查看: 1733|回复: 1
安装mysql老是错误,求解
发表于 2010-7-6 19:49:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
系统是win32
安装的是mysql-essential-5.0.45-win32
步骤到apply security settings就出错
VPS问题,还是其他问题
Error Nr. 2003
Can't connect to MySQL server on 'localhost'(10061)
If a personal firewall is running on your machine.please make sure you have opened the TCP port 3306 for connections. Otherwise no client application can connect to the server.After you have opened the port please press [Retry] to apply the security settings.
If you are re-installing after you just uninstalled the MySQL server please note that the data directory was not removed automatically. Therefore the old password from your last installation is still needed to connect to the server. In this case please select skip now and re-run the Configuration Wizard from the start menu.
发表于 2010-7-6 19:56:36 | 只看该作者
关闭防火墙
mysql服务是否运行?
mysql装在什么分区?Path to executable是否正确?
GMT+8, 2026-4-29 23:17 , Processed in 0.059290 second(s), 9 queries , Gzip On, MemCache On.
