CeraNetworks网络延迟测速工具IP归属甄别
查看: 17118|回复: 2
SHARKTECH Denver DataCenter Open August 1st 2010
发表于 2010-6-23 18:45:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The network infrastructure will be identical to Chicago DC and with more robust firewalls hardware in place. We have learned from 8 years of business in Chicago and we are putting all our experience in having a full successful launch in Denver.
We will also have a dark fiber cross-connect between Sharktech Denver and Sharktech Chicago. This will allow cross-peering between the two facilities for outgoing traffic and inter-network communications.
In regards to available packages in Denver there will be some different packages available in Denver, but the highest used systems in Chicago will also be available in Denver.
Thank you,
sharktech的丹佛机房8月1日开放,接入带宽 Tinet  Telia  TATA分别接入10Gbps。
发表于 2010-6-23 23:01:48 | 只看该作者
FDC的网络吗?
 楼主| 发表于 2010-6-30 16:43:30 | 只看该作者
回复 2# 的帖子
FDC的机柜,应该是自己的网络
GMT+8, 2026-4-26 09:33 , Processed in 0.055923 second(s), 9 queries , Gzip On, MemCache On.
