查看: 3236|回复: 5
到底是为什么报错?。。。。。。。折磨我很久了~~~.....
发表于 2013-5-30 12:38:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
root@debian:~# apt-get install gcc g++ make flex bison openssl libssl-dev perl perl-base perl-modules libperl-dev libaio1 libaio-dev zlib1g zlib1g-dev libcap-dev bzip2 automake autoconf libtool cmake
Reading package lists... Done
Building dependency tree
Reading state information... Done
bzip2 is already the newest version.
bzip2 set to manually installed.
openssl is already the newest version.
openssl set to manually installed.
zlib1g is already the newest version.
perl is already the newest version.
perl-base is already the newest version.
perl-modules is already the newest version.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
automake : Depends: autotools-dev (>= 20020320.1) but it is not going to be installed
cmake : Depends: libxmlrpc-c3 but it is not going to be installed
         Depends: cmake-data (= 2.8.2+dfsg.1-0+squeeze1) but it is not going to be installed
g++ : Depends: g++-4.4 (>= 4.4.5-1~) but it is not going to be installed
       Depends: gcc-4.4 (>= 4.4.5-1~) but it is not going to be installed
gcc : Depends: gcc-4.4 (>= 4.4.5-1~) but it is not going to be installed
       Recommends: libc6-dev but it is not going to be installed or
                   libc-dev
libc6 : Depends: libc-bin (= 2.11.3-4) but 2.13-38 is to be installed
libc6-i386 : Depends: libc6 (= 2.13-38) but 2.11.3-4 is to be installed
libtool : Depends: libc6-dev but it is not going to be installed or
                    libc-dev
           Depends: autotools-dev but it is not going to be installed
           Recommends: libltdl-dev but it is not going to be installed
locales : Depends: glibc-2.13-1 but it is not installable
zlib1g-dev : Depends: libc6-dev but it is not going to be installed or
                       libc-dev
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
安装Da之前的这些东西总是装不上。Debian6 64位
发表于 2013-5-30 12:39:37 来自手机 | 只看该作者
活着就是折腾,到此一游!
发表于 2013-5-30 12:41:24 | 只看该作者
没遇过
发表于 2013-5-30 12:58:39 | 只看该作者
为什么一定要用debian
 楼主| 发表于 2013-5-30 13:01:18 | 只看该作者
orvice 发表于 2013-5-30 12:58
为什么一定要用debian
不行就换回centos~
发表于 2013-5-30 13:02:42 | 只看该作者
8QE 发表于 2013-5-30 13:01
不行就换回centos~
装BSD吧。。
GMT+8, 2026-4-23 19:51 , Processed in 0.196784 second(s), 11 queries , Gzip On, MemCache On.
