查看: 9245|回复: 43
请教10W ip 的wp站如何优化mysql
发表于 2014-12-9 18:38:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
现在用的16G linode vps。wp站。5W多文章。负载有些大。请教该如何优化mysql。
vps装的是军哥的lnmp。已安装memcached和wp super cache。
# Example MySQL config file for medium systems.
# This is for a system with little memory (32M - 64M) where MySQL plays
# an important part, or systems up to 128M where MySQL is used together with
# other programs (such as a web server)
# MySQL programs look for option files in a set of
# locations which depend on the deployment platform.
# You can copy this option file to one of those
# locations. For information about these locations, see:
# http://dev.mysql.com/doc/mysql/en/option-files.html
# In this file, you can use all long options that a program supports.
# If you want to know which options a program supports, run the program
# with the "--help" option.
# The following options will be passed to all MySQL clients
[client]
#password       = your_password
port            = 3306
socket          = /tmp/mysql.sock
# Here follows entries for some specific programs
# The MySQL server
[mysqld]
port            = 3306
datadir = /usr/local/mysql/var
skip-external-locking
query_cache_limit = 4M
query_cache_min_res_unit = 4k
key_buffer_size = 2048M
max_allowed_packet = 16M
table_open_cache = 4096
sort_buffer_size = 512K
net_buffer_length = 8K
read_buffer_size = 256K
read_rnd_buffer_size = 512K
myisam_sort_buffer_size = 8M
# Don't listen on a TCP/IP port at all. This can be a security enhancement,
# if all processes that need to connect to mysqld run on the same host.
# All interaction with mysqld must be made via Unix sockets or named pipes.
# Note that using this option without enabling named pipes on Windows
# (via the "enable-named-pipe" option) will render mysqld useless!
#skip-networking
# Replication Master Server (default)
# binary logging is required for replication
log-bin=mysql-bin
# binary logging format - mixed recommended
binlog_format=mixed
# required unique id between 1 and 2^32 - 1
# defaults to 1 if master-host is not set
# but will not function as a master if omitted
server-id       = 1
# Replication Slave (comment out master section to use this)
# To configure this host as a replication slave, you can choose between
# two methods :
# 1) Use the CHANGE MASTER TO command (fully described in our manual) -
#    the syntax is:
#    CHANGE MASTER TO MASTER_HOST=<host>, MASTER_PORT=<port>,
#    MASTER_USER=<user>, MASTER_PASSWORD=<password> ;
#    where you replace <host>, <user>, <password> by quoted strings and
#    <port> by the master's port number (3306 by default).
#    Example:
#    CHANGE MASTER TO MASTER_HOST='125.564.12.1', MASTER_PORT=3306,
#    MASTER_USER='joe', MASTER_PASSWORD='secret';
# OR
# 2) Set the variables below. However, in case you choose this method, then
#    start replication for the first time (even unsuccessfully, for example
#    if you mistyped the password in master-password and the slave fails to
#    connect), the slave will create a master.info file, and any later
#    change in this file to the variables' values below will be ignored and
#    overridden by the content of the master.info file, unless you shutdown
#    the slave server, delete master.info and restart the slaver server.
#    For that reason, you may want to leave the lines below untouched
#    (commented) and instead use CHANGE MASTER TO (see above)
# required unique id between 2 and 2^32 - 1
# (and different from the master)
# defaults to 2 if master-host is set
# but will not function as a slave if omitted
#server-id       = 2
# The replication master for this slave - required
#master-host     =   <hostname>
# The username the slave will use for authentication when connecting
# to the master - required
#master-user     =   <username>
# The password the slave will authenticate with when connecting to
# the master - required
#master-password =   <password>
# The port the master is listening on.
# optional - defaults to 3306
#master-port     =  <port>
# binary logging - not required for slaves, but recommended
# Uncomment the following if you are using InnoDB tables
innodb_data_home_dir = /usr/local/mysql/var
innodb_data_file_path = ibdata1:10M:autoextend
innodb_log_group_home_dir = /usr/local/mysql/var
# You can set .._buffer_pool_size up to 50 - 80 %
# of RAM but beware of setting memory usage too high
init_connect='SET autocommit=0'
innodb_buffer_pool_size = 2048M
innodb_additional_mem_pool_size = 16M
# Set .._log_file_size to 25 % of buffer pool size
innodb_log_file_size = 8M
innodb_log_buffer_size = 8M
innodb_flush_log_at_trx_commit = 0
innodb_lock_wait_timeout = 50
[mysqldump]
quick
[mysql]
no-auto-rehash
# Remove the next comment character if you are not familiar with SQL
#safe-updates
[myisamchk]
key_buffer_size = 20M
sort_buffer_size = 20M
read_buffer = 2M
write_buffer = 2M
[mysqlhotcopy]
interactive-timeout
发表于 2014-12-9 21:43:42 | 只看该作者
16G内存用medium ,你还真够省的……
直接上HHVM
发表于 2014-12-9 19:42:22 | 只看该作者
内存真多, 其实用不完, 这个量级2G内存就够了.
友情送你个卖站之前的配置吧, 主要还是WP还是得靠缓存, 什么都拿内存顶, mysql差不多就行了.
  1. [mysqld]
  2. port            = 3306
  3. socket          = /tmp/mysql.sock
  4. interactive_timeout = 30
  5. wait_timeout = 60
  6. connect_timeout = 60
  7. ft_min_word_len=2
  8. default-storage-engine=MyISAM
  9. skip-innodb
  10. ;skip-locking
  11. skip-name-resolve
  12. low-priority-updates
  13. key_buffer_size = 192M
  14. sort_buffer_size = 6M
  15. read_buffer_size = 4M
  16. read_rnd_buffer_size = 4M
  17. join_buffer_size = 3M
  18. table_cache = 2560
  19. table_definition_cache = 512
  20. max_connections = 500
  21. max_join_size = 4294967295
  22. myisam_sort_buffer_size = 4M
  23. thread_cache = 32
  24. thread_cache_size = 256
  25. query_cache_limit= 8M
  26. query_cache_size = 128M
  27. query_cache_type = 1
  28. max_connect_errors= 50
  29. max_allowed_packet= 16M
  30. tmp_table_size = 384M
  31. net_buffer_length = 32768
  32. slow_query_log = 1
  33. log-queries-not-using-indexes = 0
  34. slow_query_log_file = /tmp/slowquery.log
  35. general_log = 0
  36. general_log_file = /tmp/mysql.log
  37. # Try number of CPU's*2 for thread_concurrency
  38. thread_concurrency = 12
不要问我为什么这么配. 当然这个参数也是针对当时2G内存的机器配的, 你16G的话, 参数意思自己研究修改下吧.
流量比较厉害,这站能卖到 6位数么?  发表于 2014-12-10 09:51
发表于 2014-12-9 18:54:28 | 只看该作者
wdfsinap 发表于 2014-12-9 18:51
已经用了wp super cache了。还是不行。文章有图片的
wp super cache 假静态没意义!用cos-html-cache!图片静态不了-反正都只是调用-不浪费资源-
发表于 2014-12-9 18:41:45 | 只看该作者
你用PMA看一下MySQL的状态如何。
发表于 2014-12-9 18:47:01 | 只看该作者
简单-静态化!1G内存 跑3个2W文章的WP 没压力-静态化之后-什么都是浮云!
 楼主| 发表于 2014-12-9 18:48:18 | 只看该作者
mysql 状态:
Variable_name                            | Value       |
| Aborted_clients                          | 0           |
| Aborted_connects                         | 0           |
| Binlog_cache_disk_use                    | 0           |
| Binlog_cache_use                         | 275         |
| Binlog_stmt_cache_disk_use               | 0           |
| Binlog_stmt_cache_use                    | 0           |
| Bytes_received                           | 137         |
| Bytes_sent                               | 183         |
| Com_admin_commands                       | 0           |
| Com_assign_to_keycache                   | 0           |
| Com_alter_db                             | 0           |
| Com_alter_db_upgrade                     | 0           |
| Com_alter_event                          | 0           |
| Com_alter_function                       | 0           |
| Com_alter_procedure                      | 0           |
| Com_alter_server                         | 0           |
| Com_alter_table                          | 0           |
| Com_alter_tablespace                     | 0           |
| Com_analyze                              | 0           |
| Com_begin                                | 0           |
| Com_binlog                               | 0           |
| Com_call_procedure                       | 0           |
| Com_change_db                            | 0           |
| Com_change_master                        | 0           |
| Com_check                                | 0           |
| Com_checksum                             | 0           |
| Com_commit                               | 0           |
| Com_create_db                            | 0           |
| Com_create_event                         | 0           |
| Com_create_function                      | 0           |
| Com_create_index                         | 0           |
| Com_create_procedure                     | 0           |
| Com_create_server                        | 0           |
| Com_create_table                         | 0           |
| Com_create_trigger                       | 0           |
| Com_create_udf                           | 0           |
| Com_create_user                          | 0           |
| Com_create_view                          | 0           |
| Com_dealloc_sql                          | 0           |
| Com_delete                               | 0           |
| Com_delete_multi                         | 0           |
| Com_do                                   | 0           |
| Com_drop_db                              | 0           |
| Com_drop_event                           | 0           |
| Com_drop_function                        | 0           |
| Com_drop_index                           | 0           |
| Com_drop_procedure                       | 0           |
| Com_drop_server                          | 0           |
| Com_drop_table                           | 0           |
| Com_drop_trigger                         | 0           |
| Com_drop_user                            | 0           |
| Com_drop_view                            | 0           |
| Com_empty_query                          | 0           |
| Com_execute_sql                          | 0           |
| Com_flush                                | 0           |
| Com_grant                                | 0           |
| Com_ha_close                             | 0           |
| Com_ha_open                              | 0           |
| Com_ha_read                              | 0           |
| Com_help                                 | 0           |
| Com_insert                               | 0           |
| Com_insert_select                        | 0           |
| Com_install_plugin                       | 0           |
| Com_kill                                 | 0           |
| Com_load                                 | 0           |
| Com_lock_tables                          | 0           |
| Com_optimize                             | 0           |
| Com_preload_keys                         | 0           |
| Com_prepare_sql                          | 0           |
| Com_purge                                | 0           |
| Com_purge_before_date                    | 0           |
| Com_release_savepoint                    | 0           |
| Com_rename_table                         | 0           |
| Com_rename_user                          | 0           |
| Com_repair                               | 0           |
| Com_replace                              | 0           |
| Com_replace_select                       | 0           |
| Com_reset                                | 0           |
| Com_resignal                             | 0           |
| Com_revoke                               | 0           |
| Com_revoke_all                           | 0           |
| Com_rollback                             | 0           |
| Com_rollback_to_savepoint                | 0           |
| Com_savepoint                            | 0           |
| Com_select                               | 1           |
| Com_set_option                           | 0           |
| Com_signal                               | 0           |
| Com_show_authors                         | 0           |
| Com_show_binlog_events                   | 0           |
| Com_show_binlogs                         | 0           |
| Com_show_charsets                        | 0           |
| Com_show_collations                      | 0           |
| Com_show_contributors                    | 0           |
| Com_show_create_db                       | 0           |
| Com_show_create_event                    | 0           |
| Com_show_create_func                     | 0           |
| Com_show_create_proc                     | 0           |
| Com_show_create_table                    | 0           |
| Com_show_create_trigger                  | 0           |
| Com_show_databases                       | 0           |
| Com_show_engine_logs                     | 0           |
| Com_show_engine_mutex                    | 0           |
| Com_show_engine_status                   | 0           |
| Com_show_events                          | 0           |
| Com_show_errors                          | 0           |
| Com_show_fields                          | 0           |
| Com_show_function_status                 | 0           |
| Com_show_grants                          | 0           |
| Com_show_keys                            | 0           |
| Com_show_master_status                   | 0           |
| Com_show_open_tables                     | 0           |
| Com_show_plugins                         | 0           |
| Com_show_privileges                      | 0           |
| Com_show_procedure_status                | 0           |
| Com_show_processlist                     | 0           |
| Com_show_profile                         | 0           |
| Com_show_profiles                        | 0           |
| Com_show_relaylog_events                 | 0           |
| Com_show_slave_hosts                     | 0           |
| Com_show_slave_status                    | 0           |
| Com_show_status                          | 1           |
| Com_show_storage_engines                 | 0           |
| Com_show_table_status                    | 0           |
| Com_show_tables                          | 0           |
| Com_show_triggers                        | 0           |
| Com_show_variables                       | 0           |
| Com_show_warnings                        | 0           |
| Com_slave_start                          | 0           |
| Com_slave_stop                           | 0           |
| Com_stmt_close                           | 0           |
| Com_stmt_execute                         | 0           |
| Com_stmt_fetch                           | 0           |
| Com_stmt_prepare                         | 0           |
| Com_stmt_reprepare                       | 0           |
| Com_stmt_reset                           | 0           |
| Com_stmt_send_long_data                  | 0           |
| Com_truncate                             | 0           |
| Com_uninstall_plugin                     | 0           |
| Com_unlock_tables                        | 0           |
| Com_update                               | 0           |
| Com_update_multi                         | 0           |
| Com_xa_commit                            | 0           |
| Com_xa_end                               | 0           |
| Com_xa_prepare                           | 0           |
| Com_xa_recover                           | 0           |
| Com_xa_rollback                          | 0           |
| Com_xa_start                             | 0           |
| Compression                              | OFF         |
| Connections                              | 8513        |
| Created_tmp_disk_tables                  | 0           |
| Created_tmp_files                        | 5           |
| Created_tmp_tables                       | 0           |
| Delayed_errors                           | 0           |
| Delayed_insert_threads                   | 0           |
| Delayed_writes                           | 0           |
| Flush_commands                           | 1           |
| Handler_commit                           | 0           |
| Handler_delete                           | 0           |
| Handler_discover                         | 0           |
| Handler_prepare                          | 0           |
| Handler_read_first                       | 0           |
| Handler_read_key                         | 0           |
| Handler_read_last                        | 0           |
 楼主| 发表于 2014-12-9 18:50:04 | 只看该作者
| Handler_read_next                        | 0           |
| Handler_read_prev                        | 0           |
| Handler_read_rnd                         | 0           |
| Handler_read_rnd_next                    | 0           |
| Handler_rollback                         | 0           |
| Handler_savepoint                        | 0           |
| Handler_savepoint_rollback               | 0           |
| Handler_update                           | 0           |
| Handler_write                            | 0           |
| Innodb_buffer_pool_pages_data            | 826         |
| Innodb_buffer_pool_bytes_data            | 13533184    |
| Innodb_buffer_pool_pages_dirty           | 4           |
| Innodb_buffer_pool_bytes_dirty           | 65536       |
| Innodb_buffer_pool_pages_flushed         | 900         |
| Innodb_buffer_pool_pages_free            | 130211      |
| Innodb_buffer_pool_pages_misc            | 34          |
| Innodb_buffer_pool_pages_total           | 131071      |
| Innodb_buffer_pool_read_ahead_rnd        | 0           |
| Innodb_buffer_pool_read_ahead            | 0           |
| Innodb_buffer_pool_read_ahead_evicted    | 0           |
| Innodb_buffer_pool_read_requests         | 31343668    |
| Innodb_buffer_pool_reads                 | 823         |
| Innodb_buffer_pool_wait_free             | 0           |
| Innodb_buffer_pool_write_requests        | 3962        |
| Innodb_data_fsyncs                       | 1612        |
| Innodb_data_pending_fsyncs               | 0           |
| Innodb_data_pending_reads                | 0           |
| Innodb_data_pending_writes               | 0           |
| Innodb_data_read                         | 17764352    |
| Innodb_data_reads                        | 961         |
| Innodb_data_writes                       | 2376        |
| Innodb_data_written                      | 30331904    |
| Innodb_dblwr_pages_written               | 900         |
| Innodb_dblwr_writes                      | 128         |
| Innodb_have_atomic_builtins              | ON          |
| Innodb_log_waits                         | 0           |
| Innodb_log_write_requests                | 305         |
| Innodb_log_writes                        | 1228        |
| Innodb_os_log_fsyncs                     | 1354        |
| Innodb_os_log_pending_fsyncs             | 0           |
| Innodb_os_log_pending_writes             | 0           |
| Innodb_os_log_written                    | 775680      |
| Innodb_page_size                         | 16384       |
| Innodb_pages_created                     | 4           |
| Innodb_pages_read                        | 822         |
| Innodb_pages_written                     | 900         |
| Innodb_row_lock_current_waits            | 0           |
| Innodb_row_lock_time                     | 0           |
| Innodb_row_lock_time_avg                 | 0           |
| Innodb_row_lock_time_max                 | 0           |
| Innodb_row_lock_waits                    | 0           |
| Innodb_rows_deleted                      | 5           |
| Innodb_rows_inserted                     | 11          |
| Innodb_rows_read                         | 34362189    |
| Innodb_rows_updated                      | 259         |
| Innodb_truncated_status_writes           | 0           |
| Key_blocks_not_flushed                   | 0           |
| Key_blocks_unused                        | 1714736     |
| Key_blocks_used                          | 0           |
| Key_read_requests                        | 0           |
| Key_reads                                | 0           |
| Key_write_requests                       | 0           |
| Key_writes                               | 0           |
| Last_query_cost                          | 0.000000    |
| Max_used_connections                     | 8           |
| Not_flushed_delayed_rows                 | 0           |
| Open_files                               | 20          |
| Open_streams                             | 0           |
| Open_table_definitions                   | 42          |
| Open_tables                              | 53          |
| Opened_files                             | 67823       |
| Opened_table_definitions                 | 0           |
| Opened_tables                            | 0           |
| Performance_schema_cond_classes_lost     | 0           |
| Performance_schema_cond_instances_lost   | 0           |
| Performance_schema_file_classes_lost     | 0           |
| Performance_schema_file_handles_lost     | 0           |
| Performance_schema_file_instances_lost   | 0           |
| Performance_schema_locker_lost           | 0           |
| Performance_schema_mutex_classes_lost    | 0           |
| Performance_schema_mutex_instances_lost  | 0           |
| Performance_schema_rwlock_classes_lost   | 0           |
| Performance_schema_rwlock_instances_lost | 0           |
| Performance_schema_table_handles_lost    | 0           |
| Performance_schema_table_instances_lost  | 0           |
| Performance_schema_thread_classes_lost   | 0           |
| Performance_schema_thread_instances_lost | 0           |
| Prepared_stmt_count                      | 0           |
| Qcache_free_blocks                       | 0           |
| Qcache_free_memory                       | 0           |
| Qcache_hits                              | 0           |
| Qcache_inserts                           | 0           |
| Qcache_lowmem_prunes                     | 0           |
| Qcache_not_cached                        | 0           |
| Qcache_queries_in_cache                  | 0           |
| Qcache_total_blocks                      | 0           |
| Queries                                  | 555985      |
| Questions                                | 2           |
| Rpl_status                               | AUTH_MASTER |
| Select_full_join                         | 0           |
| Select_full_range_join                   | 0           |
| Select_range                             | 0           |
| Select_range_check                       | 0           |
| Select_scan                              | 0           |
| Slave_heartbeat_period                   | 0.000       |
| Slave_open_temp_tables                   | 0           |
| Slave_received_heartbeats                | 0           |
| Slave_retried_transactions               | 0           |
| Slave_running                            | OFF         |
| Slow_launch_threads                      | 0           |
| Slow_queries                             | 0           |
| Sort_merge_passes                        | 0           |
| Sort_range                               | 0           |
| Sort_rows                                | 0           |
| Sort_scan                                | 0           |
| Ssl_accept_renegotiates                  | 0           |
| Ssl_accepts                              | 0           |
| Ssl_callback_cache_hits                  | 0           |
| Ssl_cipher                               |             |
| Ssl_cipher_list                          |             |
| Ssl_client_connects                      | 0           |
| Ssl_connect_renegotiates                 | 0           |
| Ssl_ctx_verify_depth                     | 0           |
| Ssl_ctx_verify_mode                      | 0           |
| Ssl_default_timeout                      | 0           |
| Ssl_finished_accepts                     | 0           |
| Ssl_finished_connects                    | 0           |
| Ssl_session_cache_hits                   | 0           |
| Ssl_session_cache_misses                 | 0           |
| Ssl_session_cache_mode                   | NONE        |
| Ssl_session_cache_overflows              | 0           |
| Ssl_session_cache_size                   | 0           |
| Ssl_session_cache_timeouts               | 0           |
| Ssl_sessions_reused                      | 0           |
| Ssl_used_session_cache_entries           | 0           |
| Ssl_verify_depth                         | 0           |
| Ssl_verify_mode                          | 0           |
| Ssl_version                              |             |
| Table_locks_immediate                    | 531476      |
| Table_locks_waited                       | 0           |
| Tc_log_max_pages_used                    | 0           |
| Tc_log_page_size                         | 0           |
| Tc_log_page_waits                        | 0           |
| Threads_cached                           | 0           |
| Threads_connected                        | 7           |
| Threads_created                          | 8512        |
| Threads_running                          | 1           |
| Uptime                                   | 1239        |
| Uptime_since_flush_status                | 1239        |
 楼主| 发表于 2014-12-9 18:51:53 | 只看该作者
 楼主| 发表于 2014-12-9 18:53:51 | 只看该作者
opelnic 发表于 2014-12-9 18:41
你用PMA看一下MySQL的状态如何。
请问改如何优化
发表于 2014-12-9 18:59:10 | 只看该作者
w3tc 也不错。
GMT+8, 2026-4-15 13:45 , Processed in 0.076672 second(s), 14 queries , Gzip On, MemCache On.
