查看: 2798|回复: 5
[Windows VPS] LinODE来邮件了:Linode Alert - disk io rate - linode511248
发表于 2014-4-23 11:00:08 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Your Linode, linode511248, has exceeded the notification threshold (1000) for disk io rate by averaging 1290.18 for the last 2 hours. The dashboard for this specific Linode is located at: <https://manager.linode.com/linodes/dashboard/linode511248>;
This is an automated message, please do not respond to this email.  If you have questions, please open a support ticket.
You can view or change your alert thresholds under the "Settings" tab of the Linode Manager.
This is not meant as a warning or a representation that you are misusing your resources.  We encourage you to modify the thresholds based on your own individual needs.
You may access the members' site at <https://manager.linode.com/>;.
这种情况该如何处理呢?每天收到三份这样邮件,频繁这样会不会导致关停账户?
发表于 2014-4-23 11:06:23 | 只看该作者
io超过了1000
你可以后台调整高一点
一般别长期几十K就可以了
 楼主| 发表于 2014-4-23 11:10:22 | 只看该作者
设为8000了,没问题吧
发表于 2014-4-23 11:17:00 | 只看该作者
应该没问题吧,看你的提醒邮件,过去2小时的平均IO也就是1200多,只不过你的门限1000太低了~~
发表于 2014-4-23 11:52:14 | 只看该作者
我的一般在2,3百
如果长期高 一般是程序的问题
优化一下
GMT+8, 2026-4-15 19:22 , Processed in 0.061618 second(s), 10 queries , Gzip On, MemCache On.
