查看: 6047|回复: 0
MYSQL问题,求大拿
发表于 2013-9-17 23:26:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
启动不了mysql
[root@MyVPS2393 ~]# service mysql start
Starting MySQL..................................................................
................................... ERROR! The server quit without updating PID file (/usr/local/mysql/var/MyVPS2393.pid).
查看错误文件
[root@MyVPS2393 var]# less MyVPS2393.err
130606 09:00:19 mysqld_safe Starting mysqld daemon with databases from /usr/local/mysql/var
130606  9:00:19 InnoDB: The InnoDB memory heap is disabled
130606  9:00:19 InnoDB: Mutexes and rw_locks use GCC atomic builtins
130606  9:00:19 InnoDB: Compressed tables use zlib 1.2.3
130606  9:00:19 InnoDB: Initializing buffer pool, size = 16.0M
130606  9:00:19 InnoDB: Completed initialization of buffer pool
130606  9:00:19 InnoDB: highest supported file format is Barracuda.
130606  9:00:19  InnoDB: Waiting for the background threads to start
130606  9:00:20 InnoDB: 1.1.8 started; log sequence number 1595675
130606  9:00:20 [Note] Recovering after a crash using mysql-bin
130606  9:00:20 [Note] Starting crash recovery...
130606  9:00:20 [Note] Crash recovery finished.
130606  9:00:20 [Note] Server hostname (bind-address): '0.0.0.0'; port: 3306
130606  9:00:20 [Note]   - '0.0.0.0' resolves to '0.0.0.0';
130606  9:00:20 [Note] Server socket created on IP: '0.0.0.0'.
130606  9:00:20 [Note] Event Scheduler: Loaded 0 events
130606  9:00:20 [Note] /usr/local/mysql/bin/mysqld: ready for connections.
Version: '5.5.28-log'  socket: '/tmp/mysql.sock'  port: 3306  Source distribution
130606  9:46:09 [Warning] IP address '173.208.202.190' could not be resolved: Name or service not known
130606 12:11:44 [Warning] IP address '121.199.41.41' could not be resolved: Name or service not known
130606 12:19:19 [Warning] IP address '222.66.154.138' could not be resolved: Name or service not known
130606 16:28:41 [Warning] IP address '111.2.100.197' could not be resolved: Temporary failure in name resolution
130607 11:23:15 [Warning] IP address '218.61.104.25' could not be resolved: Name or service not known
130607 21:22:38 [Warning] IP address '27.36.163.121' could not be resolved: Name or service not known
130608 23:41:12 [Warning] IP address '121.199.11.115' could not be resolved: Name or service not known
130609  9:37:15 [Warning] IP address '173.208.249.117' could not be resolved: Name or service not known
130609 19:48:45 [Warning] IP address '222.169.86.74' could not be resolved: Temporary failure in name resolution
130609 19:48:46 [Warning] IP address '222.169.86.74' could not be resolved: Temporary failure in name resolution
130609 19:48:47 [Warning] IP address '222.169.86.74' could not be resolved: Temporary failure in name resolution
130609 19:48:48 [Warning] IP address '222.169.86.74' could not be resolved: Temporary failure in name resolution
130609 19:48:49 [Warning] IP address '222.169.86.74' could not be resolved: Temporary failure in name resolution
GMT+8, 2026-4-22 05:54 , Processed in 0.063184 second(s), 12 queries , Gzip On, MemCache On.
