查看: 5898|回复: 18
[Windows VPS] KT的新加坡云服务器带宽很小啊!
发表于 2014-11-12 17:52:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
买了测试
  1. root@debian:~# wget -O /dev/null http://cachefly.cachefly.net/100mb.test
  2. --2014-11-12 01:38:29--  http://cachefly.cachefly.net/100mb.test
  3. Resolving cachefly.cachefly.net (cachefly.cachefly.net)... 205.234.175.175
  4. Connecting to cachefly.cachefly.net (cachefly.cachefly.net)|205.234.175.175|:80... connected.
  5. HTTP request sent, awaiting response... 200 OK
  6. Length: 104857600 (100M) [application/octet-stream]
  7. Saving to: `/dev/null'
  8. 100%[=====================================================================================================================================================>] 104,857,600 2.69M/s   in 39s
  9. 2014-11-12 01:39:09 (2.58 MB/s) - `/dev/null' saved [104857600/104857600]
  1. root@debian:~# wget https://dl.dropboxusercontent.com/u/3052739/files/shell/bench.sh -O - -o /dev/null|bash
  2. CPU model :  Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz
  3. Number of cores : 1
  4. CPU frequency :  2100.000 MHz
  5. Total amount of ram : 1002 MB
  6. Total amount of swap : 871 MB
  7. System uptime :   32 min,
  8. Download speed from CacheFly: 2.44MB/s
  9. Download speed from Coloat, Atlanta GA: 961KB/s
  10. Download speed from Softlayer, Dallas, TX: 1.78MB/s
  11. Download speed from Leaseweb, Haarlem, NL: 611KB/s
  12. Download speed from Softlayer, Singapore: 5.76MB/s
  13. Download speed from Softlayer, Seattle, WA: 2.34MB/s
  14. Download speed from Softlayer, San Jose, CA: 1.70MB/s
  15. Download speed from Softlayer, Washington, DC: 1.78MB/s
  16. I/O speed :  52.3 MB/s
  1. root@debian:/etc# speedtest-cli --share
  2. Retrieving speedtest.net configuration...
  3. Retrieving speedtest.net server list...
  4. Testing from VPLS Hosting (103.233.80.68)...
  5. Selecting best server based on latency...
  6. Hosted by CS LOXINFO (Bangkok) [148.42 km]: 30.973 ms
  7. Testing download speed........................................
  8. Download: 5.76 Mbits/s
  9. Testing upload speed..................................................
  10. Upload: 0.92 Mbits/s
  11. Share results: http://www.speedtest.net/result/3903120184.png
发表于 2014-11-12 17:56:38 | 只看该作者
最近很多人入驻,突然火了,带宽应该都开始限制了
发表于 2014-11-12 19:01:43 | 只看该作者
speedtest-cli多测试几次看看,貌似你那个Bangkok的节点不是最近的,距离148.42km,不知道与最近的有多大差异.....
发表于 2014-11-12 19:42:43 | 只看该作者
发表于 2014-11-12 20:59:44 | 只看该作者
[root@cs83dd75ad ~]# wget -O /dev/null http://cachefly.cachefly.net/100mb.test
--2014-11-12 20:59:27--  http://cachefly.cachefly.net/100mb.test
Resolving cachefly.cachefly.net... 205.234.175.175
Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
Saving to: 鈥?dev/null鈥
100%[======================================================================================================>] 104,857,600 14.0M/s   in 8.7s
发表于 2014-11-12 21:02:12 | 只看该作者
楼主你测测到国内的带宽呢:
  1. ./speedtest_cli.py --server 4672 --share
发表于 2014-11-12 21:14:39 | 只看该作者
带宽应该不小的,主要是流量贵!
 楼主| 发表于 2014-11-12 22:52:02 | 只看该作者
62900015 发表于 2014-11-12 21:02
楼主你测测到国内的带宽呢:
root@debian:~# speedtest-cli --server 4672 --share
Hosted by ChinaTelecom (Guangzhou) [1660.27 km]: 796.24 ms
Download: 6.92 Mbits/s
Upload: 0.43 Mbits/s
Share results: http://www.speedtest.net/result/3903737288.png
 楼主| 发表于 2014-11-12 22:53:43 | 只看该作者
--2014-11-12 20:59:27 ...
我刚才又跑了一次
--2014-11-12 06:53:54--  http://cachefly.cachefly.net/100mb.test
100%[=====================================================================================================================================================>] 104,857,600 2.69M/s   in 40s
2014-11-12 06:54:35 (2.48 MB/s) - `/dev/null' saved [104857600/104857600]
发表于 2014-11-12 23:04:55 | 只看该作者
你的ping 怎么这么高
GMT+8, 2026-5-2 03:46 , Processed in 0.076086 second(s), 13 queries , Gzip On, MemCache On.
