查看: 3899|回复: 16
21.6美元一年/3美元一月256/512MB的VPS
发表于 2010-9-2 12:51:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
123systems.net提供的,今天在LEB看到,配置如下:
256MB guaranteed/512MB burstable memory
10GB storage
500GB/month data transfer
OpenVZ/SolusVM
购买连接在这里: https://www.123systems.net/billing/cart.php?a=add&pid=101
(原文提供的)
原文在这里:http://www.lowendbox.com/blog/12 ... z-vps/#comment-8724
芝加哥SingleHop机房,近来许多SingleHop机房的便宜VPS出现了啊。
更新,我问了他们,他们没有173IP,他们的IP是184.154.*
再次更新:Test IP http://184.154.7.186/100mb.test
Pinging 184.154.7.186 with 32 bytes of data:
Reply from 184.154.7.186: bytes=32 time=359ms TTL=48
Reply from 184.154.7.186: bytes=32 time=377ms TTL=48
Reply from 184.154.7.186: bytes=32 time=390ms TTL=48
Ping statistics for 184.154.7.186:
    Minimum = 359ms, Maximum = 390ms, Average = 371ms
Tracing route to 5.ovz.chicago.123systems.net [184.154.7.186]
over a maximum of 30 hops:
  1     *        *        *     Request timed out.
  2    80 ms    26 ms    26 ms  218.58.84.1
  3    26 ms    27 ms    24 ms  124.129.249.53
  4    24 ms    22 ms    48 ms  119.167.86.1
  5    38 ms    41 ms    52 ms  219.158.12.1
  6    36 ms    37 ms    38 ms  219.158.3.226
  7   287 ms   293 ms   287 ms  219.158.29.222
  8   291 ms   293 ms   297 ms  xe-4-0-2.ar2.sjc1.us.nlayer.net [69.22.153.145]
  9   222 ms   221 ms   221 ms  ae0-50g.cr1.sjc1.us.nlayer.net [69.22.143.117]
10   230 ms   225 ms   237 ms  ae1-40g.cr1.pao1.us.nlayer.net [69.22.143.166]
11   225 ms   216 ms   214 ms  ae1-30g.cr1.sfo1.us.nlayer.net [69.22.143.169]
12   244 ms   241 ms   248 ms  te1-1.ar1.slc1.us.nlayer.net [69.22.142.96]
13   281 ms   278 ms   273 ms  xe-2-1-0.cr1.ord1.us.nlayer.net [69.22.142.101]
14   342 ms     *      329 ms  ae1-20g.ar1.ord6.us.nlayer.net [69.31.110.250]
15   310 ms   433 ms   412 ms  as32475.xe-1-0-1.ar1.ord6.us.nlayer.net [69.31.1
11.30]
16     *      329 ms   320 ms  aswg-ed112.ord03.singlehop.net [173.236.0.238]
17   367 ms   357 ms   462 ms  5.ovz.chicago.123systems.net [184.154.7.186]
Trace complete.
[ 本帖最后由 insraq 于 2010-9-2 13:22 编辑 ]
发表于 2010-9-2 12:52:49 | 只看该作者
  buyvm..........
发表于 2010-9-2 12:52:57 | 只看该作者
便宜不是好事
发表于 2010-9-2 12:57:03 | 只看该作者
备注里面提到
  1. lowendbox
会再给你增加128M内存吧
 楼主| 发表于 2010-9-2 13:00:00 | 只看该作者
原帖由 WAKAKA 于 2010-9-2 12:57 发表
备注里面提到lowendbox会再给你增加128M内存吧
原来的那个Offer会,现在这个不会的,这是WHT的Offer
 楼主| 发表于 2010-9-2 13:07:49 | 只看该作者
经过优化的Debian + Lighttpd + PHP + MySQL只占用了26M的内存,机器也是Singlehop机房的。他们机房的配置不错,但是磁盘I/O一般。
  1. root@server:~# free
  2.              total       used       free     shared    buffers     cached
  3. Mem:        393216      26368     366848          0          0          0
  4. -/+ buffers/cache:      26368     366848
  5. Swap:            0          0          0
[ 本帖最后由 insraq 于 2010-9-2 13:09 编辑 ]
发表于 2010-9-2 13:09:54 | 只看该作者
这么快就买了
发表于 2010-9-2 13:11:55 | 只看该作者
给个IP测试一下。
 楼主| 发表于 2010-9-2 13:14:05 | 只看该作者
原帖由 edmin 于 2010-9-2 13:09 发表
这么快就买了
我没买,这是另一个Singlehop的服务器,同样的机器配置,供参考。
 楼主| 发表于 2010-9-2 13:18:29 | 只看该作者
回复 8# 的帖子
GMT+8, 2026-4-21 15:50 , Processed in 0.061739 second(s), 10 queries , Gzip On, MemCache On.
