查看: 2151|回复: 4
[Windows VPS] squid 配置问题 纠结很久了
发表于 2014-6-10 20:26:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
配置
visible_hostname 127.0.0.1
http_port 80 accel vhost vport
cache_mem 256 MB
maximum_object_size_in_memory 2048 KB
memory_replacement_policy lru
cache_dir ufs /var/spool/squid 20480 16 256
access_log /var/log/squid/access.log
max_open_disk_fds 0
minimum_object_size 0 KB
maximum_object_size 32768 KB
#logformat combined %>a %ui %un [%tl] "%rm %ru HTTP/%rv" %Hs %<st "%{Referer}>h""%{User-Agent}>h" %Ss:%Sh
cache_peer www.dj19.com parent 80 0 no-query no-query originserver
http_access allow all
cache_effective_user nobody
cache_effective_group nobody
cache_mgr zifu.199s0@163.com
#refresh_pattern ^ftp: 60 20% 10080
#refresh_pattern ^gopher: 60 0% 1440
#refresh_pattern . 0 20% 1440
refresh_pattern -i \.css$      360    50%    2880
refresh_pattern -i \.js$        1440    50%    2880
refresh_pattern -i \.html$      720    50%    1440
refresh_pattern -i \.jpg$      1440    90%    2880
refresh_pattern -i \.gif$      1440    90%    2880
refresh_pattern -i \.swf$      1440    90%    2880
refresh_pattern -i \.jpg$      1440    50%    2880
refresh_pattern -i \.png$      1440    50%    2880
refresh_pattern -i \.bmp$      1440    50%    2880
refresh_pattern -i \.doc$      1440    50%    2880
refresh_pattern -i \.ppt$      1440    50%    2880
refresh_pattern -i \.xls$      1440    50%    2880
refresh_pattern -i \.pdf$      1440    50%    2880
refresh_pattern -i \.rar$      1440    50%    2880
refresh_pattern -i \.zip$      1440    50%    2880
refresh_pattern -i \.txt$      1440    50%    2880
cache_peer www.dj19.com parent 80 0 no-query no-query originserver    后端如果是独立IP就可以   要是反别人的站就不行   0-0  望各位指点一下  谢谢
发表于 2014-6-10 20:35:00 | 只看该作者
你又冒充我出来鬼混
 楼主| 发表于 2014-6-10 20:35:29 | 只看该作者
采花大盗 发表于 2014-6-10 20:35
你又冒充我出来鬼混
你名字都是我注册的
发表于 2014-6-10 20:39:20 | 只看该作者
名字挺吸引人,我只看名字,不看头像
GMT+8, 2026-4-16 08:03 , Processed in 0.057930 second(s), 10 queries , Gzip On, MemCache On.
