查看: 5863|回复: 18
[疑问] 准备入手ECVPS,附unixbench测试,大家给点意见
发表于 2010-8-9 17:20:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
现在纠结于PHOTON和ecvps,大家给点意见
PHOTONVPS不知道怎么申请测试,如果有朋友买了的,放出来看下
最便宜的那款:ecvps1 网上报价70.80.90/月 的都有,跟他们QQ支持谈了下,还没定论,说是可以商量
初来乍到,第一次买国外的VPS。。多有不安,大家帮忙参考下咯
探针 http://173.244.208.57/p.php
unixbench
http://www.loc.qiche.eu.org/viewthread.php?tid=13593
   Version 5.1.2                      Based on the Byte Magazine Unix Benchmark
   Multi-CPU version                  Version 5 revisions by Ian Smith,
                                      Sunnyvale, CA, USA
   December 22, 2007                  johantheghost at yahoo period com
1 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
1 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
1 x Execl Throughput  1 2 3
1 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
1 x File Copy 256 bufsize 500 maxblocks  1 2 3
1 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
1 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
1 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
1 x Process Creation  1 2 3
1 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
1 x Shell Scripts (1 concurrent)  1 2 3
1 x Shell Scripts (8 concurrent)  1 2 3
4 x Dhrystone 2 using register variables  1 2 3 4 5 6 7 8 9 10
4 x Double-Precision Whetstone  1 2 3 4 5 6 7 8 9 10
4 x Execl Throughput  1 2 3
4 x File Copy 1024 bufsize 2000 maxblocks  1 2 3
4 x File Copy 256 bufsize 500 maxblocks  1 2 3
4 x File Copy 4096 bufsize 8000 maxblocks  1 2 3
4 x Pipe Throughput  1 2 3 4 5 6 7 8 9 10
4 x Pipe-based Context Switching  1 2 3 4 5 6 7 8 9 10
4 x Process Creation  1 2 3
4 x System Call Overhead  1 2 3 4 5 6 7 8 9 10
4 x Shell Scripts (1 concurrent)  1 2 3
4 x Shell Scripts (8 concurrent)  1 2 3
   BYTE UNIX Benchmarks (Version 5.1.2)
   System: 515805817: GNU/Linux
   OS: GNU/Linux -- 2.6.18-194.8.1.el5.028stab070.2 -- #1 SMP Tue Jul 6 14:55:39 MSD 2010
   Machine: i686 (i386)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU X3220 @ 2.40GHz (4788.1 bogomips)
          Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET, Intel virtualization
   CPU 1: Intel(R) Xeon(R) CPU X3220 @ 2.40GHz (4787.3 bogomips)
   CPU 2: Intel(R) Xeon(R) CPU X3220 @ 2.40GHz (4787.4 bogomips)
   CPU 3: Intel(R) Xeon(R) CPU X3220 @ 2.40GHz (4787.3 bogomips)
   22:05:03 up  2:41,  1 user,  load average: 0.08, 0.02, 0.01; runlevel 3
Benchmark Run: Sun Aug 08 2010 22:05:03 - 22:33:02
4 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       10539570.3 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2099.0 MWIPS (10.1 s, 7 samples)
Execl Throughput                               3679.4 lps   (29.8 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        387867.9 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          113794.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        765342.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                              683950.8 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 146264.4 lps   (10.0 s, 7 samples)
Process Creation                              11115.7 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4550.0 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1393.5 lpm   (60.0 s, 2 samples)
System Call Overhead                         568278.1 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   10539570.3    903.1
Double-Precision Whetstone                       55.0       2099.0    381.6
Execl Throughput                                 43.0       3679.4    855.7
File Copy 1024 bufsize 2000 maxblocks          3960.0     387867.9    979.5
File Copy 256 bufsize 500 maxblocks            1655.0     113794.9    687.6
File Copy 4096 bufsize 8000 maxblocks          5800.0     765342.4   1319.6
Pipe Throughput                               12440.0     683950.8    549.8
Pipe-based Context Switching                   4000.0     146264.4    365.7
Process Creation                                126.0      11115.7    882.2
Shell Scripts (1 concurrent)                     42.4       4550.0   1073.1
Shell Scripts (8 concurrent)                      6.0       1393.5   2322.5
System Call Overhead                          15000.0     568278.1    378.9
System Benchmarks Index Score                                         770.7
Benchmark Run: Sun Aug 08 2010 22:33:02 - 23:01:04
4 CPUs in system; running 4 parallel copies of tests
Dhrystone 2 using register variables       40100372.7 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     8336.0 MWIPS (10.2 s, 7 samples)
Execl Throughput                               8998.8 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        235529.7 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           79039.7 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        597779.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                             2677099.9 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 862521.7 lps   (10.0 s, 7 samples)
Process Creation                              24184.5 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                  11418.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1630.0 lpm   (60.1 s, 2 samples)
System Call Overhead                        1823984.7 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   40100372.7   3436.2
Double-Precision Whetstone                       55.0       8336.0   1515.6
Execl Throughput                                 43.0       8998.8   2092.7
File Copy 1024 bufsize 2000 maxblocks          3960.0     235529.7    594.8
File Copy 256 bufsize 500 maxblocks            1655.0      79039.7    477.6
File Copy 4096 bufsize 8000 maxblocks          5800.0     597779.4   1030.7
Pipe Throughput                               12440.0    2677099.9   2152.0
Pipe-based Context Switching                   4000.0     862521.7   2156.3
Process Creation                                126.0      24184.5   1919.4
Shell Scripts (1 concurrent)                     42.4      11418.2   2693.0
Shell Scripts (8 concurrent)                      6.0       1630.0   2716.7
System Call Overhead                          15000.0    1823984.7   1216.0
System Benchmarks Index Score                                        1585.8
======= Script description and score comparison: =======
[url]http://www.ctohome.com/FuWuQi/c5/172.html[/url
[ 本帖最后由 sense520 于 2010-8-9 17:32 编辑 ]
 楼主| 发表于 2010-8-9 17:22:12 | 只看该作者
发表于 2010-8-9 17:24:35 | 只看该作者
 楼主| 发表于 2010-8-9 17:31:28 | 只看该作者
本来还纠结linode,后来想想。。算了,那价格找个人都可以合租个国内的15M独享了。。
顺便问下,买国外的朋友难道都是做“那种”站的吗? 我是国内的换来换去实在找不到合适的,
国内的都是开始买的时候挺好,用的时间长了越来越抽疯~
发表于 2010-8-9 17:32:32 | 只看该作者
原帖由 hellowind 于 2010-8-9 17:24 发表
我纠结在VPSYOU和D9HOST中。。。。。。
 楼主| 发表于 2010-8-9 17:36:36 | 只看该作者
这两个貌似也不便宜哇。。不过vpsyou的首页我打开速度倒是飞快,汗。。
发表于 2010-8-9 19:23:38 | 只看该作者
VPSYOU不错,用了快半年了,一直很稳定,价格也不算贵
 楼主| 发表于 2010-8-9 20:06:38 | 只看该作者
vpsyou你买的什么价?
发表于 2010-8-9 22:57:49 | 只看该作者
回复 1# 的帖子
ECVPS从眼打开始用到现在,总体来说不错吧,我用的LNMP 平时内存 90-120M占用,我用的SL西雅图。其实只要遇到不错的VPS商家 OPENVZ不比XEN差!   我用的ECVPS2 = = 那个  2个IP  自己觉得好就行了,别人说什么无所谓.
另问:楼主用的手机是 AndRoid系统?
发表于 2010-8-9 23:16:51 | 只看该作者
UnixBench 挺火啊。
GMT+8, 2026-4-29 19:30 , Processed in 0.069737 second(s), 11 queries , Gzip On, MemCache On.
