查看: 3095|回复: 7
[疑问] whmcs5.2.6出来了
发表于 2013-7-24 23:34:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
WHMCS Security Advisory for 4.x and 5.x
http://blog.whmcs.com/?t=76310
WHMCS has released new patches for the 4.5, 5.0, 5.1, and 5.2 minor releases.
These updates provide targeted changes to address security concerns with the
WHMCS product. You are highly encouraged to update immediately.
WHMCS has rated these updates as including critical or important security
impacts. Information on security ratings is available at
http://docs.whmcs.com/Security_Levels.
==Releases==
The following full-release versions of WHMCS have been published and address all
known vulnerabilities:
5.2.6
The latest public releases of WHMCS are available inside our members area at
https://www.whmcs.com/members/clientarea.php
PLEASE NOTE: The 4.5 series reached End Of Life as of June 30th 2013.  WHMCS is
aware that some customers have not moved to an LTS version due to the newness of
the LTS policy.  The related 4.5 patch release published along with this
Security Advisory is provided as a courtesy to those customers.  From this point
forward, there will be no more patches provided for 4.5 or any other release
that has reached EOL.
==Security Issue Information==
The resolved security issues were identified and reported by
Vlad C. of NetSec Interactive Solutions <http://safeornot.net>
Rack911 <https://www.rack911.com/>
FastVPS Eesti OU <http://fastvps.ru>
WHMCS development team.
There is no reason to believe that these vulnerabilities are known to the
public. As such, WHMCS will only release limited information regarding the
vulnerabilities at this time.
Once sufficient time has passed to allow WHMCS customers to update their
installed software, WHMCS will release additional information regarding the
nature of the security issue.
These Targeted Security Releases and Patches address 9 vulnerabilities in WHMCS
versions 4.5, 5.0, .5.1, and 5.2.
==Mitigation==
===WHMCS Version 4.5===
Download and apply the appropriate patch files to protect against these
vulnerabilities.
Patch files for affected versions of the 4.5 series are located on the WHMCS
site as itemized below.
v4.5.6 (patch only; for 4.5.5): http://go.whmcs.com/174/v456patch
To apply a patch, download the files as indicated above.  Next follow the
regular upgrade instructions which can be found at
http://docs.whmcs.com/Upgrading#Performing_an_Upgrade.
===WHMCS Version 5.x===
Download and apply the appropriate full-version or patch of WHMCS to protect
against these vulnerabilities.
Patch files for affected version 5.x are located on the WHMCS site as itemized
below. A full-version of 5.2.6 is located in the WHMCS member's area download
section, under your license details.
v5.0.7 (patch only; for 5.0.6): http://go.whmcs.com/178/v507patch
v5.1.8 (patch only; for 5.1.7): http://go.whmcs.com/182/v518patch
v5.2.6 (full-version) - Available in the members area @ www.whmcs.com/members
To apply a patch or full-version release, download the files as indicated above.
Next follow the regular upgrade instructions which can be found at
*This Security Advisory is in the process of being emailed to all active license
holders.*
WHMCS Limited
www.whmcs.com
发表于 2013-7-24 23:35:54 | 只看该作者
表示 没有授权码
发表于 2013-7-24 23:58:01 | 只看该作者
不知道这次是什么漏洞
发表于 2013-7-28 16:56:42 | 只看该作者
whmcs5.2.3
whmcs5.2.4
whmcs5.2.5
whmcs5.2.6
whmcs5.2.7
全能完美无后门破解友情推荐,见签名!
发表于 2013-8-7 00:15:27 | 只看该作者
闲置貌似5.2.7了谁申请了吗 有没有小白鼠啊 来说说啥效果
发表于 2013-8-10 22:40:33 | 只看该作者
木有钱买这个
发表于 2013-8-11 08:25:26 | 只看该作者
One Time No Branding
$324.95
GMT+8, 2026-4-18 08:25 , Processed in 0.059831 second(s), 9 queries , Gzip On, MemCache On.
