查看: 5886|回复: 7
[疑问] 有人安装过Zkeys Linux的被控?
发表于 2013-6-3 17:45:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我安装一直提示这些
---> Package ncurses-devel.i686 0:5.7-3.20090208.el6 will be installed
---> Package net-snmp.i686 1:5.5-44.el6_4.1 will be installed
---> Package net-snmp-devel.i686 1:5.5-44.el6_4.1 will be installed
--> Processing Dependency: tcp_wrappers-devel for package: 1:net-snmp-devel-5.5-        44.el6_4.1.i686
--> Processing Dependency: lm_sensors-devel for package: 1:net-snmp-devel-5.5-44        .el6_4.1.i686
---> Package net-snmp-libs.i686 1:5.5-44.el6_4.1 will be installed
---> Package openldap-devel.i686 0:2.4.23-32.el6_4.1 will be installed
---> Package perl-DBI.i686 0:1.609-4.el6 will be installed
---> Package perl-String-CRC32.i686 0:1.4-9.el6 will be installed
---> Package postgresql.i686 0:8.4.13-1.el6_3 will be installed
--> Processing Dependency: postgresql-libs(x86-32) = 8.4.13-1.el6_3 for package:        postgresql-8.4.13-1.el6_3.i686
--> Processing Dependency: libpq.so.5 for package: postgresql-8.4.13-1.el6_3.i68        6
---> Package postgresql-devel.i686 0:8.4.13-1.el6_3 will be installed
---> Package rpm-devel.i686 0:4.8.0-32.el6 will be installed
--> Processing Dependency: popt-devel(x86-32) for package: rpm-devel-4.8.0-32.el        6.i686
--> Processing Dependency: file-devel(x86-32) for package: rpm-devel-4.8.0-32.el        6.i686
---> Package sqlite-devel.i686 0:3.6.20-1.el6 will be installed
---> Package unixODBC.i686 0:2.2.14-12.el6_3 will be installed
--> Processing Dependency: libltdl.so.7 for package: unixODBC-2.2.14-12.el6_3.i6        86
---> Package unixODBC-devel.i686 0:2.2.14-12.el6_3 will be installed
---> Package vsftpd.i686 0:2.2.2-11.el6_4.1 will be installed
--> Running transaction check
---> Package apr-util-ldap.i686 0:1.3.9-3.el6_0.1 will be installed
---> Package aspell.i686 12:0.60.6-12.el6 will be installed
---> Package autohost.i386 0:1.5-1 will be installed
--> Processing Dependency: beecrypt-devel >= 4.1.2-10.1.1 for package: autohost-        1.5-1.i386
---> Package dmidecode.i686 1:2.11-2.el6 will be installed
---> Package file-devel.i686 0:5.04-15.el6 will be installed
---> Package httpd-tools.i686 0:2.2.15-28.el6.centos will be installed
---> Package libtool-ltdl.i686 0:2.2.6-15.5.el6 will be installed
---> Package lm_sensors-devel.i686 0:3.1.1-17.el6 will be installed
---> Package lm_sensors-libs.i686 0:3.1.1-17.el6 will be installed
---> Package mailcap.noarch 0:2.1.31-2.el6 will be installed
---> Package perl-DBD-MySQL.i686 0:4.013-3.el6 will be installed
---> Package popt-devel.i686 0:1.13-7.el6 will be installed
---> Package postgresql-libs.i686 0:8.4.13-1.el6_3 will be installed
---> Package tcl.i686 1:8.5.7-6.el6 will be installed
---> Package tcp_wrappers-devel.i686 0:7.6-57.el6 will be installed
--> Finished Dependency Resolution
Error: Package: autohost-1.5-1.i386 (Autohost)
           Requires: beecrypt-devel >= 4.1.2-10.1.1
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
发表于 2013-6-3 17:52:05 | 只看该作者
找他们客服吧
 楼主| 发表于 2013-6-3 17:54:01 | 只看该作者
tointer 发表于 2013-6-3 17:52
找他们客服吧
这家公司客服难找
发表于 2013-6-3 18:53:02 | 只看该作者
gd1861 发表于 2013-6-3 17:54
这家公司客服难找
一样 的国内几家卖主机系统的卖出去就不求管了
发表于 2013-6-3 23:01:28 来自手机 | 只看该作者
第三方软件源版本不对 比如说你是centos5确装的centos6的源
发表于 2013-6-3 23:02:36 | 只看该作者
发表于 2013-6-3 23:26:55 | 只看该作者
这家不是破解的?
发表于 2013-6-4 00:26:12 | 只看该作者
垃圾的一比
GMT+8, 2026-4-13 16:03 , Processed in 0.127056 second(s), 12 queries , Gzip On, MemCache On.
