查看: 4878|回复: 5
[Windows VPS] ..............
发表于 2013-2-15 22:18:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2013-2-15 22:21:31 | 只看该作者
看日志
 楼主| 发表于 2013-2-15 22:33:26 | 只看该作者
AH00015: Unable to open logs
求解。。。
 楼主| 发表于 2013-2-15 22:35:18 | 只看该作者
[Fri Feb 15 15:39:02.648750 2013] [auth_digest:notice] [pid 24782] AH01757: generating secret for digest authentication ...
[Fri Feb 15 15:39:04.116481 2013] [ssl:warn] [pid 24782] AH01909: RSA certificate configured for www.example.com:443 does NOT include an ID which matches the server name
[Fri Feb 15 15:39:04.116825 2013] [ssl:warn] [pid 24782] AH02292: Init: Name-based SSL virtual hosts only work for clients with TLS server name indication support (RFC 4366)
[Fri Feb 15 15:39:04.116857 2013] [lbmethod_heartbeat:notice] [pid 24782] AH02282: No slotmem from mod_heartmonitor
[Fri Feb 15 15:39:04.117353 2013] [mpm_prefork:notice] [pid 24782] AH00163: Apache/2.4.3 (Unix) OpenSSL/0.9.8o configured -- resuming normal operations
[Fri Feb 15 15:39:04.117362 2013] [core:notice] [pid 24782] AH00094: Command line: '/usr/sbin/httpd -D SSL'
发现还有这两行
发表于 2013-2-15 22:44:31 | 只看该作者
 楼主| 发表于 2013-2-15 23:02:21 | 只看该作者
单手摘月 发表于 2013-2-15 22:44
非常感谢,正在试,用的是apache2.4,不知道是不是版本的原因。。。
GMT+8, 2026-4-14 10:51 , Processed in 0.187552 second(s), 11 queries , Gzip On, MemCache On.
