查看: 2362|回复: 6
[疑问] 低廉的1PB备份空间
发表于 2012-10-11 03:35:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
1PB备份空间,就算你再懒人也能帮你备份15天,既然你迅雷要给我1PB,我不用对不住你,发现使用了30T还没什么
  1. #!/bin/bash
  2. #apt-get update
  3. #apt-get install -y git
  4. #git clone git://github.com/iambus/xunlei-lixian.git
  5. #echo 'alias lx="python ~/xunlei-lixian/lixian_cli.py"' >> ~/.bashrc
  6. #source ~/.bashrc
  7. lx config username 你的迅雷帐号
  8. lx config password 你的迅雷密码
  9. lx login
  10. ######~Set Directory you want to backup~######
  11. Backup_Dir1=www.baidu.com
  12. Backup_Dir2=www.google.com
  13. Backup_Dir3=www.taobao.com
  14. ######~Set MySQL UserName and password~######
  15. MYSQL_UserName=root
  16. MYSQL_PassWord=administrator
  17. ######~Set MySQL Database you want to backup~######
  18. Backup_Database_Name1=baidu
  19. Backup_Database_Name2=google
  20. Backup_Database_Name3=taobao
  21. #Values Setting END!
  22. TodayWWWBackup=WEB-*-$(date +"%Y%m%d").tar.gz
  23. TodayDBBackup=DB-*-$(date +"%Y%m%d").sql
  24. OldWWWBackup=WEB-*-$(date -d -5day +"%Y%m%d").tar.gz
  25. OldDBBackup=DB-*-$(date -d -5day +"%Y%m%d").sql
  26. tar zcf /home/backup/WEB-$Backup_Dir1-$(date +"%Y%m%d").tar.gz -C /home/wwwroot/ $Backup_Dir1
  27. tar zcf /home/backup/WEB-$Backup_Dir2-$(date +"%Y%m%d").tar.gz -C /home/wwwroot/ $Backup_Dir2
  28. tar zcf /home/backup/WEB-$Backup_Dir3-$(date +"%Y%m%d").tar.gz -C /home/wwwroot/ $Backup_Dir3
  29. /usr/local/mysql/bin/mysqldump -u$MYSQL_UserName -p$MYSQL_PassWord $Backup_Database_Name1 > /home/backup/DB-$Backup_Database_Name1-$(date +"%Y%m%d").sql
  30. /usr/local/mysql/bin/mysqldump -u$MYSQL_UserName -p$MYSQL_PassWord $Backup_Database_Name2 > /home/backup/DB-$Backup_Database_Name2-$(date +"%Y%m%d").sql
  31. /usr/local/mysql/bin/mysqldump -u$MYSQL_UserName -p$MYSQL_PassWord $Backup_Database_Name3 > /home/backup/DB-$Backup_Database_Name3-$(date +"%Y%m%d").sql
  32. rm -f /home/backup/$OldWWWBackup
  33. rm -f /home/backup/$OldDBBackup
  34. lx add ftp://abc:def@123.456.789.0/WEB-$Backup_Dir1-$(date +"%Y%m%d").tar.gz
  35. lx add ftp://abc:def@123.456.789.0/WEB-$Backup_Dir2-$(date +"%Y%m%d").tar.gz
  36. lx add ftp://abc:def@123.456.789.0/WEB-$Backup_Dir3-$(date +"%Y%m%d").tar.gz
  37. lx add ftp://abc:def@123.456.789.0/DB-$Backup_Database_Name1-$(date +"%Y%m%d").sql
  38. lx add ftp://abc:def@123.456.789.0/DB-$Backup_Database_Name2-$(date +"%Y%m%d").sql
  39. lx add ftp://abc:def@123.456.789.0/DB-$Backup_Database_Name3-$(date +"%Y%m%d").sql
这个就不做具体解释了,前提要迅雷的VIP帐号
发表于 2012-10-11 03:37:40 | 只看该作者
         你的数据敢放到迅雷离线上面 你牛        ——来自呶呶防御鸡
 楼主| 发表于 2012-10-11 03:38:39 | 只看该作者
汉陈帝国 发表于 2012-10-11 03:37
你的数据敢放到迅雷离线上面 你牛                                                             ...
额  反正我是这样做的。。。
发表于 2012-10-11 03:40:22 | 只看该作者
两天蜘蛛就把你流量吸没了
发表于 2012-10-11 03:42:26 | 只看该作者
有一个小问题。 传输速度给力么?
发表于 2012-10-11 06:44:33 | 只看该作者
看到了脚本,更方便脱裤。。
发表于 2012-10-11 06:55:44 | 只看该作者
能不能搞个压缩包加密
GMT+8, 2026-4-24 09:23 , Processed in 0.120857 second(s), 12 queries , Gzip On, MemCache On.
