查看: 2266|回复: 8
[Windows VPS] Crazy Domains说我的Address Verification Error,怎么办?
发表于 2014-12-29 12:33:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
收到个邮件:
Hello Yang,
We were unable to verify the accuracy of your given address.
Why does my address need to be correct?
Due to the WHOIS Accuracy Program specifications imposed by ICANN's Registrar Accreditation Agreement, we are required to verify the accuracy of your address. Details of this specification can be viewed here. If you do not provide a valid address, then you are at risk of losing any domains registered with the invalid address.
How to proceed?
You can update your address by clicking here. If your address is correct, you can reply to this email with an item to prove to address is correct. Our staff will then manually verify that the address is correct.
Need help?
If you have any enquiries, please do not hesitate to contact our friendly customer support team who are available 24/7 to assist you. Call 1300 210 210
我按身份证的地址翻译过去的,还是提示这个,这个要紧吗?
发表于 2014-12-29 12:36:48 | 只看该作者
我英文 拼音改了几次都不行,后来给他回复邮件,附上中文地址,然后就过了
发表于 2014-12-29 12:38:12 来自手机 | 只看该作者
一定要理会啊!不理会后果严重
发表于 2014-12-29 12:39:36 | 只看该作者
他的验证系统很BT,我正确的地址死活不让过,找了个别人的地址就过了,这算啥事啊。。。
发表于 2014-12-29 12:46:58 | 只看该作者
这家注册有什么好处?
发表于 2014-12-29 15:58:38 | 只看该作者
我直接回复了个身份证扫描件 就通过了!!
 楼主| 发表于 2014-12-29 16:33:33 | 只看该作者
谢谢,我也照您的方法,回复了身份证扫描件,收到邮件:
You should no longer received Address Verification emails as your Member Account details have been updated and verified.
应该是通过了吧?
发表于 2014-12-29 16:35:19 | 只看该作者
You should no longer received Address Verific ...
是的,已经verified
发表于 2014-12-29 16:37:35 | 只看该作者
是的!!
GMT+8, 2026-4-16 12:15 , Processed in 0.301551 second(s), 13 queries , Gzip On, MemCache On.
