+8, 2026-4-15 15:30 , Processed in 0.070679 second(s), 14 queries , Gzip On, MemCache On.
