查看: 4285|回复: 9
[深度评测]DigitalOcean – $5/月 512MB KVM 旧金山
发表于 2013-6-2 15:48:23 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
DigitalOcean-512MB
  1. CPU:1
  2. 内存:512MB
  3. 磁盘:20 GB
  4. 流量:1 TB
  5. 价格:$5/mo
1、CPU信息
  1. ~# cat /proc/cpuinfo
  2. processor : 0
  3. vendor_id : GenuineIntel
  4. cpu family : 6
  5. model : 2
  6. model name : QEMU Virtual CPU version 1.2.0
  7. stepping : 3
  8. microcode : 0x1
  9. cpu MHz : 2299.998
  10. cache size : 4096 KB
  11. fdiv_bug : no
  12. hlt_bug : no
  13. f00f_bug : no
  14. coma_bug : no
  15. fpu : yes
  16. fpu_exception : yes
  17. cpuid level : 4
  18. wp : yes
  19. flags : fpu de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pse36 clflush mmx fxsr sse sse2 syscall nx lm up pni vmx cx16 popcnt hypervisor lahf_lm
  20. bogomips : 4599.99
  21. clflush size : 64
  22. cache_alignment : 64
  23. address sizes : 40 bits physical, 48 bits virtual
  24. power management:
2.摧残磁盘
  1. ~# hdparm -t /dev/sda
  2. /dev/sda:
  3. Timing buffered disk reads: 1110 MB in 3.00 seconds = 369.93 MB/sec
  4. ~# dd if=/dev/zero of=test bs=64k count=4k conv=fdatasync
  5. 4096+0 records in
  6. 4096+0 records out
  7. 268435456 bytes (268 MB) copied, 0.490432 s, 547 MB/s
  8. ~# dd if=/dev/zero of=test bs=256k count=4k conv=fdatasync
  9. 4096+0 records in
  10. 4096+0 records out
  11. 1073741824 bytes (1.1 GB) copied, 2.9836 s, 360 MB/s
  12. ~# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  13. 4096+0 records in
  14. 4096+0 records out
  15. 268435456 bytes (268 MB) copied, 5.54056 s, 48.4 MB/s
3.上海电信Ping值
  1. Pinging 198.199.114.235 with 64 bytes of data:
  2. Reply from 198.199.114.*: bytes=64 time=368 TTL=51 seq=1
  3. Reply from 198.199.114.*: bytes=64 time=384 TTL=51 seq=2
  4. Reply from 198.199.114.*: bytes=64 time=400 TTL=51 seq=3
  5. Reply from 198.199.114.*: bytes=64 time=400 TTL=51 seq=4
  6. Reply from 198.199.114.*: bytes=64 time=416 TTL=51 seq=5
  7. Reply from 198.199.114.*: bytes=64 time=416 TTL=51 seq=6
  8. Reply from 198.199.114.*: bytes=64 time=432 TTL=51 seq=7
  9. Reply from 198.199.114.*: bytes=64 time=416 TTL=51 seq=8
  10. Reply from 198.199.114.*: bytes=64 time=496 TTL=51 seq=9
  11. Reply from 198.199.114.*: bytes=64 time=432 TTL=51 seq=10
  12. Ping statistics for 198.199.114.*
  13. Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
  14. Approximate round trip times in milliseconds:
  15. Minimum = 368, Maximum = 496, Average = 416
4.上海电信路由跟踪
  1. Tracing route to 198.199.114.* over a maximum of 20 hops
  2. 1 16ms 1ms 1ms 114.85.128.1
  3. 2 1ms 1ms 1ms 124.74.148.69
  4. 3 1ms 1ms 1ms 124.74.209.229
  5. 4 1ms 1ms 1ms 61.152.86.198
  6. 5 1ms 1ms 1ms 202.97.50.234
  7. 6 1ms 1ms 1ms 202.97.35.94
  8. 7 192ms 192ms 192ms 202.97.58.162
  9. 8 160ms 160ms 160ms 202.97.90.6
  10. 9 * 336ms * Request timed out.
  11. 10 272ms 320ms 288ms 89.149.184.150
  12. 11 320ms 304ms 304ms 173.241.128.238
  13. 12 352ms 336ms 336ms 198.199.114.*
  14. Trace complete.
5.网络测试
  1. ~# wget cachefly.cachefly.net/100mb.test
  2. --2013-05-26 13:46:01-- http://cachefly.cachefly.net/100mb.test
  3. Resolving cachefly.cachefly.net (cachefly.cachefly.net)... 205.234.175.175
  4. Connecting to cachefly.cachefly.net (cachefly.cachefly.net)|205.234.175.175|:80... connected.
  5. HTTP request sent, awaiting response... 200 OK
  6. Length: 104857600 (100M) [application/octet-stream]
  7. Saving to: `100mb.test'
  8. 100%[======================================>] 104,857,600 26.6M/s in 3.8s
  9. 2013-05-26 13:46:05 (26.4 MB/s) - `100mb.test' saved [104857600/104857600]
6.网络测试(深圳腾讯)
  1. ~# wget http://dldir1.qq.com/qqfile/qq/QQ2013/2013Beta4/6734/QQ2013Beta4.exe
  2. --2013-05-26 13:47:34-- http://dldir1.qq.com/qqfile/qq/QQ2013/2013Beta4/6734/QQ2013Beta4.exe
  3. Resolving dldir1.qq.com (dldir1.qq.com)... 103.7.29.210, 103.7.29.211, 103.7.29.215, ...
  4. Connecting to dldir1.qq.com (dldir1.qq.com)|103.7.29.210|:80... connected.
  6. Length: 58511032 (56M) [application/octet-stream]
  7. Saving to: `QQ2013Beta4.exe'
  8. 100%[======================================>] 58,511,032 179K/s in 7m 50s
  9. 2013-05-26 13:55:25 (122 KB/s) - `QQ2013Beta4.exe' saved [58511032/58511032]
发表于 2013-6-2 15:57:15 | 只看该作者
        这也算深度么。。。。。        ——来自VPS爱唯欧
发表于 2013-6-2 15:58:10 来自手机 | 只看该作者
裤子都脱了,你就给我看这个?
发表于 2013-6-2 15:59:24 | 只看该作者
 楼主| 发表于 2013-6-2 16:02:42 | 只看该作者
_____________Cc 发表于 2013-6-2 15:57
这也算深度么。。。。。        ...
比上面那个深度。。。
发表于 2013-6-2 16:12:55 | 只看该作者
延迟太高。不打算要了
发表于 2013-6-2 16:52:53 | 只看该作者
ulmate01 发表于 2013-6-2 16:12
延迟太高。不打算要了
有纽约节点的,纽约节点的ping值的才200多
纽约才是高延迟  发表于 2013-6-2 18:03
发表于 2013-6-2 17:38:00 | 只看该作者
电信的ping这么高?以前很低的呀
发表于 2013-6-2 21:24:05 | 只看该作者
发表于 2013-6-2 21:31:08 | 只看该作者
不知道他们怎么想的 居然从nlayer换到tinet
GMT+8, 2026-4-17 05:26 , Processed in 0.069657 second(s), 14 queries , Gzip On, MemCache On.
