查看: 3573|回复: 4
[疑问] lnmp一键安装包没有liibmysqlclient.so.15,怎么办
发表于 2010-8-16 21:42:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
装了dovecot
发现log里说
Aug 16 21:06:57 dovecot: Info: Dovecot v1.2.13 starting up (core dumps disabled)
Aug 16 21:06:57 dovecot: Info: Generating Diffie-Hellman parameters for the first time. This may take a while..
Aug 16 21:06:57 dovecot: Error: child 17627 (auth) returned error 127
Aug 16 21:06:57 auth(default): Error: dovecot-auth: error while loading shared libraries: libmysqlclient.so.15: cannot open shared object file: No such file or directory
Aug 16 21:06:57 dovecot: Fatal: Auth process died too early - shutting down
然后  find / -name libmysqlclient*
/usr/local/mysql/lib/mysql/libmysqlclient_r.so
/usr/local/mysql/lib/mysql/libmysqlclient.so.16.0.0
/usr/local/mysql/lib/mysql/libmysqlclient_r.so.16.0.0
/usr/local/mysql/lib/mysql/libmysqlclient.la
/usr/local/mysql/lib/mysql/libmysqlclient_r.a
/usr/local/mysql/lib/mysql/libmysqlclient_r.la
/usr/local/mysql/lib/mysql/libmysqlclient.a
没有这个文件咋办
发表于 2010-8-16 21:47:20 | 只看该作者
难道不能yum一个?
发表于 2010-8-16 21:51:17 | 只看该作者
发表于 2010-8-16 21:58:08 | 只看该作者
听说hostgator一年能赚1200万美刀,额惊呆嘞,啥也不说,赶快进入idc行业,,,
发表于 2010-8-16 22:23:11 | 只看该作者
GMT+8, 2026-4-27 18:04 , Processed in 0.059961 second(s), 10 queries , Gzip On, MemCache On.
