查看: 1409|回复: 2
KVM性能如此强劲?
发表于 2012-11-7 17:52:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
errantweb.com 256M
  1. ========================================================================
  2.    BYTE UNIX Benchmarks (Version 5.1.3)
  3.    System: localhost: GNU/Linux
  4.    OS: GNU/Linux -- 3.2.0-32-generic-pae -- #51-Ubuntu SMP Wed Sep 26 21:54:23 U        TC 2012
  5.    Machine: i686 (i386)
  6.    Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
  7.    CPU 0: QEMU Virtual CPU version (cpu64-rhel6) (6385.5 bogomips)
  8.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSCALL/SYSRET
  9.    CPU 1: QEMU Virtual CPU version (cpu64-rhel6) (6385.5 bogomips)
  10.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSCALL/SYSRET
  11.    CPU 2: QEMU Virtual CPU version (cpu64-rhel6) (6385.5 bogomips)
  12.           Hyper-Threading, x86-64, MMX, Physical Address Ext, SYSCALL/SYSRET
  13.    02:53:54 up  3:32,  2 users,  load average: 0.00, 0.01, 0.05; runlevel 2
  14. ------------------------------------------------------------------------
  1. System Benchmarks Index Values               BASELINE       RESULT    INDEX
  2. Dhrystone 2 using register variables         116700.0   20706222.8   1774.3
  3. Double-Precision Whetstone                       55.0       3592.6    653.2
  4. Execl Throughput                                 43.0       1921.7    446.9
  5. File Copy 1024 bufsize 2000 maxblocks          3960.0     804802.1   2032.3
  6. File Copy 256 bufsize 500 maxblocks            1655.0     211864.9   1280.2
  7. File Copy 4096 bufsize 8000 maxblocks          5800.0    2090268.5   3603.9
  8. Pipe Throughput                               12440.0    1169809.4    940.4
  9. Pipe-based Context Switching                   4000.0     231575.1    578.9
  10. Process Creation                                126.0       4761.3    377.9
  11. Shell Scripts (1 concurrent)                     42.4       5093.7   1201.3
  12. Shell Scripts (8 concurrent)                      6.0       2714.1   4523.5
  13. System Call Overhead                          15000.0    1171395.6    780.9
  14.        ========
  15. System Benchmarks Index Score                                        1127.9
  2. Dhrystone 2 using register variables         116700.0   59816870.1   5125.7
  3. Double-Precision Whetstone                       55.0      10609.1   1928.9
  4. Execl Throughput                                 43.0      15471.7   3598.1
  5. File Copy 1024 bufsize 2000 maxblocks          3960.0    1312376.3   3314.1
  6. File Copy 256 bufsize 500 maxblocks            1655.0     348509.3   2105.8
  7. File Copy 4096 bufsize 8000 maxblocks          5800.0    3686060.4   6355.3
  8. Pipe Throughput                               12440.0    3420500.7   2749.6
  9. Pipe-based Context Switching                   4000.0     668165.6   1670.4
  10. Process Creation                                126.0      49692.0   3943.8
  11. Shell Scripts (1 concurrent)                     42.4      22083.0   5208.3
  12. Shell Scripts (8 concurrent)                      6.0       3271.3   5452.2
  13. System Call Overhead                          15000.0    3164888.3   2109.9
  14.        ========
  15. System Benchmarks Index Score                                        3307.2
发表于 2012-11-7 17:53:16 | 只看该作者
估计是新上的JJ
发表于 2012-11-7 17:54:13 | 只看该作者
不了解
GMT+8, 2026-4-19 23:40 , Processed in 0.064837 second(s), 13 queries , Gzip On, MemCache On.
