查看: 3994|回复: 15
Get 50% off your first year! (+ XEN Announcement)
发表于 2013-3-3 14:32:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hello chen stone (NO),
We are going to start off this email by informing all of you that we (123Systems) have began working to expand our virtual server offers to include XEN based virtual servers. This has been a long planning process to determine how much of our current client base would like to have a XEN based virtual server over an OpenVZ based virtual server. We recently published a survey on our 推特 feed asking people to take the survey and we really liked the results that we have received so far and now we have began the process of determining when and how we intend to deploy XEN.
This is no longer a debate about if we will release the XEN offerings but now it is how and when, we have decided that we will be bringing them on board and offering them sometime in the near future. Be sure to check your email and our 推特 feed for more updates on this! Were you not aware of the survey? Take it now!
http://www.surveymonkey.com/s/RHY8HZZ
Now we go on to the current OpenVZ offerings that we are offering you guy's today, this promotional is a combination promotional. If you order an OpenVZ virtual server with this promotional, you will be able to transfer the promotional over to your XEN virtual server (if you choose to purchase one) when we do release them. If for example, you chose to purchase a Linux-256MB-SolusVM package with this promotional, when we release the XEN plans you can carry over the promotional and apply it to any of our XEN packages when we release them. We do not plan to offer a 50% yearly promotional for our XEN packages, so you would need to have this promotional in order to obtain 50% off your first year when we release the XEN packages.
If anything about this promotional is unclear, please email us and we will be sure to explain it the best we can! To put it in simple terms, if you order an OpenVZ VPS with the promotional, you will be able to use the same promotional on any XEN package when we release them.
The promotional code is: VZXENCOMBO | This promotional will give you 50% off your first year (If you purchase with this promotional you will be able to obtain a XEN virtual server with the coupon even after the first year, you only need to have used it once and you're locked in for life!)
Direct order links: (Promotional only applies to the packages listed below!!)
Linux-256-SolusVM: https://123systems.net/billing/cart.php?a=add&pid=101
Linux-512-SolusVM: https://123systems.net/billing/cart.php?a=add&pid=102
Linux-1GB-SolusVM: https://123systems.net/billing/cart.php?a=add&pid=104
Linux-2GB-SolusVM: https://123systems.net/billing/cart.php?a=add&pid=105
(You can not use the promotional to purchase any promotional package or the 128MB & 192MB yearly packages that we offer)
For all you minecraft clients out there, we haven't forgot about you. We intend to release a full XEN-RAM line of virtual servers just for you! The promotional code is the same as it is for the regular virtual servers, we have provided you with direct orders links as well.
Linux-1GB-RAM: https://123systems.net/billing/cart.php?a=add&pid=136
Linux-2GB-RAM: https://123systems.net/billing/cart.php?a=add&pid=137
Linux-3GB-RAM: https://123systems.net/billing/cart.php?a=add&pid=138
Linux-4GB-RAM: https://123systems.net/billing/cart.php?a=add&pid=171
We would like to thank everyone that has already taken the survey and would like to thank everyone that will be taking the survey, it is never a clear cut decision when it comes to bringing an entirely new product on board and our clients (you) have made it very clear so far that you would like to have XEN based offerings, therefore you shall receive it! We do not have a current ETA on when we will be releasing our first line of XEN offerings but we can tell you that it will be in the very near future.
Again, if anything about this promotional is unclear to you, please reply to this email or open a ticket and ask us anything that is unclear to you. We will do our best to answer your questions!
Not a big fan of these emails? Alright, we understand. Simply email us back and tell us to remove you from our mailing list.
Warm Regards,
Copyright 2009-2013 ©
123Systems Solutions™
http://www.123systems.net
Have any questions? Contact us!
https://www.123systems.net/billing/submitticket.php
Follow us on 推特 @123Systems
发表于 2013-3-3 14:35:55 | 只看该作者
............look look
发表于 2013-3-3 14:38:06 | 只看该作者
勇敢的快上。。。
如果真的要买,选最便宜的,然后加100GB硬盘(100刀一次性),再加2GB内存(100刀一次性) 。。。
之后每个月3刀。
发表于 2013-3-3 14:58:59 | 只看该作者
我是人 发表于 2013-3-3 14:38
勇敢的快上。。。
如果真的要买,选最便宜的,然后加100GB硬盘(100刀一次性),再加2GB内存(100刀一次性 ...
牛b。。。
发表于 2013-3-3 15:04:15 | 只看该作者
勇敢的快上。。。
200多刀。。。
发表于 2013-3-3 15:06:10 | 只看该作者
Mr.Ra1n 发表于 2013-3-3 15:04
200多刀。。。
你看Linode。。。2GB内存 / 96GB硬盘 每个月$79.95
当然,品质不一样。。。
发表于 2013-3-3 16:15:55 | 只看该作者
当然,品质不一样。。。
正因品质不一样。。。。。。。。。
发表于 2013-3-3 21:11:56 来自手机 | 只看该作者
勇敢的快上。。。
不是这意思吧
不是以后可以以50%买任何xen计划的vps么
发表于 2013-3-3 21:20:12 | 只看该作者
之后每个月3刀。
我一個 2G RAM , 100G HDD 的才 10 刀 1 個月.
買一個這樣的花兩百加下去,要用兩年半才打平.
有人 123system 已經用兩年半了的嗎?
发表于 2013-3-3 21:20:21 | 只看该作者
买不起的撸过
GMT+8, 2026-4-29 22:01 , Processed in 0.070537 second(s), 13 queries , Gzip On, MemCache On.
