楼主: David
[不限流量] 完美突破白名单封锁,实现免北岸接入
发表于 2013-2-5 22:38:37 | 只看该作者
用这个 还不如用有亚洲节点的CDN
发表于 2013-2-5 22:42:10 | 只看该作者
404 发表于 2013-2-5 22:27
其实就是反代........这问题就是...这样做了等于穿墙四次,往返中美两次, 还有个中转节点的数据安全问题... ...
正解!!!!DA、CP通过.htaccess同理可以
发表于 2013-2-5 22:56:51 | 只看该作者
无咩咩无真相
天下真相十斗  咩咩独占八斗
发表于 2013-2-5 22:58:31 | 只看该作者
搞的那么复杂!!!!!
发表于 2013-2-5 23:09:32 | 只看该作者
发表于 2013-2-5 23:12:03 | 只看该作者
mark,虽然觉得很蛋疼
发表于 2013-2-5 23:21:28 | 只看该作者
其实就是反代........这问题就是...这样做了等于穿墙四次,往返中美两次, 还有个中转节点的数据安全问题.........那为什么不直接用美国主机, 只要往返中美一次, 穿墙两次......
发表于 2013-2-6 00:01:25 | 只看该作者
哪个MJJ搞的这个玩意,自觉出来吧。
$ host cname.addon-domain.com
cname.addon-domain.com has address 184.82.44.115
$ whois 184.82.44.115
# Query terms are ambiguous.  The query is assumed to be:
#     "n 184.82.44.115"
# Use "?" to get help.
# The following results may also be obtained via:
# http://whois.arin.net/rest/nets;q=184.82.44.115?showDetails=true&showARIN=false&ext=netref2
NetRange:       184.82.0.0 - 184.82.255.255
CIDR:           184.82.0.0/16
OriginAS:       AS21788
NetName:        HOSTNOC-8BLK
NetHandle:      NET-184-82-0-0-1
Parent:         NET-184-0-0-0-0
NetType:        Direct Allocation
Comment:        SMA4-ARIN
RegDate:        2010-03-10
Updated:        2012-03-02
Ref:            http://whois.arin.net/rest/net/NET-184-82-0-0-1
OrgName:        Network Operations Center Inc.
OrgId:          NOC
Address:        PO Box 591
City:           Scranton
StateProv:      PA
PostalCode:     18501-0591
Country:        US
RegDate:        2001-04-04
Updated:        2011-09-24
Comment:        Abuse Dept: abuse@hostnoc.net
Ref:            http://whois.arin.net/rest/org/NOC
ReferralServer: rwhois://rwhois.hostnoc.net:4321
OrgTechHandle: SMA4-ARIN
OrgTechName:   Arcus, S. Matthew
OrgTechPhone:  +1-570-343-2200
OrgTechEmail:  nic@hostnoc.net
OrgTechRef:    http://whois.arin.net/rest/poc/SMA4-ARIN
OrgAbuseHandle: SMA4-ARIN
OrgAbuseName:   Arcus, S. Matthew
OrgAbusePhone:  +1-570-343-2200
OrgAbuseEmail:  nic@hostnoc.net
OrgAbuseRef:    http://whois.arin.net/rest/poc/SMA4-ARIN
RTechHandle: SMA4-ARIN
RTechName:   Arcus, S. Matthew
RTechPhone:  +1-570-343-2200
RTechEmail:  nic@hostnoc.net
RTechRef:    http://whois.arin.net/rest/poc/SMA4-ARIN
RNOCHandle: SMA4-ARIN
RNOCName:   Arcus, S. Matthew
RNOCPhone:  +1-570-343-2200
RNOCEmail:  nic@hostnoc.net
RNOCRef:    http://whois.arin.net/rest/poc/SMA4-ARIN
RAbuseHandle: SMA4-ARIN
RAbuseName:   Arcus, S. Matthew
RAbusePhone:  +1-570-343-2200
RAbuseEmail:  nic@hostnoc.net
RAbuseRef:    http://whois.arin.net/rest/poc/SMA4-ARIN
# ARIN WHOIS data and services are subject to the Terms of Use
# available at: https://www.arin.net/whois_tou.html
Found a referral to rwhois.hostnoc.net:4321.
%rwhois V-1.5:003fff:00 rwhois.hostnoc.net (by Network Solutions, Inc. V-1.5.9.5)
network:Class-Name:network
network:ID:NET-184.82.44.115/32
network:Auth-Area:184.82.0.0/16
network:network:NET-184.82.44.115/32
network:block:184.82.44.115/32
networkrganization;I:T0000031794
network:address:422 Prescott Avenue
network:city:Scranton
network:stateA
network:postalcode:18510
network:country:US
network:admin-c;I:A9000000001
network:tech-c;I:T0000031794
network:abuse-c;I:I9000000001
network:created:20121219080501
network:Updated:20121219080501
%ok
发表于 2013-2-6 00:30:04 | 只看该作者
反代,速度影响很大的,还不如直接放美国呢
20#
发表于 2013-2-6 01:22:30 来自手机 | 只看该作者
Service 发表于 2013-2-5 22:21
神马情况?这跟域名转发不是类似么?
反向代理
GMT+8, 2026-4-15 22:57 , Processed in 0.060929 second(s), 9 queries , Gzip On, MemCache On.
