查看: 1833|回复: 6
[Windows VPS] 统计代码为何统计不到Google关键字?
发表于 2014-11-12 14:12:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有两个站,分别用51la和cnzz,有google搜索流量,但为何都统计不到google关键字?
发表于 2014-11-12 14:49:05 | 只看该作者
因为砖头吧
发表于 2014-11-12 14:52:26 来自手机 | 只看该作者
这个是谷歌自己的问题~~
发表于 2014-11-12 14:53:20 | 只看该作者
墙的原因吧?
发表于 2014-11-12 16:55:59 | 只看该作者
「Keyword not defined」 means the search engine did not pass to your website the keyword used by your visitors — Search engines hide the keyword for privacy reasons. It is common that most keywords are 「Not defined」 after Google changes made in early 2012.
Some search engines (Google for all logged in users, DuckDuckGo, Firefox latest version now also removes keywords, etc.) may not specify the keyword used to reach your website. The analytics tool will report the keyword as 「Keyword not defined」. It means that analytics tool has detected that the visitor came from a search engine, but the keyword was not provided in the Referrer URL.
There is no way to access the keyword in this case, and no other web analytics tool can get this information either.
 楼主| 发表于 2014-11-12 17:01:23 | 只看该作者
v998 发表于 2014-11-12 16:55
「Keyword not defined」 means the search engine did not pass to your website the keyword used by you ...
哦,不知道google自己的统计工具能统计到不
发表于 2014-11-12 17:33:08 | 只看该作者
你猜google会这样偏心吗?
不会统计到的, 死心吧...
GMT+8, 2026-4-28 18:55 , Processed in 0.120427 second(s), 12 queries , Gzip On, MemCache On.
