查看: 6802|回复: 31
[疑问] 息壤20折腾了好久,终于利用squid+ipv6翻长城成功了。
发表于 2013-6-25 23:38:55 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
这个方法只在国内服务器上有用,国外的试过,全部死啦死啦的。
squid+HE提供的隧道(香港节点)+HE提供的dns=除推特外,FB和有图比都可上。速度soso的。。。。
squid配置必须加上 dns_nameservers 2001:470:20::2 8.8.8.8 8.8.4.4
推特搞不清,难道没提供ipv6服务?
测试看看HTTP proxy:proxy.cachecdn.org(不知道dns同步了没)   端口是squid默认的3128
5M,,别挤太多人。
我的squid配置:
# Recommended minimum configuration:
acl manager proto cache_object
acl localhost src 127.0.0.1/32 ::1
acl to_localhost dst 127.0.0.0/8 0.0.0.0/32 ::1
# Example rule allowing access from your local networks.
# Adapt to list your (internal) IP networks from where browsing
# should be allowed
acl localnet src 10.0.0.0/8        # RFC1918 possible internal network
acl localnet src 172.16.0.0/12        # RFC1918 possible internal network
acl localnet src 192.168.0.0/16        # RFC1918 possible internal network
acl localnet src fc00::/7       # RFC 4193 local private network range
acl localnet src fe80::/10      # RFC 4291 link-local (directly plugged) machines
#acl SSL_ports port 443
#acl Safe_ports port 80                # http
#acl Safe_ports port 21                # ftp
#acl Safe_ports port 443                # https
#acl Safe_ports port 70                # gopher
#acl Safe_ports port 210                # wais
#acl Safe_ports port 1025-65535        # unregistered ports
#acl Safe_ports port 280                # http-mgmt
#acl Safe_ports port 488                # gss-http
#acl Safe_ports port 591                # filemaker
#acl Safe_ports port 777                # multiling http
#acl CONNECT method CONNECT
# Recommended minimum Access Permission configuration:
# Only allow cachemgr access from localhost
http_access allow manager localhost
http_access deny manager
# Deny requests to certain unsafe ports
#http_access deny !Safe_ports
# Deny CONNECT to other than secure SSL ports
#http_access deny CONNECT !SSL_ports
# We strongly recommend the following be uncommented to protect innocent
# web applications running on the proxy server who think the only
# one who can access services on "localhost" is a local user
#http_access deny to_localhost
# INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
# Adapt localnet in the ACL section to list your (internal) IP networks
# from where browsing should be allowed
http_access allow localnet
http_access allow localhost
# And finally deny all other access to this proxy
http_access allow all
# Squid normally listens to port 3128
http_port 3128
# We recommend you to use at least the following line.
acl QUERY urlpath_regex cgi-bin \?
no_cache deny QUERY
# Uncomment and adjust the following to add a disk cache directory.
cache_mem 200 MB
maximum_object_size 20 MB
maximum_object_size_in_memory 20 MB
cache_replacement_policy heap LFUDA
memory_replacement_policy heap LFUDA
cache_dir aufs /var/spool/squid 10000 16 256
# Leave coredumps in the first cache dir
coredump_dir /var/spool/squid
# Add any of your own refresh_pattern entries above these.
refresh_pattern ^ftp:                1440        20%        10080
refresh_pattern ^gopher:        1440        0%        1440
refresh_pattern -i (/cgi-bin/|\?) 0        0%        0
refresh_pattern .                0        20%        4320
forwarded_for off
client_persistent_connections on
server_persistent_connections on
client_db off
cache_mgr 保密
visible_hostname Aliyun
#hosts_file /etc/hosts
发表于 2013-6-25 23:42:32 | 只看该作者
求ipv6方法
 楼主| 发表于 2013-6-25 23:43:30 | 只看该作者
yxzyxz001 发表于 2013-6-25 23:42
求ipv6方法
什么架构的,ovz的我没成功过
发表于 2013-6-25 23:43:37 | 只看该作者
哥表示一直在用,一路由直接连接he,一个通过oah转发ip。都可以获得独立ipv6地址,比这个代理强多了!
发表于 2013-6-25 23:44:37 | 只看该作者
TSP连呆丸无压力
发表于 2013-6-25 23:45:51 | 只看该作者
hcw1588 发表于 2013-6-25 23:43
什么架构的,ovz的我没成功过
xen吧整来玩玩
 楼主| 发表于 2013-6-25 23:50:25 | 只看该作者
yxzyxz001 发表于 2013-6-25 23:45
xen吧整来玩玩
http://www.tunnelbroker.net/
注册个号,登陆后 1.png (1.63 KB, 下载次数: 0) ,框内填你vps的ip,之后选香港的就好。之后 1.png (4.24 KB, 下载次数: 0) ,根据你什么系统选择命令了
 楼主| 发表于 2013-6-25 23:51:36 | 只看该作者
xen吧整来玩玩
对了,你是国内的服务器吧
发表于 2013-6-25 23:53:54 | 只看该作者
hcw1588 发表于 2013-6-25 23:51
对了,你是国内的服务器吧
恩恩
发表于 2013-6-25 23:54:55 | 只看该作者
对了,你是国内的服务器吧
国内的能用吧?
GMT+8, 2026-5-4 18:24 , Processed in 0.073729 second(s), 14 queries , Gzip On, MemCache On.
