查看: 5405|回复: 9
[疑问] 【T楼评测】92cloud香港云主机评测
发表于 2014-1-20 17:13:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
云主机配置:1核CPU、1GB内存、20GB系统盘+20GB数据盘、3M独享带宽、1个独立公网IP。 赠送时长:1个月。¥128.00 CNY (月付)
香港 103.242.109.-  ,  说是BGP网络,chinaz ping测试,电信很快,其他线路有超时现象。
  1. root@qqq:~# dd if=/dev/zero of=test bs=64k count=4k conv=fdatasync && rm -f test
  2. 4096+0 records in
  3. 4096+0 records out
  4. 268435456 bytes (268 MB) copied, 3.14257 s, 85.4 MB/s
  5. root@qqq:~# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync && rm -f test
  6. 4096+0 records in
  7. 4096+0 records out
  8. 268435456 bytes (268 MB) copied, 22.7336 s, 11.8 MB/s
  9. root@qqq:~# wget http://cachefly.cachefly.net/100mb.test; rm -f 100mb.test
  10. --2014-01-20 16:53:18--  http://cachefly.cachefly.net/100mb.test
  11. Resolving cachefly.cachefly.net (cachefly.cachefly.net)... 205.234.175.175
  12. Connecting to cachefly.cachefly.net (cachefly.cachefly.net)|205.234.175.175|:80... connected.
  13. HTTP request sent, awaiting response... 200 OK
  14. Length: 104857600 (100M) [application/octet-stream]
  15. Saving to: `100mb.test'
  16. 5% [==>                                                           ] 5,970,056    346K/s  eta 3m 50s
  17. ^C
  18. root@qqq:~# top
  19. top - 16:54:46 up 8 min,  3 users,  load average: 0.00, 0.01, 0.02
  20. Tasks:  63 total,   1 running,  62 sleeping,   0 stopped,   0 zombie
  21. %Cpu(s):  0.3 us,  0.0 sy,  0.0 ni, 99.3 id,  0.3 wa,  0.0 hi,  0.0 si,  0.0 st
  22. KiB Mem:   1024452 total,    69304 used,   955148 free,     3028 buffers
  23. KiB Swap:  1048572 total,        0 used,  1048572 free,    28136 cached
  24.   PID USER      PR  NI  VIRT  RES  SHR S  %CPU %MEM    TIME+  COMMAND
  25. 2592 root      20   0 71296 3656 2764 S   0.3  0.4   0:00.12 sshd
  26.     1 root      20   0 10648  808  672 S   0.0  0.1   0:00.75 init
  27.     2 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kthreadd
  28.     3 root      20   0     0    0    0 S   0.0  0.0   0:00.02 ksoftirqd/0
  29.     5 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kworker/u:0
  30.     6 root      rt   0     0    0    0 S   0.0  0.0   0:00.00 migration/0
  31.     7 root      rt   0     0    0    0 S   0.0  0.0   0:00.00 watchdog/0
  32.     8 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 cpuset
  33.     9 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 khelper
  34.    10 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kdevtmpfs
  35.    11 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 netns
  36.    12 root      20   0     0    0    0 S   0.0  0.0   0:00.00 sync_supers
  37.    13 root      20   0     0    0    0 S   0.0  0.0   0:00.08 bdi-default
  38.    14 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 kintegrityd
  39.    15 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 kblockd
  40.    16 root      20   0     0    0    0 S   0.0  0.0   0:00.18 kworker/0:1
  41.    17 root      20   0     0    0    0 S   0.0  0.0   0:00.00 khungtaskd
  42.    18 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kswapd0
  43.    19 root      25   5     0    0    0 S   0.0  0.0   0:00.00 ksmd
  44.    20 root      39  19     0    0    0 S   0.0  0.0   0:00.00 khugepaged
  45.    21 root      20   0     0    0    0 S   0.0  0.0   0:00.00 fsnotify_mark
  46.    22 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 crypto
  47.    84 root      20   0     0    0    0 S   0.0  0.0   0:00.00 khubd
  48.   107 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 ata_sff
  49.   139 root      20   0     0    0    0 S   0.0  0.0   0:00.00 scsi_eh_0
  50.   142 root      20   0     0    0    0 S   0.0  0.0   0:00.00 scsi_eh_1
  51.   143 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kworker/u:1
  52.   151 root      20   0     0    0    0 S   0.0  0.0   0:00.00 vballoon
  53.   192 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kjournald
  54.   334 root      20   0 21376 1276  728 S   0.0  0.1   0:00.03 udevd
  55.   469 root      20   0 21372  920  372 S   0.0  0.1   0:00.00 udevd
  56.   470 root      20   0 21372  920  372 S   0.0  0.1   0:00.00 udevd
  57.   489 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 kpsmoused
  58.   490 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kworker/0:2
  59. 1365 root      20   0     0    0    0 S   0.0  0.0   0:00.00 kjournald
  60. 1656 root      20   0 18968  864  604 S   0.0  0.1   0:00.00 rpcbind
  61. 1687 statd     20   0 23340 1320  864 S   0.0  0.1   0:00.00 rpc.statd
  62. 1692 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 rpciod
  63. 1694 root       0 -20     0    0    0 S   0.0  0.0   0:00.00 nfsiod
  64. 1701 root      20   0 25288  424  208 S   0.0  0.0   0:00.00 rpc.idmapd
  65. 1823 root      20   0     0    0    0 S   0.0  0.0   0:00.00 flush-254:0
  66. 1827 root      20   0     0    0    0 S   0.0  0.0   0:00.00 flush-254:32
  67. 1976 root      20   0 52772 1492 1084 S   0.0  0.1   0:00.02 rsyslogd
  68. 2006 root      20   0  4112  652  508 S   0.0  0.1   0:00.00 acpid
  69. root@qqq:~# free -m
  70.              total       used       free     shared    buffers     cached
  71. Mem:          1000         67        933          0          2         27
  72. -/+ buffers/cache:         36        963
  73. Swap:         1023          0       1023
  74. root@qqq:~# cat /proc/cpuinfo
  75. processor       : 0
  76. vendor_id       : GenuineIntel
  77. cpu family      : 6
  78. model           : 13
  79. model name      : QEMU Virtual CPU version (cpu64-rhel6)
  80. stepping        : 3
  81. microcode       : 0x1
  82. cpu MHz         : 1999.999
  83. cache size      : 4096 KB
  84. fpu             : yes
  85. fpu_exception   : yes
  86. cpuid level     : 4
  87. wp              : yes
  88. flags           : fpu de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pse36 clflush mmx fxsr sse sse2 syscall nx lm up nopl pni cx16 hypervisor lahf_lm
  89. bogomips        : 3999.99
  90. clflush size    : 64
  91. cache_alignment : 64
  92. address sizes   : 46 bits physical, 48 bits virtual
  93. power management:
发表于 2014-1-20 17:15:05 | 只看该作者
联通抽完了。
发表于 2014-1-20 17:30:40 | 只看该作者
发表于 2014-1-20 17:31:49 | 只看该作者
发表于 2014-1-20 17:42:14 | 只看该作者
 楼主| 发表于 2014-1-20 17:44:57 | 只看该作者
晓白 发表于 2014-1-20 17:31
http://www.loc.qiche.eu.org/thread-230988-1-1.html
楼主拿这个脚本测试对locvps.com测试下带宽效果看看呗
还没装环境。
发表于 2014-1-20 21:03:53 来自手机 | 只看该作者
用艾普,长城宽带看看,沙田机房网络比较好,
发表于 2014-1-20 21:19:29 | 只看该作者
3m独享 1280都不够
发表于 2014-1-20 21:22:22 | 只看该作者
 楼主| 发表于 2014-1-21 11:02:58 | 只看该作者
昨天确实是网络抽了。现在PING不错。
GMT+8, 2026-4-17 02:13 , Processed in 0.120378 second(s), 13 queries , Gzip On, MemCache On.
