查看: 2806|回复: 6
能分到个好母鸡是多么的重要啊,元芳,你怎么看?
发表于 2013-1-23 00:05:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
以下为 BlueVM 家两个母鸡对比测试,元芳,你怎么看?
母鸡A
  1. [root@xxx ~]# wget http://cachefly.cachefly.net/100mb.test
  2. --2013-01-22 17:41:26--  http://cachefly.cachefly.net/100mb.test
  3. Resolving cachefly.cachefly.net... 205.234.175.175
  4. Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
  5. HTTP request sent, awaiting response... 200 OK
  6. Length: 104857600 (100M) [application/octet-stream]
  7. Saving to: `100mb.test'
  8. 100%[===============================================================>] 104,857,600 70.7M/s   in 1.4s
  9. 2013-01-22 17:41:28 (70.7 MB/s) - `100mb.test' saved [104857600/104857600]
  10. [root@xxx ~]# wget http://cachefly.cachefly.net/100mb.test
  11. --2013-01-22 17:41:30--  http://cachefly.cachefly.net/100mb.test
  12. Resolving cachefly.cachefly.net... 205.234.175.175
  13. Connecting to cachefly.cachefly.net|205.234.175.175|:80... connected.
  14. HTTP request sent, awaiting response... 200 OK
  15. Length: 104857600 (100M) [application/octet-stream]
  16. Saving to: `100mb.test.1'
  17. 100%[===============================================================>] 104,857,600 71.2M/s   in 1.4s
  18. 2013-01-22 17:41:31 (71.2 MB/s) - `100mb.test.1' saved [104857600/104857600]
  1. [root@xxx ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  2. 4096+0 records in
  3. 4096+0 records out
  4. 268435456 bytes (268 MB) copied, 5.3491 seconds, 50.2 MB/s
  5. [root@xxx ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  6. 4096+0 records in
  7. 4096+0 records out
  8. 268435456 bytes (268 MB) copied, 4.77459 seconds, 56.2 MB/s
母鸡B
  1. [root@yyy ~]# wget http://cachefly.cachefly.net/100mb.test
  2. --2013-01-22 17:59:35--  http://cachefly.cachefly.net/100mb.test
  8. 100%[===============================================================>] 104,857,600 15.6M/s   in 7.2s
  9. 2013-01-22 17:59:42 (13.8 MB/s) - `100mb.test' saved [104857600/104857600]
  10. [root@yyy ~]# wget http://cachefly.cachefly.net/100mb.test
  11. --2013-01-22 17:59:45--  http://cachefly.cachefly.net/100mb.test
  17. 100%[===============================================================>] 104,857,600 13.8M/s   in 7.1s
  18. 2013-01-22 17:59:52 (14.0 MB/s) - `100mb.test.1' saved [104857600/104857600]
  1. [root@yyy ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  4. 268435456 bytes (268 MB) copied, 25.4198 seconds, 10.6 MB/s
  5. [root@yyy ~]# dd if=/dev/zero of=test bs=64k count=4k oflag=dsync
  8. 268435456 bytes (268 MB) copied, 25.2569 seconds, 10.6 MB/s
suzizi 该用户已被删除
发表于 2013-1-23 00:07:48 | 只看该作者
发表于 2013-1-23 00:17:17 | 只看该作者
二楼亮了
发表于 2013-1-23 00:17:29 | 只看该作者
的确重要。
发表于 2013-1-23 00:32:15 | 只看该作者
 楼主| 发表于 2013-1-23 00:40:46 | 只看该作者
suzizi 发表于 2013-1-23 00:07
不会是你想把第二个转让吧  http://www.loc.qiche.eu.org/thread-176705-1-1.html
你认为呢?
我会告诉你我可以让客服随便换母鸡的么
发表于 2013-1-23 01:43:23 | 只看该作者
哈哈没我觉得是的
GMT+8, 2026-4-30 04:41 , Processed in 0.209626 second(s), 14 queries , Gzip On, MemCache On.
