查看: 6486|回复: 0
GoDaddy windows空间“full trust”权限说明
发表于 2008-6-6 18:43:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
If you are using ASP.NET 1.1 on your Windows shared hosting account, you have "full trust" on the server. If you are using .NET runtime environment 2.0, you have 'medium trust' on the server.
Trust level refers to permissions set in the Web.config file that dictate
what operations can and cannot be performed by Web applications.
使用 ASP.NET 1.1 的话 full trust 开启。
使用 ASP.NET 2.0 的话 full trust 不开启。
GMT+8, 2026-4-21 11:02 , Processed in 0.061423 second(s), 9 queries , Gzip On, MemCache On.
