查看: 2847|回复: 7
申请IP 机房要求回答问题。有高手帮我解答吗?
发表于 2013-5-8 17:19:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我晕。申请的253个IP.
The documentation you have provided is fine in terms of the manner in which you intend to use the address space. As explained in our previous responses, in addition to that,  we must confirm that at least 80% of their previously allocated IP address space, both from us and other sources, is in use. You have indicated that you have address space assigned from other providers, and as such, we need a listing of that IP space from the other provider, and details which demonstrate that at least 80% of those addresses are in use.
发表于 2013-5-8 17:22:58 | 只看该作者
楼下来
 楼主| 发表于 2013-5-8 17:42:00 | 只看该作者
网者归来 发表于 2013-5-8 17:22
楼下来
谢谢
发表于 2013-5-8 17:45:37 | 只看该作者
不懂英语的我土鳖翻译 不能一次申请那么多  而且已申请的 需要用掉 80% 才可以继续申请
楼下继续
 楼主| 发表于 2013-5-8 17:54:59 | 只看该作者
楼下继续 ...
难道我需要建立了站才能使用
发表于 2013-5-8 18:03:43 | 只看该作者
你需要证明之前他家和别家分配给你的IP80%以上都在使用
给他一个名单
 楼主| 发表于 2013-5-8 20:03:22 | 只看该作者
给他一个名单
谢谢
发表于 2013-5-8 20:23:05 | 只看该作者
search 发表于 2013-5-8 20:03
谢谢
客气了
GMT+8, 2026-4-15 20:38 , Processed in 0.199930 second(s), 12 queries , Gzip On, MemCache On.
