查看: 2034|回复: 7
申请IP 机房要求回答问题。有高手帮我解答吗?
发表于 2013-3-7 23:59:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我说卖VPS  他问我4个问题。我晕。申请的253个IP.
Thank you for getting back with us. In order to approve your request, we will need some additional information. Please provide
responses to the following 4 questions.
1 - How many VPS servers will you be creating immediately using the requested IP address space?
2 - What is the total number of IP addresses that the VPS servers you will be creating immediately (as identified in #1 above)
will use?
3 - How many VPS servers do you anticipate creating in one years time using the requested IP address space?
4 - What is the total number of IP addresses you expect that the VPS servers you anticipate creating in one years time (as
identified in #3 above) will use?
Please get back to us with responses to those questions at your convenience. Thank you in advance.
发表于 2013-3-8 00:00:19 | 只看该作者
这些问题的答案只有你知道吧。。。?
发表于 2013-3-8 00:01:36 | 只看该作者
这些问题的答案只有你知道吧。。。?
发表于 2013-3-8 00:02:25 | 只看该作者
这些问题的答案只有你知道吧。。。?
 楼主| 发表于 2013-3-8 00:04:41 | 只看该作者
为了申请到IP  还有什么理由么?
发表于 2013-3-8 00:10:00 | 只看该作者
UBI的。。
发表于 2013-3-8 00:13:31 | 只看该作者
目测ubi机房
60 ips
will use?
193 ips
4 - What is the total number of IP addresses you expect that the VPS servers you anticipate creating in one years time (asidentified in #3 above) will use?
I will give 1 IP addresses on average provisioned per vps, 253 projected customers within one year
发表于 2013-3-8 00:16:41 | 只看该作者
什么配置 ?
GMT+8, 2026-4-15 06:44 , Processed in 0.072876 second(s), 9 queries , Gzip On, MemCache On.
