查看: 6568|回复: 12
帮忙trace一个加拿大的IP
发表于 2010-6-26 13:32:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
204.187.100.14
每个5分。
发表于 2010-6-26 13:46:42 | 只看该作者
8   112 ms   109 ms   109 ms  219.158.10.149
  9   156 ms   151 ms   151 ms  219.158.11.6
10   158 ms   154 ms     *     219.158.29.54
11   327 ms   329 ms   325 ms  12.119.9.49
12   340 ms   343 ms   340 ms  cr2.la2ca.ip.att.net [12.122.129.118]
13   325 ms   320 ms   332 ms  cr2.la2ca.ip.att.net [12.123.30.250]
14   321 ms   322 ms   328 ms  la2ca02jt.ip.att.net [12.123.30.189]
15   367 ms   373 ms   377 ms  193.158.5.9
16   436 ms   437 ms   431 ms  217.239.40.210
17   463 ms   465 ms   464 ms  80.156.163.166
18   474 ms   468 ms   472 ms  204-187-100-14.amanah.com [204.187.100.14]
参与人数 1威望 +6 收起 理由
ccp + 6
发表于 2010-6-26 13:34:45 | 只看该作者
原帖由 ccp 于 2010-6-26 13:32 发表
204.187.100.14
每个5分。
tracert 204.187.100.14
traceroute to 204.187.100.14 (204.187.100.14), 30 hops max, 40 byte packets
1  218.7.164.25 (218.7.164.25)  9.277 ms  9.224 ms  9.213 ms
2  218.7.167.17 (218.7.167.17)  5.333 ms  12.616 ms  12.862 ms
3  218.9.207.93 (218.9.207.93)  1.858 ms  1.968 ms  2.000 ms
4  * * *
5  61.138.38.225 (61.138.38.225)  2.576 ms  2.644 ms  2.638 ms
6  61.167.6.25 (61.167.6.25)  2.397 ms  2.181 ms  2.158 ms
7  219.158.17.137 (219.158.17.137)  27.533 ms  27.411 ms  27.306 ms
8  219.158.4.154 (219.158.4.154)  67.822 ms  68.119 ms  67.710 ms
9  219.158.11.42 (219.158.11.42)  116.219 ms  116.130 ms  115.098 ms
10  219.158.29.50 (219.158.29.50)  122.081 ms  124.409 ms  124.352 ms
11  12.119.9.49 (12.119.9.49)  287.100 ms  287.045 ms  287.038 ms
12  cr1.la2ca.ip.att.net (12.122.128.118)  285.858 ms  285.850 ms  285.845 ms
13  cr1.la2ca.ip.att.net (12.123.30.110)  286.215 ms  286.206 ms  286.263 ms
14  la2ca02jt.ip.att.net (12.123.30.17)  285.383 ms  285.406 ms  285.392 ms
15  193.158.5.9 (193.158.5.9)  390.092 ms  400.191 ms  400.236 ms
16  217.239.40.210 (217.239.40.210)  482.971 ms  484.692 ms  482.798 ms
17  80.156.163.166 (80.156.163.166)  436.282 ms  436.315 ms  436.480 ms
18  204-187-100-14.amanah.com (204.187.100.14)  411.927 ms  412.923 ms  410.864 ms
参与人数 1威望 +6 收起 理由
ccp + 6
发表于 2010-6-26 13:40:51 | 只看该作者
Tracing route to 204-187-100-14.amanah.com [204.187.100.14]
over a maximum of 30 hops:
  1    23 ms    35 ms    24 ms  119.122.32.1
  2    30 ms    30 ms    28 ms  119.122.32.1
  3    22 ms    22 ms    19 ms  121.15.150.17
  4    19 ms    20 ms    19 ms  119.136.12.162
  5    25 ms    23 ms    25 ms  119.145.47.82
  6    24 ms    25 ms    25 ms  202.97.34.17
  7   129 ms   125 ms   125 ms  202.97.60.66
  8   192 ms   191 ms   195 ms  202.97.49.106
  9   293 ms   292 ms   322 ms  202.97.50.66
10   190 ms   186 ms   186 ms  218.30.54.66
11   402 ms   403 ms   401 ms  217.239.40.210
12   296 ms   298 ms   301 ms  80.156.163.166
13   395 ms   394 ms     *     204-187-100-14.amanah.com [204.187.100.14]
14   296 ms     *      293 ms  204-187-100-14.amanah.com [204.187.100.14]
Trace complete.
参与人数 1威望 +6 收起 理由
ccp + 6
发表于 2010-6-26 13:50:39 | 只看该作者
广东电信
1 61.142.80.190 广东省中山市 11ms
2 59.33.32.246 246.32.33.59.broad.zs.gd.dy... 广东省中山市 1ms
3 59.33.85.169 169.85.33.59.broad.zs.gd.dy... 广东省中山市 0ms
4 183.59.0.130 广东省 2ms
5 183.59.0.42 广东省 2ms
6 202.97.33.218 上海市 3ms
7 202.97.60.66 电信骨干网 4ms
8 202.97.49.110 上海市 168ms
9 202.97.50.54 电信骨干网 181ms
10 218.30.54.66 电信美国节点 229ms
11 217.239.40.210 德国 271ms
12 80.156.163.166 德国 279ms
13 204.187.100.14 204-187-100-14.amanah.com 美国 270ms
参与人数 1威望 +6 收起 理由
ccp + 6
发表于 2010-6-26 13:55:52 | 只看该作者
3    11 ms    12 ms    12 ms  218.86.43.21
  4    15 ms    19 ms    32 ms  218.86.44.229
  5    16 ms    15 ms    16 ms  202.97.43.254
  6    23 ms    25 ms    22 ms  202.97.41.146
  7    77 ms    69 ms    79 ms  202.97.33.150
  8    78 ms    76 ms    73 ms  202.97.60.182
  9   241 ms   248 ms   246 ms  202.97.51.162
10   253 ms   247 ms   250 ms  202.97.50.26
11   250 ms   250 ms   245 ms  62.156.139.149
12   340 ms   343 ms   344 ms  217.239.40.210
13   330 ms   327 ms   327 ms  80.156.163.166
14   343 ms   347 ms   344 ms  204-187-100-14.amanah.com [204.187.100.14]
Trace complete.
参与人数 1威望 +6 收起 理由
ccp + 6
发表于 2010-6-26 14:06:52 | 只看该作者
C:\Users\Administrator>tracert 204.187.100.14
通过最多 30 个跃点跟踪
到 204-187-100-14.amanah.com [204.187.100.14] 的路由:
  2    16 ms    15 ms    16 ms  222.222.78.9
  3    22 ms    23 ms    23 ms  219.148.94.193
  4    27 ms    28 ms    26 ms  202.97.49.189
  5    27 ms    26 ms    27 ms  202.97.53.10
  6   238 ms   237 ms   238 ms  202.97.51.186
  7   217 ms   213 ms   213 ms  202.97.50.26
  8   239 ms   240 ms   241 ms  62.156.139.149
  9   306 ms   347 ms   332 ms  217.239.40.210
10   308 ms   308 ms   308 ms  80.156.163.166
11   368 ms   351 ms   320 ms  204-187-100-14.amanah.com [204.187.100.14]
跟踪完成。
发表于 2010-6-26 14:20:59 | 只看该作者
通过最多 30 个跃点跟踪
  1    <1 毫秒   <1 毫秒   <1 毫秒 192.168.1.1
  2     1 ms     1 ms     1 ms  61.172.80.1
  3     1 ms    <1 毫秒   <1 毫秒 124.74.29.1
  4     2 ms     2 ms     2 ms  124.74.211.85
  5     3 ms     3 ms     3 ms  61.152.86.42
  6     3 ms     2 ms     2 ms  202.97.35.106
  7     4 ms     4 ms     4 ms  202.97.35.14
  8   301 ms   302 ms   302 ms  202.97.51.58
  9   172 ms   171 ms   172 ms  202.97.50.34
10   196 ms   199 ms   196 ms  62.156.139.149
11   267 ms   270 ms   267 ms  217.239.40.210
12   260 ms   263 ms   259 ms  80.156.163.166
13   281 ms   282 ms   279 ms  204-187-100-14.amanah.com [204.187.100.14]
跟踪完成。
参与人数 1威望 +6 收起 理由
ccp + 6
发表于 2010-6-26 14:27:22 | 只看该作者
ping值有点大了哦
发表于 2010-6-26 14:43:34 | 只看该作者
C:\>tracert 204.187.100.14
  1    12 ms     9 ms    10 ms  110.52.131.1
  2    19 ms     9 ms    19 ms  110.52.131.1
  3     3 ms     6 ms     6 ms  58.20.176.241
  4     6 ms     4 ms     4 ms  220.248.160.181
  5    27 ms    27 ms    27 ms  219.158.18.5
  6   122 ms   123 ms   123 ms  219.158.11.158
  7   128 ms   132 ms   130 ms  219.158.29.54
  8   316 ms   314 ms   309 ms  12.119.9.49
  9   327 ms   318 ms   314 ms  cr2.la2ca.ip.att.net [12.122.129.122]
10     *      303 ms     *     cr2.la2ca.ip.att.net [12.123.30.250]
11   301 ms   304 ms     *     la2ca02jt.ip.att.net [12.123.30.189]
12   358 ms   361 ms   358 ms  193.158.5.9
13   435 ms   434 ms   445 ms  217.239.40.210
14   432 ms   434 ms   435 ms  80.156.163.166
15   445 ms   444 ms   440 ms  204-187-100-14.amanah.com [204.187.100.14]
Trace complete.
湖南联通
参与人数 1威望 +6 收起 理由
ccp + 6
GMT+8, 2026-4-27 02:47 , Processed in 0.071892 second(s), 12 queries , Gzip On, MemCache On.
