查看: 6098|回复: 12
[Windows VPS] Google Voice在选号码的时候老是错误是怎么回事?
发表于 2013-4-28 11:08:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我以前申请过,没有这么麻烦,很容易就弄好了,现在再弄个,发现在选号的时候无论你选择什么号码都会出现如下图错误
有人遇到过这种问题吗?这个该怎么解决啊
 楼主| 发表于 2013-4-28 11:10:10 | 只看该作者
是不是现在太严格了不好搞了?
发表于 2013-4-28 11:13:48 | 只看该作者
一样 多次都不成功
 楼主| 发表于 2013-4-28 11:53:02 | 只看该作者
阿门 发表于 2013-4-28 11:13
一样 多次都不成功
找到原因了,我用来接收验证码的电话以前注册过GV……
发表于 2013-4-28 11:55:09 | 只看该作者
那我以前也没注册过  情况差不多
 楼主| 发表于 2013-4-28 12:11:49 | 只看该作者
I was getting the same error but I was able to add a number.
This is what I did.
I removed the forwarding number that I had entered the first time. It seems that the system had an error with this number and it was causing the problem, it is not easy to remove the forwarding number, it did not show in the Setting panel, I did not have a "Phones" tab so, to delete the forwarding number I first selected Google Lite and I indicated that the forwarding number was a cell phone number even when it was not, then after I got a GV access number I got the "Phones" tab in the Settings panel, then I was able to remove the forwarding number and I logged out from GV.
I did login again and get a new GV number but this time when the GV asked me to enter my forwarding number I used a different number than the one I used the first time (using the same forwarding number that I used the first time was not working), then I was able to select a GV number. I then added the first forwarding number and GV let me add it, after I added the first forwarding number I removed the second temporary forwarding number that I used to get the GV number.
看到谷歌论坛上有一个解决办法 但不知道怎么操作 哪位来解说一下
发表于 2013-4-28 12:40:19 | 只看该作者
楼主直接买一个吧 才2-3元一个
折腾不起时间
 楼主| 发表于 2013-4-28 14:11:40 | 只看该作者
xyz 发表于 2013-4-28 12:40
楼主直接买一个吧 才2-3元一个
折腾不起时间
这个以前注册过 我自己会弄 就是现在那一步过不了
发表于 2013-4-28 14:40:11 | 只看该作者
发表于 2013-4-28 14:41:20 | 只看该作者
这个我折腾过几天。。还是不行
GMT+8, 2026-4-15 07:41 , Processed in 0.129109 second(s), 13 queries , Gzip On, MemCache On.
