查看: 1649|回复: 5
DO莫名奇妙的无法连接。。求翻译
发表于 2015-3-30 22:46:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hello!
Usually this happens as a result of a package update (yum update) having updated the kernel libraries on your system without a matching kernel being set.
To check to see if this is the case, please log into the control panel, click the droplet, then "Access" then "Console". Then log in as root. If you are unable to load the console or log in, please let us know, perhaps sharing the access credentials that you were using.
Once logged in, run:
ls -al /lib/modules
If you do not see more than one directory, leave yourself logged in to the server on the console and let us know. However, if you do see more than one directory there, take note of the versions (best way is to take a screenshot).
Then, go to the control panel, click on the droplet, click "settings" and then "Kernel". Click the list and find the right version that matches your kernel libraries. Make sure you choose the right architecture (x32 or x64) and version matching your droplet's OS. Then, return to the console and power off with the command "poweroff". Then boot the droplet using the control panel, and check to see if networking was restored once the droplet boots. If not, please log into the console as root and then let us know so that we may investigate more deeply.
Let us know if you have any additional questions or concerns.
Regards,
Tim
DigitalOcean Support
发表于 2015-3-30 22:48:52 | 只看该作者
 楼主| 发表于 2015-3-30 23:08:52 | 只看该作者
看他的意思就是DO最好不要yum update...不然会出现一系列奇葩的问题。。。
发表于 2015-3-30 23:33:51 | 只看该作者
看来是更新了kernel..
yum update 又不看清楚了吧
入DO的网页Console
登入root
ls -al /lib/modules
假如只有一个资料夹
保持登入状态, 回覆ticket说只有一个folder在那
假如有几个资料夹
将上面ls的结果截图
然后入DO的Control Panel, 选Setting, Kernel, 选个ls里有和对应的kernel ((搞清楚x32和x64啊!)
进console: poweroff
再从DO面版Power On小鸡就应该可以了
假如还是不行的话, console里登入root不要登出, 回覆ticket, 叫他跟进
要是有其他问题, 也请回覆ticket
发表于 2015-3-30 23:53:43 | 只看该作者
还没放弃centos?
debian -大--法-好
 楼主| 发表于 2015-3-30 23:59:37 | 只看该作者
v998 发表于 2015-3-30 23:33
看来是更新了kernel..
yum update 又不看清楚了吧
英文牛。
GMT+8, 2026-4-21 07:18 , Processed in 0.065492 second(s), 13 queries , Gzip On, MemCache On.
