查看: 12122|回复: 11
安装net_speeder出错,Unable to correct problems, you have held broken ?
发表于 2014-8-7 22:54:31 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
net_speeder.c:1:18: fatal error: pcap.h: No such file or directory
compilation terminated.
在apt-get install libnet1-dev 时报错,
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libnet1-dev : Depends: libc6-dev but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
应该怎么处理?
发表于 2014-8-7 22:56:18 | 只看该作者
第一行不是说的很清楚了吗?缺少pcap的头。
# apt-get libpcap-dev
 楼主| 发表于 2014-8-7 22:59:13 | 只看该作者
libpcap0.8-dev : Depends: libc6-dev but it is not going to be installed
怎么办呢?谢谢
发表于 2014-8-7 23:04:17 | 只看该作者
# apt-get install libc6-dev
 楼主| 发表于 2014-8-7 23:09:49 | 只看该作者
libc6-dev : Depends: libc6 (= 2.13-38+deb7u3) but 2.19-7 is to be installed
             Depends: libc-dev-bin (= 2.13-38+deb7u3) but it is not going to be installed
发表于 2014-8-7 23:09:58 | 只看该作者
这些协议 如果能换到windows下就爽歪歪了
发表于 2014-8-7 23:14:44 | 只看该作者
ubuntu不会自己搞定依赖库啊?
装个aptitude试试吧。
发表于 2014-8-7 23:17:54 | 只看该作者
# apt get install build-essential
发表于 2014-8-8 07:10:01 来自手机 | 只看该作者
发表于 2014-8-8 09:08:03 | 只看该作者
nginx  net_speeder  好像对dz论坛的附件支持不好。
GMT+8, 2026-4-14 15:19 , Processed in 0.133384 second(s), 13 queries , Gzip On, MemCache On.
