查看: 1278|回复: 10
昨天T到的008vps 简单测速云云
发表于 2012-12-9 17:17:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://www.loc.qiche.eu.org/thread-167465-1-1.html
机房是在San Jose的
↓↓↓↓↓↓Windows↓↓↓↓↓↓
Cpu是2核的X3440
chenboy_2012.12.09_17h07m46s.png (10.55 KB, 下载次数: 1) chenboy_2012.12.09_17h08m20s.png (12.87 KB, 下载次数: 1)
内存1G
下载速度
硬盘测试
ping测试
↑↑↑↑↑↑Windows结束↑↑↑↑↑↑
↓↓↓↓↓↓↓centos开始↓↓↓↓↓↓
Cpu
硬盘DD
网络
Benchmark Run: Sun Dec 09 2012 17:45:49 - 18:13:42
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       11074312.4 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2259.3 MWIPS (10.2 s, 7 samples)
Execl Throughput                               1827.1 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        130110.1 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           33145.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        566945.6 KBps  (30.0 s, 2 samples)
Pipe Throughput                              152662.7 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  49194.9 lps   (10.0 s, 7 samples)
Process Creation                               3679.6 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   3574.6 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    767.1 lpm   (60.0 s, 2 samples)
System Call Overhead                         481985.0 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   11074312.4    949.0
Double-Precision Whetstone                       55.0       2259.3    410.8
Execl Throughput                                 43.0       1827.1    424.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     130110.1    328.6
File Copy 256 bufsize 500 maxblocks            1655.0      33145.0    200.3
File Copy 4096 bufsize 8000 maxblocks          5800.0     566945.6    977.5
Pipe Throughput                               12440.0     152662.7    122.7
Pipe-based Context Switching                   4000.0      49194.9    123.0
Process Creation                                126.0       3679.6    292.0
Shell Scripts (1 concurrent)                     42.4       3574.6    843.1
Shell Scripts (8 concurrent)                      6.0        767.1   1278.6
System Call Overhead                          15000.0     481985.0    321.3
System Benchmarks Index Score                                         399.0
Benchmark Run: Sun Dec 09 2012 18:13:42 - 18:41:39
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       19650727.2 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4447.5 MWIPS (10.2 s, 7 samples)
Execl Throughput                               3580.3 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks         95050.7 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           24631.7 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        681950.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                              278951.2 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  90680.4 lps   (10.0 s, 7 samples)
Process Creation                               6724.3 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   5563.9 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    808.1 lpm   (60.1 s, 2 samples)
System Call Overhead                         883110.9 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   19650727.2   1683.9
Double-Precision Whetstone                       55.0       4447.5    808.6
Execl Throughput                                 43.0       3580.3    832.6
File Copy 1024 bufsize 2000 maxblocks          3960.0      95050.7    240.0
File Copy 256 bufsize 500 maxblocks            1655.0      24631.7    148.8
File Copy 4096 bufsize 8000 maxblocks          5800.0     681950.4   1175.8
Pipe Throughput                               12440.0     278951.2    224.2
Pipe-based Context Switching                   4000.0      90680.4    226.7
Process Creation                                126.0       6724.3    533.7
Shell Scripts (1 concurrent)                     42.4       5563.9   1312.3
Shell Scripts (8 concurrent)                      6.0        808.1   1346.8
System Call Overhead                          15000.0     883110.9    588.7
System Benchmarks Index Score                                         576.4
lnmp安装用时20分钟
↑↑↑↑↑↑↑centos结束↑↑↑↑↑↑
发表于 2012-12-9 17:18:21 | 只看该作者
发表于 2012-12-9 17:18:56 | 只看该作者
看起来不错
发表于 2012-12-9 17:19:39 | 只看该作者
100.42.239.34
st
哪漏了  发表于 2012-12-9 17:21
发表于 2012-12-9 17:20:39 | 只看该作者
一看IP就知道是peter的SJC
发表于 2012-12-9 17:21:49 | 只看该作者
发表于 2012-12-9 17:24:20 | 只看该作者
lazyzhu 发表于 2012-12-9 17:19
100.42.239.34
st
你这眼睛我服了  少打一个马赛克
发表于 2012-12-9 17:24:30 | 只看该作者
目测漏了56处
 楼主| 发表于 2012-12-9 17:49:43 | 只看该作者
哎哟 没看到那处
发表于 2012-12-9 17:51:08 | 只看该作者
测漏
GMT+8, 2026-4-22 16:15 , Processed in 0.211009 second(s), 16 queries , Gzip On, MemCache On.
