查看: 2653|回复: 5
ramnode vps 说我发送ddos怎么回事?
发表于 2014-10-12 19:40:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Your VPS at 23.226.*.* appears to be sending out DoS attacks.
Please explain this activity to the best of your knowledge at your earliest availability.
我设置的很安全啊。只是装了wdcp,discuz,然后用了个扶墙一键安装,其他没做过设置。
我该怎么办?怎么回复他们?
发表于 2014-10-12 19:42:55 | 只看该作者
你自己看一下流量图,如果突然跑得很高就是很可能是DDOS
有可能是被黑了
发表于 2014-10-12 19:44:05 来自手机 | 只看该作者
wdcp前几天的洞没补被黑了吧
发表于 2014-10-12 20:01:20 | 只看该作者
LZ的WDCP不是最新版的
发表于 2014-10-12 20:07:55 | 只看该作者
hi support,
I only installed a control panel, and a discussion forum webapp on the vps.
I don't know why you are saying me sending out DoS attack.
Would you please login to my vps to check or solve the problem?
thank you
 楼主| 发表于 2014-10-12 20:26:08 | 只看该作者
v998 发表于 2014-10-12 20:07
hi support,
I don't kno ...
对 就这么说 谢谢大佬
GMT+8, 2026-5-2 17:17 , Processed in 0.061989 second(s), 10 queries , Gzip On, MemCache On.
