查看: 1226|回复: 9
dreamhost 看来要悲剧了。
发表于 2012-12-15 08:50:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
We're happy to share some great news with you - DreamHost is growing and expanding!
As a part of our many months of hard work to harden our network, improve stability, and strengthen our systems overall we've chosen to move into some new state-of-the-art data centers. This move so far has provided additional stability and redundancy for our customers and our network. As a part of these improvements we will be shutting down the Los Angeles Airport adjacent (LAX) data center where your site is currently hosted.
Your site will be migrated into our newest data center (located in the US - East Region, in Ashburn, Virginia) within about a week starting from December 16th. We are closely monitoring the migration process to make it as painless as possible. Please note, however, that you may experience some higher than usual loads while your data is being moved over, which may cause slower load times than usual on your websites. We apologize for the inconvenience this is causing.
Once the move has completed, we will notify you via email.
Important note, if you have third party DNS (your domain does not point to our nameservers) or other services that connect to your domain via the IP address: You will receive a follow up email, containing your new IP addresses. You will need to update those outside records to match ours within seven days from the completion of the move to avoid site downtime. Your new IP can also be viewed by clicking on DNS in the panel at this location (after we have migrated you):
https://panel.dreamhost.com/index.cgi?tree=domain.manage
发表于 2012-12-15 09:59:41 | 只看该作者
不懂
发表于 2012-12-15 08:51:05 来自手机 | 只看该作者
发表于 2012-12-15 08:53:48 | 只看该作者
杯具
发表于 2012-12-15 09:08:34 | 只看该作者
换鸡房,还会那么稳定那么快么~
 楼主| 发表于 2012-12-15 09:27:43 | 只看该作者
mapleaf 发表于 2012-12-15 09:08
换鸡房,还会那么稳定那么快么~
换到东岸去了。。
发表于 2012-12-15 09:58:02 | 只看该作者
什么意思
发表于 2012-12-15 10:00:40 | 只看该作者
蛋疼。。。找各种理由。。可能是资金回流吧。。。想套现了
发表于 2012-12-15 10:02:57 | 只看该作者
为毛我没有收到?
发表于 2012-12-15 10:12:22 | 只看该作者
以前用这个空间  那时候速度还行啊 现在。。。
GMT+8, 2026-5-4 13:58 , Processed in 0.203594 second(s), 14 queries , Gzip On, MemCache On.
