查看: 3423|回复: 14
快易互联芝加哥1G内存VPS仅售79块/月
发表于 2013-4-28 00:16:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
配置参数:
2核心CPU
40G raid10硬盘
1G内存
仅售79元/月
直接登陆my.kiiyi.com选择芝加哥机房购买
或者点击直接购买链接:my.kiiyi.com/index.aspx?c=order&ptype=1&pid=170
DD测试:
  1. dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  2. 4096+0 records in
  3. 4096+0 records out
  4. 268435456 bytes (268 MB) copied, 2.95248 seconds, 90.9 MB/s
  5. dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  6. 4096+0 records in
  7. 4096+0 records out
  8. 268435456 bytes (268 MB) copied, 2.98898 seconds, 89.8 MB/s
  9. dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  10. 4096+0 records in
  11. 4096+0 records out
  12. 268435456 bytes (268 MB) copied, 3.15219 seconds, 85.2 MB/s
  13. dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  14. 4096+0 records in
  15. 4096+0 records out
  16. 268435456 bytes (268 MB) copied, 3.2866 seconds, 81.7 MB/s
wget测试
  1. wget http://cachefly.cachefly.net/100mb.test
  2. --2013-04-21 01:47:15--  http://cachefly.cachefly.net/100mb.test
  3. Resolving cachefly.cachefly.net... 205.234.175.175
  4. Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
  5. HTTP request sent, awaiting response... 200 OK
  6. Length: 104857600 (100M) [application/octet-stream]
  7. Saving to: `100mb.test'
  8. 2013-04-21 01:47:24 (11.2 MB/s) - `100mb.test' saved [104857600/104857600]
UB跑分测试
  1. ===========================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.2)
  3.    System: MyVPS: GNU/Linux
  4.    OS: GNU/Linux -- 2.6.18-238.5.1.el5xen -- #1 SMP Fri Apr 1 20:27:35 EDT 2011
  5.    Machine: i686 (i386)
  6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  7.    CPU 0: Intel(R) Xeon(R) CPU E3-1270 V2 @ 3.50GHz (8731.5 bogomips)
  8.           Hyper-Threading, MMX, Physical Address Ext
  9.    CPU 1: Intel(R) Xeon(R) CPU E3-1270 V2 @ 3.50GHz (8731.5 bogomips)
  10.           Hyper-Threading, MMX, Physical Address Ext
  11.    01:47:33 up 21 min,  1 user,  load average: 1.44, 1.36, 0.82; runlevel 3
  12. ------------------------------------------------------------------------
  13. Benchmark Run: Sun Apr 21 2013 01:47:33 - 02:15:43
  14. 2 CPUs in system; running 1 parallel copy of tests
  15. Dhrystone 2 using register variables       19582872.3 lps   (10.0 s, 7 samples)
  16. Double-Precision Whetstone                     3065.7 MWIPS (10.1 s, 7 samples)
  17. Execl Throughput                               3076.5 lps   (30.0 s, 2 samples)
  18. File Copy 1024 bufsize 2000 maxblocks        628523.6 KBps  (30.0 s, 2 samples)
  19. File Copy 256 bufsize 500 maxblocks          166876.4 KBps  (30.0 s, 2 samples)
  20. File Copy 4096 bufsize 8000 maxblocks       1894694.6 KBps  (30.0 s, 2 samples)
  21. Pipe Throughput                              910204.0 lps   (10.0 s, 7 samples)
  22. Pipe-based Context Switching                 143416.0 lps   (10.0 s, 7 samples)
  23. Process Creation                               6405.8 lps   (30.0 s, 2 samples)
  24. Shell Scripts (1 concurrent)                   5936.4 lpm   (60.0 s, 2 samples)
  25. Shell Scripts (8 concurrent)                   1252.0 lpm   (60.0 s, 2 samples)
  26. System Call Overhead                         637841.6 lps   (10.0 s, 7 samples)
  27. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  28. Dhrystone 2 using register variables         116700.0   19582872.3   1678.1
  29. Double-Precision Whetstone                       55.0       3065.7    557.4
  30. Execl Throughput                                 43.0       3076.5    715.5
  31. File Copy 1024 bufsize 2000 maxblocks          3960.0     628523.6   1587.2
  32. File Copy 256 bufsize 500 maxblocks            1655.0     166876.4   1008.3
  33. File Copy 4096 bufsize 8000 maxblocks          5800.0    1894694.6   3266.7
  34. Pipe Throughput                               12440.0     910204.0    731.7
  35. Pipe-based Context Switching                   4000.0     143416.0    358.5
  36. Process Creation                                126.0       6405.8    508.4
  37. Shell Scripts (1 concurrent)                     42.4       5936.4   1400.1
  38. Shell Scripts (8 concurrent)                      6.0       1252.0   2086.6
  39. System Call Overhead                          15000.0     637841.6    425.2
  40.        ========
  41. System Benchmarks Index Score                                         955.6
  42. ------------------------------------------------------------------------
  43. Benchmark Run: Sun Apr 21 2013 02:15:43 - 02:43:55
  44. 2 CPUs in system; running 2 parallel copies of tests
  45. Dhrystone 2 using register variables       39121632.3 lps   (10.0 s, 7 samples)
  46. Double-Precision Whetstone                     6134.5 MWIPS (10.0 s, 7 samples)
  47. Execl Throughput                               5997.0 lps   (30.0 s, 2 samples)
  48. File Copy 1024 bufsize 2000 maxblocks        352253.9 KBps  (30.0 s, 2 samples)
  49. File Copy 256 bufsize 500 maxblocks          101819.7 KBps  (30.0 s, 2 samples)
  50. File Copy 4096 bufsize 8000 maxblocks       1432634.2 KBps  (30.0 s, 2 samples)
  51. Pipe Throughput                             1821005.4 lps   (10.0 s, 7 samples)
  52. Pipe-based Context Switching                 287111.8 lps   (10.0 s, 7 samples)
  53. Process Creation                              11841.3 lps   (30.0 s, 2 samples)
  54. Shell Scripts (1 concurrent)                   9429.8 lpm   (60.0 s, 2 samples)
  55. Shell Scripts (8 concurrent)                   1494.2 lpm   (60.1 s, 2 samples)
  56. System Call Overhead                        1238048.2 lps   (10.0 s, 7 samples)
  57. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  58. Dhrystone 2 using register variables         116700.0   39121632.3   3352.3
  59. Double-Precision Whetstone                       55.0       6134.5   1115.4
  60. Execl Throughput                                 43.0       5997.0   1394.7
  61. File Copy 1024 bufsize 2000 maxblocks          3960.0     352253.9    889.5
  62. File Copy 256 bufsize 500 maxblocks            1655.0     101819.7    615.2
  63. File Copy 4096 bufsize 8000 maxblocks          5800.0    1432634.2   2470.1
  64. Pipe Throughput                               12440.0    1821005.4   1463.8
  65. Pipe-based Context Switching                   4000.0     287111.8    717.8
  66. Process Creation                                126.0      11841.3    939.8
  67. Shell Scripts (1 concurrent)                     42.4       9429.8   2224.0
  68. Shell Scripts (8 concurrent)                      6.0       1494.2   2490.3
  69. System Call Overhead                          15000.0    1238048.2    825.4
  70.        ========
  71. System Benchmarks Index Score                                        1334.2
发表于 2013-4-28 00:38:01 | 只看该作者
不错机器,靠谱公司,值得入手。
发表于 2013-4-28 02:15:46 | 只看该作者
发表于 2013-4-28 08:38:34 | 只看该作者
发表于 2013-4-28 08:40:01 | 只看该作者
JJ搞唧唧
发表于 2013-4-28 09:17:28 | 只看该作者
全管理型 大家懂
发表于 2013-4-28 12:11:37 | 只看该作者
川总你不忙么
发表于 2013-4-28 14:40:26 | 只看该作者
当小广告插在文章里了~~
发表于 2013-4-28 16:33:18 | 只看该作者
这个要支持,服务是相当的好
发表于 2013-4-28 19:32:03 | 只看该作者
也是全管理?
GMT+8, 2026-4-15 21:42 , Processed in 0.124296 second(s), 13 queries , Gzip On, MemCache On.
