查看: 4397|回复: 16
围观啦,VPS效果评价~~~~
发表于 2012-10-24 09:56:59 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
购买了一台diyivps的512VPS做性能测试,效果如何,我就不多说啦,看图就知道
内存:
硬盘:
读写:
CPU型号:
Ping:走HE路线,最近国内访问好像非常悲剧…..没事,只用来做小站缓存
下载:拖的是84的测试数据,美国之间速度一直不错
探针:
CPU跑分:
   BYTE UNIX Benchmarks (Version 5.1.2)
   System: MyVPS1541: GNU/Linux
   OS: GNU/Linux -- 2.6.18-308.16.1.el5xen -- #1 SMP Tue Oct 2 23:41:32 EDT 2012
Machine: i686 (i386)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz (8356.0 bogomips)
          Hyper-Threading, MMX, Physical Address Ext
   CPU 1: Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz (8356.0 bogomips)
   22:54:39 up 3 min,  1 user,  load average: 0.23, 0.14, 0.05; runlevel 3
Benchmark Run: Mon Oct 22 2012 22:54:39 - 23:23:01
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       15543248.4 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     2721.4 MWIPS (10.0 s, 7 samples)
Execl Throughput                               2420.5 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        432157.9 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          113997.6 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1242844.7 KBps  (30.0 s, 2 samples)
Pipe Throughput                              633662.9 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  94662.5 lps   (10.0 s, 7 samples)
Process Creation                               4835.7 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4765.6 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    931.0 lpm   (60.0 s, 2 samples)
System Call Overhead                         541857.3 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   15543248.4   1331.9
Double-Precision Whetstone                       55.0       2721.4    494.8
Execl Throughput                                 43.0       2420.5    562.9
File Copy 1024 bufsize 2000 maxblocks          3960.0     432157.9   1091.3
File Copy 256 bufsize 500 maxblocks            1655.0     113997.6    688.8
File Copy 4096 bufsize 8000 maxblocks          5800.0    1242844.7   2142.8
Pipe Throughput                               12440.0     633662.9    509.4
Pipe-based Context Switching                   4000.0      94662.5    236.7
Process Creation                                126.0       4835.7    383.8
Shell Scripts (1 concurrent)                     42.4       4765.6   1124.0
Shell Scripts (8 concurrent)                      6.0        931.0   1551.6
System Call Overhead                          15000.0     541857.3    361.2
System Benchmarks Index Score                                         713.5
Benchmark Run: Mon Oct 22 2012 23:23:01 - 23:51:30
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       28296742.3 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     5310.6 MWIPS (10.1 s, 7 samples)
Execl Throughput                               4410.3 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        334651.8 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           90029.9 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1002918.3 KBps  (30.0 s, 2 samples)
Pipe Throughput                             1237712.8 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 199768.2 lps   (10.0 s, 7 samples)
Process Creation                               8853.5 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   6897.6 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                   1034.1 lpm   (60.1 s, 2 samples)
System Call Overhead                         996437.5 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   28296742.3   2424.7
Double-Precision Whetstone                       55.0       5310.6    965.6
Execl Throughput                                 43.0       4410.3   1025.6
File Copy 1024 bufsize 2000 maxblocks          3960.0     334651.8    845.1
File Copy 256 bufsize 500 maxblocks            1655.0      90029.9    544.0
File Copy 4096 bufsize 8000 maxblocks          5800.0    1002918.3   1729.2
Pipe Throughput                               12440.0    1237712.8    994.9
Pipe-based Context Switching                   4000.0     199768.2    499.4
Process Creation                                126.0       8853.5    702.7
Shell Scripts (1 concurrent)                     42.4       6897.6   1626.8
Shell Scripts (8 concurrent)                      6.0       1034.1   1723.5
System Call Overhead                          15000.0     996437.5    664.3
System Benchmarks Index Score                                        1018.2
======= Script description and score comparison: =======
感觉效果不错,就给加分吧,亲~~~
参与人数 3威望 +17 收起 理由
mj_japen + 1 diyivps 真心坑爹的,。。
ybs885 + 1 马甲不错。水军不错。都懂
思悦创新 + 15 最腹黑的IDC...diyivps..背后捅几刀.
发表于 2012-10-24 09:58:08 | 只看该作者
发表于 2012-10-24 10:01:22 | 只看该作者
不错的 楼主马赛克技术不错
 楼主| 发表于 2012-10-24 10:02:33 | 只看该作者
Maser 发表于 2012-10-24 09:58
100块,全管理的吧,有钱人
哈,我就不告诉你
发表于 2012-10-24 10:04:53 | 只看该作者
太贵了吧
发表于 2012-10-24 10:06:20 | 只看该作者
没兴趣
发表于 2012-10-24 10:06:29 | 只看该作者
diyivps。。。幕后+背后捅几刀的IDC....
参与人数 1威望 +1 收起 理由
ybs885 + 1 他是马甲。一看就知道。
发表于 2012-10-24 10:10:28 | 只看该作者
有钱人
100块 我可以买2个了
发表于 2012-10-24 10:12:03 | 只看该作者
不需要
发表于 2012-10-24 10:13:24 | 只看该作者
太贵了啊
GMT+8, 2026-4-16 03:16 , Processed in 0.077300 second(s), 13 queries , Gzip On, MemCache On.
