查看: 1113|回复: 5
[Windows VPS] 为啥查询whois时会出现这些?
发表于 2014-5-12 15:41:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
查询 live.com
出现:
Whois Server Version 2.0
Domain names in the .com and .net domains can now be registered
with many different competing registrars. Go to http://www.internic.net
for detailed information.
LIVE.COM.IS.0WN3D.BY.GULLI.COM
LIVE.COM.IS.N0T.AS.1337.AS.GULLI.COM
LIVE.COM.ITS-NOT-ROCKET-SCIENCE-MR-RIKY-BLAIKIE.BURTYB.COM
LIVE.COM.ZZZ.GET.LAID.AT.WWW.SWINGINGCOMMUNITY.COM
LIVE.COM
To single out one record, look it up with "xxx", where xxx is one of the
records displayed above. If the records are the same, look them up
with "=xxx" to receive a full display for each record.
>>> Last update of whois database: Mon, 12 May 2014 07:40:23 UTC <<<
NOTICE: The expiration date displayed in this record is the date the
registrar's sponsorship of the domain name registration in the registry is
currently set to expire. This date does not necessarily reflect the expiration
date of the domain name registrant's agreement with the sponsoring
registrar.  Users may consult the sponsoring registrar's Whois database to
view the registrar's reported date of expiration for this registration.
TERMS OF USE: You are not authorized to access or query our Whois
database through the use of electronic processes that are high-volume and
automated except as reasonably necessary to register domain names or
modify existing registrations; the Data in VeriSign Global Registry
Services' ("VeriSign") Whois database is provided by VeriSign for
information purposes only, and to assist persons in obtaining information
about or related to a domain name registration record. VeriSign does not
guarantee its accuracy. By submitting a Whois query, you agree to abide
by the following terms of use: You agree that you may use this Data only
for lawful purposes and that under no circumstances will you use this Data
to: (1) allow, enable, or otherwise support the transmission of mass
unsolicited, commercial advertising or solicitations via e-mail, telephone,
or facsimile; or (2) enable high volume, automated, electronic processes
that apply to VeriSign (or its computer systems). The compilation,
repackaging, dissemination or other use of this Data is expressly
prohibited without the prior written consent of VeriSign. You agree not to
use electronic processes that are automated and high-volume to access or
query the Whois database except as reasonably necessary to register
domain names or modify existing registrations. VeriSign reserves the right
to restrict your access to the Whois database in its sole discretion to ensure
operational stability.  VeriSign may restrict or terminate your access to the
Whois database for failure to abide by these terms of use. VeriSign
reserves the right to modify these terms at any time.
The Registry database contains ONLY .COM, .NET, .EDU domains and
Registrars.
很多其他域名也这样,貌似比较牛的域名都这样……
发表于 2014-5-12 15:48:22 | 只看该作者
你的方法不对吧
注册商:CSC CORPORATE DOMAINS, INC.
域名服务器:whois.corporatedomains.com
DNS服务器:NS1.MSFT.NET
DNS服务器:NS2.MSFT.NET
DNS服务器:NS3.MSFT.NET
DNS服务器:NS4.MSFT.NET
DNS服务器:NS5.MSFT.NET
域名状态:运营商设置了客户禁止删除保护
域名状态:运营商设置了客户禁止转移保护
域名状态:运营商设置了客户禁止修改保护
域名状态:域名服务器上禁止删除保护
域名状态:域名服务器上禁止转移保护
域名状态:域名服务器上禁止修改保护
更新时间:2013年09月25日
创建时间:1994年12月28日
过期时间:2017年12月27日
联系人:: domain administrator
联系方式:
Domain Name: live.com
Registry Domain ID: 2344732_DOMAIN_COM-VRSN
Registrar WHOIS Server: whois.corporatedomains.com
Registrar URL: www.cscprotectsbrands.com
更新时间: 2013-11-27 04:20:48 -0500
Creation Date: 1994-12-28 00:00:00 -0500
Registrar Registration 过期时间: 2017-12-27 00:00:00 -0500
Registrar: CSC CORPORATE DOMAINS, INC.
Registrar IANA ID: 299
Registrar Abuse Contact Email:
Registrar Abuse Contact Phone: +1.8887802723
Domain 状态: serverTransferProhibited
Domain 状态: serverDeleteProhibited
Domain 状态: clientTransferProhibited
Domain 状态: clientUpdateProhibited
Domain 状态: clientDeleteProhibited
Domain 状态: serverUpdateProhibited
Registry Registrant ID:
Registrant Name: Domain Administrator
Registrant Organization: Microsoft Corporation
Registrant Street: One Microsoft Way
Registrant City: Redmond
Registrant State/Province: WA
Registrant Postal Code: 98052-6399
Registrant Country: US
Registrant Phone: 1--4258828080
Registrant Phone Ext:
Registrant Fax: 1--4259367329
Registrant Fax Ext:
Registrant Email:
Registry Admin ID:
Admin Name: Domain Administrator
Admin Organization: Microsoft Corporation
Admin Street: One Microsoft Way
Admin City: Redmond
Admin State/Province: WA
Admin Postal Code: 98052-6399
Admin Country: US
Admin Phone: 1--4258828080
Admin Phone Ext:
Admin Fax: 1--4259367329
Admin Fax Ext:
Admin Email:
Registry Tech ID:
Tech Name: MSN Hostmaster
Tech Organization: Microsoft Corporation
Tech Street: One Microsoft Way
Tech City: Redmond
Tech State/Province: WA
Tech Postal Code: 98052
Tech Country: US
Tech Phone: 1--4258828080
Tech Phone Ext:
Tech Fax: 1--4259367329
Tech Fax Ext:
Tech Email:
Name Server: ns2.msft.net
Name Server: ns4.msft.net
Name Server: ns3.msft.net
Name Server: ns5.msft.net
Name Server: ns1.msft.net
DNSSEC:
URL of the ICANN WHOIS Data Problem Reporting System: http://wdprs.internic.net/
>>> Last update of WHOIS database: 2013-11-27 04:20:48 -0500 <<<
发表于 2014-5-12 15:49:39 | 只看该作者
这个查询接口的差别,有些43port的好像
发表于 2014-5-12 15:51:22 | 只看该作者
 楼主| 发表于 2014-5-12 16:00:01 | 只看该作者
明白了
发表于 2014-5-12 16:21:58 | 只看该作者
GMT+8, 2026-4-30 18:20 , Processed in 0.059889 second(s), 7 queries , Gzip On, MemCache On.
