查看: 6542|回复: 16
美团云主机的评测。。。。
发表于 2013-5-15 01:24:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
自己花钱买了个当小白鼠~~
考虑可能尝试投个稿什么的,就只放个跑分吧
具体的可以去博客看:http://www.btdou.com/meiyuan-20130514.html
  1. ##跑分测试。总分 1180
  2. ##标准参考:总分低于400的就算性能低下;600-800是属于正常VPS水准;超过1000分性能就算给力。
  3. ================================================================
  4.    BYTE UNIX Benchmarks (Version 5.1.2)
  5.    System: vm.cloud.mos.meituan.com: GNU/Linux
  6.    OS: GNU/Linux -- 2.6.32-358.2.1.el6.x86_64 -- #1 SMP Wed Mar 13 00:26:49 UTC 2013
  7.    Machine: x86_64 (x86_64)
  8.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  9.    CPU 0: QEMU Virtual CPU version 1.1.2 (4000.0 bogomips)
  10.           x86-64, MMX, Physical Address Ext, SYSENTER/SYSEXIT, SYSCALL/SYSRET
  11.    00:29:27 up  1:48,  2 users,  load average: 1.01, 1.03, 0.71; runlevel 3
  12. --------------------------------------------------------------
  13. Benchmark Run: Wed May 15 2013 00:29:27 - 00:57:06
  14. 1 CPU in system; running 1 parallel copy of tests
  15. Dhrystone 2 using register variables       25912748.5 lps   (10.0 s, 7 samples)
  16. Double-Precision Whetstone                     1625.7 MWIPS (8.3 s, 7 samples)
  17. Execl Throughput                               4031.5 lps   (29.9 s, 2 samples)
  18. File Copy 1024 bufsize 2000 maxblocks        801801.2 KBps  (30.0 s, 2 samples)
  19. File Copy 256 bufsize 500 maxblocks          223378.7 KBps  (30.0 s, 2 samples)
  20. File Copy 4096 bufsize 8000 maxblocks       1791722.0 KBps  (30.0 s, 2 samples)
  21. Pipe Throughput                             1489713.8 lps   (10.0 s, 7 samples)
  22. Pipe-based Context Switching                 285828.2 lps   (10.0 s, 7 samples)
  23. Process Creation                              14354.1 lps   (30.0 s, 2 samples)
  24. Shell Scripts (1 concurrent)                   4669.2 lpm   (60.0 s, 2 samples)
  25. Shell Scripts (8 concurrent)                    632.2 lpm   (60.1 s, 2 samples)
  26. System Call Overhead                        1875463.2 lps   (10.0 s, 7 samples)
  27. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  28. Dhrystone 2 using register variables         116700.0   25912748.5   2220.5
  29. Double-Precision Whetstone                       55.0       1625.7    295.6
  30. Execl Throughput                                 43.0       4031.5    937.6
  31. File Copy 1024 bufsize 2000 maxblocks          3960.0     801801.2   2024.8
  32. File Copy 256 bufsize 500 maxblocks            1655.0     223378.7   1349.7
  33. File Copy 4096 bufsize 8000 maxblocks          5800.0    1791722.0   3089.2
  34. Pipe Throughput                               12440.0    1489713.8   1197.5
  35. Pipe-based Context Switching                   4000.0     285828.2    714.6
  36. Process Creation                                126.0      14354.1   1139.2
  37. Shell Scripts (1 concurrent)                     42.4       4669.2   1101.2
  38. Shell Scripts (8 concurrent)                      6.0        632.2   1053.6
  39. System Call Overhead                          15000.0    1875463.2   1250.3
  40.        ========
  41. System Benchmarks Index Score                                        1180.8
发表于 2013-5-15 01:25:47 | 只看该作者
还行。。。
 楼主| 发表于 2013-5-15 01:29:03 | 只看该作者
aarwwefdds 发表于 2013-5-15 01:25
还行。。。
估计现在基本是空载
发表于 2013-5-15 01:34:26 | 只看该作者
北岸政策怎么样
发表于 2013-5-15 01:39:48 | 只看该作者
还不错
发表于 2013-5-15 01:50:33 | 只看该作者
纳豆妹妹神速
序号 Ping的地点 响应IP 响应时间 TTL
4 云南昆明[电信] 106.3.*.* 2211毫秒 54
看来云南这个ping节点MJJ
发表于 2013-5-15 01:56:25 | 只看该作者
没钱买
发表于 2013-5-15 01:58:57 | 只看该作者
网络不错啊,1MB跑出这速度来,哈哈,如果能保持这个速度我都想买个。
发表于 2013-5-15 05:21:49 来自手机 | 只看该作者
架构那个很简单,拿个软件测试就出来了
发表于 2013-5-15 08:13:01 | 只看该作者
挺好的
GMT+8, 2026-4-22 14:22 , Processed in 0.288366 second(s), 12 queries , Gzip On, MemCache On.
