查看: 1797|回复: 23
最新便便VPS评测,你懂的!!!
发表于 2012-10-23 09:49:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
       今天心血来潮,买了便便的一台香港VPS,他家是用XenServer架构和XenSystem管理平台,大家都知道的
CPU核心: Dual Intel Xeon E5-2660 2核心
物理内存: Kingston 512MB RECC DDR3
物理硬盘: Seagate 20GB SAS
国际带宽: 2Mbps on 100Mbps Switch
每月流量: 1000GB
IP地址: 1个IPv4地
原价:98元/月,使用优惠码:October,是73.5元/月
Ping值:不错,香港免北岸,速度也好,不过这口太小了点
硬盘:由于便便说不要D,但还是忍不住D了下30M/s,忘记截图了,不在折腾了
内存:未装任何环境前,用了42M
CPU:E5的CPU,很给力
下载美国Webnx资源:
探针:安装完LNMP后,重启VPS
CPU跑分:
   BYTE UNIX Benchmarks (Version 5.1.2)
   System: MyVPS967: GNU/Linux
   OS: GNU/Linux -- 2.6.18-308.16.1.el5xen -- #1 SMP Tue Oct 2 23:41:32 EDT 2012
   Machine: i686 (i386)
   Language: en_US.utf8 (charmap="UTF-8", collate="UTF-8")
   CPU 0: Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz (5017.0 bogomips)
          Hyper-Threading, MMX, Physical Address Ext
   CPU 1: Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz (5017.0 bogomips)
   17:36:42 up 10 min,  1 user,  load average: 0.15, 0.09, 0.07; runlevel 3
Benchmark Run: Mon Oct 22 2012 17:36:42 - 18:04:43
2 CPUs in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       11136247.9 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     1870.5 MWIPS (10.4 s, 7 samples)
Execl Throughput                               1048.4 lps   (29.7 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        307578.6 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           85294.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        868015.2 KBps  (30.0 s, 2 samples)
Pipe Throughput                              471532.8 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  80133.0 lps   (10.0 s, 7 samples)
Process Creation                               3402.4 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   3152.6 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    742.1 lpm   (60.0 s, 2 samples)
System Call Overhead                         383766.1 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   11136247.9    954.3
Double-Precision Whetstone                       55.0       1870.5    340.1
Execl Throughput                                 43.0       1048.4    243.8
File Copy 1024 bufsize 2000 maxblocks          3960.0     307578.6    776.7
File Copy 256 bufsize 500 maxblocks            1655.0      85294.0    515.4
File Copy 4096 bufsize 8000 maxblocks          5800.0     868015.2   1496.6
Pipe Throughput                               12440.0     471532.8    379.0
Pipe-based Context Switching                   4000.0      80133.0    200.3
Process Creation                                126.0       3402.4    270.0
Shell Scripts (1 concurrent)                     42.4       3152.6    743.5
Shell Scripts (8 concurrent)                      6.0        742.1   1236.9
System Call Overhead                          15000.0     383766.1    255.8
System Benchmarks Index Score                                         497.3
Benchmark Run: Mon Oct 22 2012 18:04:43 - 18:32:45
2 CPUs in system; running 2 parallel copies of tests
Dhrystone 2 using register variables       21484592.7 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     3768.5 MWIPS (10.3 s, 7 samples)
Execl Throughput                               3286.6 lps   (30.0 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        167684.7 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           46720.3 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        404583.4 KBps  (30.0 s, 2 samples)
Pipe Throughput                              935077.2 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 162644.5 lps   (10.0 s, 7 samples)
Process Creation                               5786.3 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   5419.4 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    801.6 lpm   (60.1 s, 2 samples)
System Call Overhead                         726019.2 lps   (10.0 s, 7 samples)
Dhrystone 2 using register variables         116700.0   21484592.7   1841.0
Double-Precision Whetstone                       55.0       3768.5    685.2
Execl Throughput                                 43.0       3286.6    764.3
File Copy 1024 bufsize 2000 maxblocks          3960.0     167684.7    423.4
File Copy 256 bufsize 500 maxblocks            1655.0      46720.3    282.3
File Copy 4096 bufsize 8000 maxblocks          5800.0     404583.4    697.6
Pipe Throughput                               12440.0     935077.2    751.7
Pipe-based Context Switching                   4000.0     162644.5    406.6
Process Creation                                126.0       5786.3    459.2
Shell Scripts (1 concurrent)                     42.4       5419.4   1278.2
Shell Scripts (8 concurrent)                      6.0        801.6   1335.9
System Call Overhead                          15000.0     726019.2    484.0
System Benchmarks Index Score                                         677.3
======= Script description and score comparison: =======
参与人数 2威望 +20 收起 理由
niniwa + 10 速度迷人
不守妇道 + 10 很给力!
发表于 2012-10-23 09:51:55 | 只看该作者
发表于 2012-10-23 09:52:16 | 只看该作者
        不错        ——来自呶呶防御鸡
发表于 2012-10-23 09:52:28 | 只看该作者
香港的ping值不错,用来做反代不错哦
发表于 2012-10-23 09:54:00 | 只看该作者
克洗待款态消乐
速度不错。
发表于 2012-10-23 09:59:52 | 只看该作者
怕以后带宽问题 其他感觉便便的挺好
 楼主| 发表于 2012-10-23 10:02:09 | 只看该作者
dantengde 发表于 2012-10-23 09:59
怕以后带宽问题 其他感觉便便的挺好
嗯,便便确实好用
发表于 2012-10-23 10:39:34 | 只看该作者
ping值10分诱人
发表于 2012-10-23 10:41:01 | 只看该作者
PING 小,但實際傳輸慢,適合小站使用
GMT+8, 2026-4-27 10:32 , Processed in 0.118396 second(s), 18 queries , Gzip On, MemCache On.
