查看: 3960|回复: 10
组长的福利VPS评测来了~~~
发表于 2013-3-5 17:43:06 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
组长好人~~~
不多废话了 直接上数据了
详细可以看:http://www.btdou.com/hostshare-201302305.html
  1. ##Nginx安装时间测试 12 分钟
  2. Nginx is runing!
  3. php-fpm is runing!
  4. SUCCESS! MySQL running (11764)
  5. Active Internet connections (only servers)
  6. Proto Recv-Q Send-Q Local Address               Foreign Address             State
  7. tcp        0      0 0.0.0.0:3306                0.0.0.0:*                   LISTEN
  8. tcp        0      0 0.0.0.0:80                  0.0.0.0:*                   LISTEN
  9. tcp        0      0 0.0.0.0:22                  0.0.0.0:*                   LISTEN
  10. tcp        0      0 :::22                       :::*                        LISTEN
  11. real        12m55.463s
  12. user        9m4.066s
  13. sys        2m21.525s
  1. ##CPU信息
  2. cat /proc/cpuinfo
  3. processor        : 0
  4. vendor_id        : GenuineIntel
  5. cpu family        : 6
  6. model                : 58
  7. model name        : Intel(R) Xeon(R) CPU E3-1270 V2 @ 3.50GHz
  8. stepping        : 9
  9. cpu MHz                : 3500.026
  10. cache size        : 8192 KB
  11. fdiv_bug        : no
  12. hlt_bug                : no
  13. f00f_bug        : no
  14. coma_bug        : no
  15. fpu                : yes
  16. fpu_exception        : yes
  17. cpuid level        : 13
  18. wp                : yes
  19. flags                : fpu de tsc msr pae cx8 apic cmov pat clflush acpi mmx fxsr sse sse2 ss ht nx constant_tsc up nonstop_tsc pni ssse3 sse4_1 sse4_2 popcnt [8]
  20. bogomips        : 8757.56
  1. ##硬盘I/O测试
  2. ##参考标准:如果超过10M,对正常建站就无影响。超过50M,就是非常给力状态
  3. dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  4. 4096+0 records in
  5. 4096+0 records out
  6. 268435456 bytes (268 MB) copied, 6.88391 seconds, 39.0 MB/s
  7. dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  8. 4096+0 records in
  9. 4096+0 records out
  10. 268435456 bytes (268 MB) copied, 5.30414 seconds, 50.6 MB/s
  11. dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  12. 4096+0 records in
  13. 4096+0 records out
  14. 268435456 bytes (268 MB) copied, 5.03841 seconds, 53.3 MB/s
  15. dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  16. 4096+0 records in
  17. 4096+0 records out
  18. 268435456 bytes (268 MB) copied, 4.97853 seconds, 53.9 MB/s
  1. ##带宽测试
  2. wget http://cachefly.cachefly.net/100mb.test
  3. --2013-03-05 16:36:37--  http://cachefly.cachefly.net/100mb.test
  4. Resolving cachefly.cachefly.net... 205.234.175.175
  5. Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
  6. HTTP request sent, awaiting response... 200 OK
  7. Length: 104857600 (100M) [application/octet-stream]
  8. Saving to: `100mb.test'
  9. 2013-03-05 16:36:41 (34.4 MB/s) - `100mb.test' saved [104857600/104857600]
  1. ##跑分测试。总分 948.8
  2. ##标准参考:总分低于400的就算性能低下;600-800是属于正常VPS水准;超过1000分性能就算给力。
  3. ------------------------------------------------------------------------
  4. Benchmark Run: Tue Mar 05 2013 16:36:46 - 17:04:56
  5. 1 CPU in system; running 1 parallel copy of tests
  6. Dhrystone 2 using register variables       19614062.1 lps   (10.0 s, 7 samples)
  7. Double-Precision Whetstone                     3065.0 MWIPS (10.0 s, 7 samples)
  8. Execl Throughput                               3417.0 lps   (30.0 s, 2 samples)
  9. File Copy 1024 bufsize 2000 maxblocks        700831.5 KBps  (30.0 s, 2 samples)
  10. File Copy 256 bufsize 500 maxblocks          186621.2 KBps  (30.0 s, 2 samples)
  11. File Copy 4096 bufsize 8000 maxblocks       1967986.5 KBps  (30.0 s, 2 samples)
  12. Pipe Throughput                              938423.1 lps   (10.0 s, 7 samples)
  13. Pipe-based Context Switching                 148909.4 lps   (10.0 s, 7 samples)
  14. Process Creation                               6629.4 lps   (30.0 s, 2 samples)
  15. Shell Scripts (1 concurrent)                   5527.5 lpm   (60.0 s, 2 samples)
  16. Shell Scripts (8 concurrent)                    771.7 lpm   (60.1 s, 2 samples)
  17. System Call Overhead                         639642.1 lps   (10.0 s, 7 samples)
  18. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  19. Dhrystone 2 using register variables         116700.0   19614062.1   1680.7
  20. Double-Precision Whetstone                       55.0       3065.0    557.3
  21. Execl Throughput                                 43.0       3417.0    794.6
  22. File Copy 1024 bufsize 2000 maxblocks          3960.0     700831.5   1769.8
  23. File Copy 256 bufsize 500 maxblocks            1655.0     186621.2   1127.6
  24. File Copy 4096 bufsize 8000 maxblocks          5800.0    1967986.5   3393.1
  25. Pipe Throughput                               12440.0     938423.1    754.4
  26. Pipe-based Context Switching                   4000.0     148909.4    372.3
  27. Process Creation                                126.0       6629.4    526.1
  28. Shell Scripts (1 concurrent)                     42.4       5527.5   1303.7
  29. Shell Scripts (8 concurrent)                      6.0        771.7   1286.2
  30. System Call Overhead                          15000.0     639642.1    426.4
  31.        ========
  32. System Benchmarks Index Score                                         948.8
发表于 2013-3-5 17:43:47 | 只看该作者
月姐姐家18元XEN VPS
发表于 2013-3-5 17:44:16 | 只看该作者
前排留名。。偶还没联系组长呢。
发表于 2013-3-5 17:45:17 | 只看该作者
路过
发表于 2013-3-5 17:52:09 | 只看该作者
性能不错啊
 楼主| 发表于 2013-3-5 17:53:22 | 只看该作者
ccc 发表于 2013-3-5 17:43
月姐姐家18元XEN VPS
月妹纸~~~
发表于 2013-3-5 17:58:16 | 只看该作者
速度不错哦
发表于 2013-3-5 18:04:08 | 只看该作者
发表于 2013-3-5 18:09:13 | 只看该作者
这个我也有
发表于 2013-3-5 18:11:06 | 只看该作者
还没有安装呢   晚上来测试
GMT+8, 2026-5-4 11:38 , Processed in 0.503943 second(s), 11 queries , Gzip On, MemCache On.
