查看: 4037|回复: 19
[Windows VPS] Linode,LAMP环境,启动VPS后可以正常访问,过几分钟就不行了
发表于 2014-4-20 15:23:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
主机:Linode,
环境:LAMP环境,
网站程序:DZ
日IP:6000左右
刚启动VPS后可以正常访问,过几分钟就不行了,VPS服务器可以正常ping通,是什么原因呢?
发表于 2014-4-20 15:36:21 | 只看该作者
不正常后又反馈信息   查看反馈信息及日志信息
 楼主| 发表于 2014-4-20 15:57:45 | 只看该作者
截取了一段数据,太多了,才几天就有40M的LOG,vps是新买的。
110.181.169.143 - - [20/Apr/2014:14:19:44 +0800] "GET /attachments/month_1403/1403110940351a489790486ef4.jpg HTTP/1.1" 200 7980
118.26.176.3 - - [20/Apr/2014:14:19:44 +0800] "GET /images/BANKUAI/01.png HTTP/1.1" 200 2687
118.26.176.3 - - [20/Apr/2014:14:19:44 +0800] "GET /templates/jinlan/images/forum_new.gif HTTP/1.1" 404 201
110.181.169.143 - - [20/Apr/2014:14:19:44 +0800] "GET /plugins/ducexhome/images/ducebg.png HTTP/1.1" 200 7546
114.83.69.202 - - [20/Apr/2014:14:19:44 +0800] "GET /forumdata/cache/style_23_common.css?AaV HTTP/1.1" 304 -
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /plugins/ducexhome/cache/style_ducexhome_xhome_23.css?AaV HTTP/1.1" 200 2119
118.26.176.3 - - [20/Apr/2014:14:19:44 +0800] "GET /plugins/ducexhome/images/flashnum.gif HTTP/1.1" 200 174
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /templates/jinlan/images/bg.gif HTTP/1.1" 200 592
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /templates/jinlan/images/headerbg.gif HTTP/1.1" 200 305
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /templates/jinlan/images/header_right.gif HTTP/1.1" 200 9271
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /templates/jinlan/images/logo.gif HTTP/1.1" 200 12367
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /templates/jinlan/images/menu_bg.gif HTTP/1.1" 200 519
114.83.69.202 - - [20/Apr/2014:14:19:44 +0800] "GET /plugins/ducexhome/js/dicta.js?AaV HTTP/1.1" 200 3823
118.26.176.3 - - [20/Apr/2014:14:19:44 +0800] "GET /images/BANKUAI/17.png HTTP/1.1" 200 2797
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /templates/jinlan/images/menu_left.gif HTTP/1.1" 200 6497
110.181.169.143 - - [20/Apr/2014:14:19:44 +0800] "GET /images/default/collapsed_yes.gif HTTP/1.1" 200 61
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /templates/jinlan/images/menu_right.gif HTTP/1.1" 200 1066
121.231.72.19 - - [20/Apr/2014:14:19:44 +0800] "GET /images/default/arrow_down.gif HTTP/1.1" 200 51
110.181.169.143 - - [20/Apr/2014:14:19:44 +0800] "GET /images/BANKUAI/19.png HTTP/1.1" 200 2855
发表于 2014-4-20 15:59:08 | 只看该作者
top 看是不是php卡死了,建议尝试一下lnmp环境,apache跑php,小内存就要优化好。
求小内存优化方法. 谢谢  发表于 2014-4-20 20:04
 楼主| 发表于 2014-4-20 16:02:54 | 只看该作者
小夜 发表于 2014-4-20 15:59
top 看是不是php卡死了,建议尝试一下lnmp环境,apache跑php,小内存就要优化好。 ...
技术太菜,使用的是LAMP一键安装包。内存是2G的,按道理不至于这么容易歇菜啊
发表于 2014-4-20 16:38:22 | 只看该作者
无法访问的时候试试ssh登陆进去看看,负载,和组件运行状态。
上面的日志基本上都算正常的访问。
 楼主| 发表于 2014-4-20 16:48:24 | 只看该作者
上面的日志基本上都算正常的访问。 ...
一般用哪几个命令查询负载状况,求教~
top,只是用dz可以用nginx,负载能力比apache好。  发表于 2014-4-20 19:11
发表于 2014-4-20 16:56:30 | 只看该作者
pornograph 发表于 2014-4-20 16:48
一般用哪几个命令查询负载状况,求教~
用top吧,自动刷新。
 楼主| 发表于 2014-4-20 16:57:47 | 只看该作者
★Extreme★ 发表于 2014-4-20 16:56
用top吧,自动刷新。
谢谢
发表于 2014-4-20 17:15:53 | 只看该作者
可以用军哥的lnmp一键安装包啊,比较稳定的
GMT+8, 2026-4-28 17:14 , Processed in 0.069537 second(s), 11 queries , Gzip On, MemCache On.
