查看: 2851|回复: 4
选来选去,还是买了Photonvps
发表于 2010-8-12 02:20:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
机器倒是很强悍
入的BEAM 1
技术支持响应还挺快,待长期观察
   Version 5.1.2                      Based on the Byte Magazine Unix Benchmark
   Multi-CPU version                  Version 5 revisions by Ian Smith,
                                      Sunnyvale, CA, USA
   December 22, 2007                  johantheghost at yahoo period com
1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
1 x Execl Throughput  1 2 3
1 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
1 x File Copy 256 bufsize 500 maxblocks  1 2 3
1 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
1 x Process Creation  1 2 3
1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
1 x Shell Scripts (1 concurrent)  1 2 3
1 x Shell Scripts (8 concurrent)  1 2 3
8 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
8 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
8 x Execl Throughput  1 2 3
8 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
8 x File Copy 256 bufsize 500 maxblocks  1 2 3
8 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
8 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
8 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
8 x Process Creation  1 2 3
8 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
8 x Shell Scripts (1 concurrent)  1 2 3
8 x Shell Scripts (8 concurrent)  1 2 3
   BYTE UNIX Benchmarks (Version 5.1.2)
   System: www.ma-dou.net: GNU/Linux
   OS: GNU/Linux -- 2.6.18-164.10.1.el5.028stab067.4 -- #1 SMP Thu Jan 14 21:23:12 MSK 2010
   Machine: i686 (i386)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4522.1 bogomips)
          Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
   CPU 1: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4521.3 bogomips)
   CPU 2: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4521.4 bogomips)
   CPU 3: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4521.2 bogomips)
   CPU 4: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4521.4 bogomips)
   CPU 5: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4521.3 bogomips)
   CPU 6: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4521.3 bogomips)
   CPU 7: Intel(R) Xeon(R) CPU E5520 @ 2.27GHz (4521.4 bogomips)
   00:40:38 up  1:15,  1 user,  load average: 0.19, 0.24, 0.22; runlevel 3
Benchmark Run: Thu Aug 12 2010 00:40:38 - 01:24:10
8 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables        8631250.5 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     1941.8 MWIPS (10.1 s, 7 samples)
Execl Throughput                               3416.8 lps   (29.4 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        405050.2 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          123108.3 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1030629.1 KBps  (30.4 s, 2 samples)
Pipe Throughput                              828552.3 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  57608.8 lps   (10.0 s, 7 samples)
Process Creation                               9954.2 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4064.1 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1405.2 lpm   (60.0 s, 2 samples)
System Call Overhead                         737618.8 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0    8631250.5    739.6
Double-Precision Whetstone                       55.0       1941.8    353.1
Execl Throughput                                 43.0       3416.8    794.6
File Copy 1024 bufsize 2000 maxblocks          3960.0     405050.2   1022.9
File Copy 256 bufsize 500 maxblocks            1655.0     123108.3    743.9
File Copy 4096 bufsize 8000 maxblocks          5800.0    1030629.1   1776.9
Pipe Throughput                               12440.0     828552.3    666.0
Pipe-based Context Switching                   4000.0      57608.8    144.0
Process Creation                                126.0       9954.2    790.0
Shell Scripts (1 concurrent)                     42.4       4064.1    958.5
Shell Scripts (8 concurrent)                      6.0       1405.2   2341.9
System Call Overhead                          15000.0     737618.8    491.7
System Benchmarks Index Score                                         731.5
Benchmark Run: Thu Aug 12 2010 01:24:10 - 02:16:31
8 CPUs in system; running 8 parallel copies of tests
Dhrystone 2 using register variables       32109619.8 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                    14047.8 MWIPS (10.2 s, 7 samples)
Execl Throughput                              14106.2 lps   (29.3 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        943173.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          262050.1 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1945315.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                             3206064.1 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 925155.4 lps   (10.0 s, 7 samples)
Process Creation                              35382.1 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  12202.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   2018.6 lpm   (60.1 s, 2 samples)
System Call Overhead                        3130429.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   32109619.8   2751.5
Double-Precision Whetstone                       55.0      14047.8   2554.2
Execl Throughput                                 43.0      14106.2   3280.5
File Copy 1024 bufsize 2000 maxblocks          3960.0     943173.6   2381.8
File Copy 256 bufsize 500 maxblocks            1655.0     262050.1   1583.4
File Copy 4096 bufsize 8000 maxblocks          5800.0    1945315.4   3354.0
Pipe Throughput                               12440.0    3206064.1   2577.2
Pipe-based Context Switching                   4000.0     925155.4   2312.9
Process Creation                                126.0      35382.1   2808.1
Shell Scripts (1 concurrent)                     42.4      12202.9   2878.0
Shell Scripts (8 concurrent)                      6.0       2018.6   3364.3
System Call Overhead                          15000.0    3130429.7   2087.0
System Benchmarks Index Score                                        2607.2
======= Script description and score comparison: =======
http://www.ctohome.com/FuWuQi/c5/172.html
[ 本帖最后由 sense520 于 2010-8-12 02:29 编辑 ]
发表于 2010-8-12 04:14:02 | 只看该作者
线路最近很不错的
发表于 2010-8-14 12:17:03 | 只看该作者
观察一下
发表于 2010-8-14 12:27:57 | 只看该作者
最近线路似乎又有细微提速 不错
发表于 2010-8-16 22:56:40 | 只看该作者
原帖由 sense520 于 2010-8-12 02:20 发表
机器倒是很强悍
入的BEAM 1
技术支持响应还挺快,待长期观察
看起來OK 不錯
GMT+8, 2026-4-29 16:14 , Processed in 0.068941 second(s), 11 queries , Gzip On, MemCache On.
