查看: 2360|回复: 11
[Windows VPS] 求高手解答,服务器定期出这个消息是什么意思啊?
发表于 2012-12-5 03:42:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
发表于 2012-12-5 03:45:10 | 只看该作者
中断处理异常?
 楼主| 发表于 2012-12-5 03:46:42 | 只看该作者
发表于 2012-12-5 08:00:06 | 只看该作者
意思就是,我快挂了。
发表于 2012-12-5 09:03:06 | 只看该作者
不知道,帮顶
发表于 2012-12-5 09:46:38 | 只看该作者
看上去像是挂了马,接受IRC的遥控。
发表于 2012-12-5 09:56:29 | 只看该作者
估计是PCI槽上的某个设备坏了。做一下检测吧。
  1. http://forum.mandriva.com/viewtopic.php?t=122830
  2. Spurious interrupts can be generated by hardware by one of the following reasons:
  3. a) faulty hardware
  4. b) bad driver has enabled the PCI device's hardware interrupt but failed to register an interrupt service routine for that IRQ number
  5. c) bad driver has failed to chain interrupt handlers together for a shared IRQ
  6. d) misbehaving APIC (programmable interrupt controller) routes the PCI device's hardware interrupt to the wrong IRQ
  7. If you get a spurious interrupt then it means a device has been enabled but no software is servicing it properly. You should look for PCI devices that do not work.
  8. To look at the PCI devices, as root (superuser) do
  9. Code:
  10. lspci -v
  11. You might be able to see PCI device(s) that is using IRQ 83.
  12. To look at registered Interrupt handlers do
  13. Code:
  14. cat /proc/interrupts
  15. You should see a list of drivers names in the right-hand column. Are there any drivers listed for IRQ number 83 ? Note that IRQs can be shared between devices.
  16. You could disable the APIC by adding "noapic" to the kernel command line options in /boot/grub/menu.lst. If you know grub then you can try doing it interactively at boot-up.
  17. Look in /var/log/syslog, search for "syslogd" to find the start of a boot up sequence. Is there any mention of IRQ 83 ?
  18. There is a command called "dmesg" that will show some debug information from the kernel, that might help. Best used after the first pop-up is seen after a reboot.
  19. http://kerneltrap.org/mailarchive/linux-kernel/2008/7/27/2708354
  20. My guess is some device is that some device is generating MSI interrupts
  21. without any handler being registered for it, and with MSI support
  22. disabled it now generates a master abort instead. Most likely whatever
  23. device is connected to the Bus=00h, Device=02h, Function=00h bridge. Can
  24. you post "lspci -vv" output?
发表于 2012-12-5 09:57:29 | 只看该作者
看不懂 帮顶
发表于 2012-12-5 10:28:05 | 只看该作者
额  不是很懂  我只是提供服务器的
需要 国内电信  双线 美国KT机房的 独立服务器的话联系我吧
QQ 97150792
 楼主| 发表于 2012-12-5 12:53:58 | 只看该作者
GMT+8, 2026-1-15 07:13 , Processed in 0.127896 second(s), 12 queries , Gzip On, MemCache On.
