查看: 5031|回复: 18
[疑问] 国内vps Squid+ipv6成功看有图比(Squid配置有更新)
发表于 2013-6-26 03:26:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
之前为毛被删帖
这个方法只在国内服务器上有用,国外的试过,全部死啦死啦的。
squid or kangle+HE提供的隧道(香港节点)+HE提供的dns=除推特外,FB和有图比都可上。速度soso的。。。。
squid配置必须加上 dns_nameservers 2001:470:20::2 8.8.8.8 8.8.4.4
推特搞不清,难道没提供ipv6服务?
测试看看p*r*o*x*y.cachecdn.org(去掉*)   端口是3128(基于kangle)
5M,,别挤太多人。
环境centos6 64bit
我的squid配置(供参考,可能有人 ::1 、fc00:: 、fe80::这几个不同):
PS:ok如果报错试试将两个::1删除,带有fc00:: 、fe80::的这两行删除
# Recommended minimum configuration:
acl manager proto cache_object
acl localhost src 127.0.0.1/32 ::1
acl to_localhost dst 127.0.0.0/8 0.0.0.0/32 ::1
# Example rule allowing access from your local networks.
# Adapt to list your (internal) IP networks from where browsing
# should be allowed
acl localnet src 10.0.0.0/8        # RFC1918 possible internal network
acl localnet src 172.16.0.0/12        # RFC1918 possible internal network
acl localnet src 192.168.0.0/16        # RFC1918 possible internal network
acl localnet src fc00::/7       # RFC 4193 local private network range
acl localnet src fe80::/10      # RFC 4291 link-local (directly plugged) machines
#acl SSL_ports port 443
#acl Safe_ports port 80                # http
#acl Safe_ports port 21                # ftp
#acl Safe_ports port 443                # https
#acl Safe_ports port 70                # gopher
#acl Safe_ports port 210                # wais
#acl Safe_ports port 1025-65535        # unregistered ports
#acl Safe_ports port 280                # http-mgmt
#acl Safe_ports port 488                # gss-http
#acl Safe_ports port 591                # filemaker
#acl Safe_ports port 777                # multiling http
#acl CONNECT method CONNECT
# Recommended minimum Access Permission configuration:
# Only allow cachemgr access from localhost
http_access allow manager localhost
http_access deny manager
# Deny requests to certain unsafe ports
#http_access deny !Safe_ports
# Deny CONNECT to other than secure SSL ports
#http_access deny CONNECT !SSL_ports
# We strongly recommend the following be uncommented to protect innocent
# web applications running on the proxy server who think the only
# one who can access services on "localhost" is a local user
#http_access deny to_localhost
# INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
# Adapt localnet in the ACL section to list your (internal) IP networks
# from where browsing should be allowed
http_access allow localnet
http_access allow localhost
# And finally deny all other access to this proxy
http_access allow all
# Squid normally listens to port 3128
http_port 8080
# We recommend you to use at least the following line.
acl QUERY urlpath_regex cgi-bin \?
no_cache deny QUERY
# Uncomment and adjust the following to add a disk cache directory.
cache_mem 200 MB
maximum_object_size 50 MB
minimum_object_size 0 KB
maximum_object_size_in_memory 50 MB
cache_swap_low 70
cache_swap_high 85
cache_replacement_policy heap LFUDA
memory_replacement_policy heap LFUDA
cache_dir aufs /var/spool/squid 10000 16 256
# Leave coredumps in the first cache dir
coredump_dir /var/spool/squid
# Add any of your own refresh_pattern entries above these.
refresh_pattern ^ftp:           1440    20%     10080
refresh_pattern ^gopher:        1440    0%      1440
refresh_pattern -i (/cgi-bin/|\?) 0     0%      0
refresh_pattern .               0       20%     4320
refresh_pattern -i \.flv$ 4320 100% 43200 reload-into-ims ignore-reload
refresh_pattern -i \.ipa$ 4320 100% 43200 reload-into-ims ignore-reload
refresh_pattern -i \.apk$ 4320 100% 43200 reload-into-ims ignore-reload
refresh_pattern -i windowsupdate.com/.*\.(cab|exe) 4320 100% 43200 reload-into-ims ignore-reload
refresh_pattern -i download.microsoft.com/.*\.(cab|exe) 4320 100% 43200 reload-into-ims ignore-reload
refresh_pattern -i au.download.windowsupdate.com/.*\.(cab|exe) 4320 100% 43200 reload-into-ims ignore-reload
refresh_pattern -i itunes.apple.com/.*\.(ipa|bmp|jpg|gif) 4320 100% 43200 reload-into-ims ignore-reload
refresh_pattern -i apple.com/.*\.(ipa|bmp|jpg|gif) 4320 100% 43200 reload-into-ims ignore-reload
range_offset_limit 50 MB
range_offset_limit -1 KB
quick_abort_min -1 KB
forwarded_for off
client_persistent_connections on
server_persistent_connections on
client_db off
cache_mgr root
visible_hostname Aliyun
#hosts_file /etc/hosts
发表于 2013-6-26 03:30:53 | 只看该作者
这帖等下应该也会被防水墙删掉。
防水墙是文盲。
发表于 2013-6-26 04:06:23 | 只看该作者
我是人 发表于 2013-6-26 03:30
这帖等下应该也会被防水墙删掉。
防水墙是文盲。
成功存活半小时以上
发表于 2013-6-26 04:08:07 | 只看该作者
另外国外不死才怪 某FW早就能检测HTTP代理了
 楼主| 发表于 2013-6-26 04:09:21 | 只看该作者
服务器在国内就不会。。
国内有北岸卡着 功夫网就不需要过滤了  发表于 2013-6-26 04:11
 楼主| 发表于 2013-6-26 04:29:35 | 只看该作者
雨宫音羽 发表于 2013-6-26 04:06
成功存活半小时以上
上一个帖子活了大概两三个小时//、
发表于 2013-6-26 08:00:30 | 只看该作者
您的IP:[115.47.41.226] 来自:北京市 电信通
发表于 2013-6-26 08:04:27 | 只看该作者
hcw1588 发表于 2013-6-26 04:09
服务器在国内就不会。。
坐等去喝茶了好么
 楼主| 发表于 2013-6-26 08:08:57 | 只看该作者
onlybird 发表于 2013-6-26 08:04
坐等去喝茶了好么
不会啊,没留任何真实信息,再说这么做的人多了那里管得过来
 楼主| 发表于 2013-6-26 08:10:38 | 只看该作者
用的息壤20弄得,废物利用。。。
GMT+8, 2026-5-3 17:58 , Processed in 0.117936 second(s), 15 queries , Gzip On, MemCache On.
