查看: 3340|回复: 8
有用Cloudmin作为面板的吗?
发表于 2010-8-2 20:54:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
有用Cloudmin作为面板的吗?
发表于 2010-8-2 21:00:05 | 只看该作者
关注
发表于 2010-8-2 21:06:52 | 只看该作者
What is Cloudmin?
It is a UI built on top of Webmin for managing virtual systems, such as Xen, KVM and OpenVZ instances. Using Cloudmin you can create, destroy, resize, startup, shutdown and restrict multiple instances using different virtualization technologies from a single interface. It also has a full command line API that can be used to manage virtual systems from a shell script or via HTTP requests.
Cloudmin is designed for use by VPS hosting companies that sell virtual systems to their customers, but is also suited for anyone who wants to get into virtualization for application management, testing, controlling a cluster of Virtualmin hosts, or just to learn about cloud computing.
Cloudmin supports additional logins called system owners, who can be given limited access to a subset of virtual systems, and can be restricted in the actions that they perform. Owners can have limits set on their disk, RAM and CPU usage that apply across all their virtual systems, either defined on a per-owner limit or from a plan.
我来上个课。
发表于 2010-8-2 21:07:40 | 只看该作者
学习下
发表于 2010-8-2 21:11:15 | 只看该作者
回复 3# 的帖子
l来成中文的啊
发表于 2010-8-2 21:13:21 | 只看该作者
看了一下,只支持Xen。
发表于 2010-8-2 21:45:56 | 只看该作者
瞧瞧去。。
发表于 2010-8-2 22:00:48 | 只看该作者
看不懂啊.XEN性能比openvz差太多了.
发表于 2010-8-2 22:16:41 | 只看该作者
原帖由 cnx 于 2010-8-2 21:13 发表
看了一下,只支持Xen。
不好
GMT+8, 2026-1-14 13:49 , Processed in 0.063005 second(s), 10 queries , Gzip On, MemCache On.
